Hello together!
Since yesterday, I have a problem with notifications sound.
When a notification pops up, there is no sound.
I already learned how to solve it temporarily:
The sound of Notifications is set to the Level 0% (not muted)
I can turn it back to ~50% and then it works again.
But, when I reboot, then it is at 0% again => No Sound again.
How can I create a autostart application or something like that to fix it for me?
Kernel: 5.16.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=bbd31a1a-5acd-4143-b97f-a940c8bb5b82
Desktop: KDE Plasma 5.24.0 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Medion product: S4216 v: 1.0 serial: <superuser required>
Mobo: Medion model: S4216 v: 1.0 serial: <superuser required> UEFI: American Megatrends v: 505
date: 09/28/2012
ID-1: BAT0 charge: 31.0 Wh (97.2%) condition: 31.9/36.4 Wh (87.6%) volts: 16.5 min: 14.4
model: B34 type: Li-ion serial: N/A status: Not charging
Info: model: Intel Core i5-3317U bits: 64 type: MT MCP arch: Ivy Bridge family: 6
Topology: cpus: 1x cores: 2 tpc: 2 threads: 4 smt: enabled cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2348 high: 2369 min/max: 800/2600 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 2369 2: 2333 3: 2333 4: 2359 bogomips: 13568
Device-1: Intel 3rd Gen Core processor Graphics vendor: Pegatron driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: Microdia USB 2.0 Camera type: USB driver: uvcvideo bus-ID: 1-1.1:3
chip-ID: 0c45:6457 class-ID: 0e02
Display: x11 server: X.Org 1.21.1.3 compositor: kwin_x11 driver: loaded: intel
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 507x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: VGA1 res: 1920x1080 hz: 60 dpi: 92 size: 530x300mm (20.9x11.8") diag: 609mm (24")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa 21.3.5 compat-v: 3.0
direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Pegatron
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20 class-ID: 0403
Sound Server-1: ALSA v: k5.16.8-zen1-1-zen running: yes
Device-1: Intel Centrino Wireless-N 2230 driver: iwlwifi v: kernel bus-ID: 02:00.0
chip-ID: 8086:0887 class-ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Pegatron
driver: r8169 v: kernel port: e000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: Intel Centrino Bluetooth Wireless Transceiver type: USB driver: btusb v: 0.8
bus-ID: 1-1.4:5 chip-ID: 8087:07da class-ID: e001
Local Storage: total: 223.57 GiB used: 37.78 GiB (16.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: GOODRAM model: SSDPR-CL100-240-G2 size: 223.57 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: V4.7
ID-1: / raw-size: 104.87 GiB size: 104.87 GiB (100.00%) used: 37.75 GiB (36.0%) fs: btrfs
dev: /dev/sda5 maj-min: 8:5
ID-2: /boot/efi raw-size: 99 MiB size: 95 MiB (95.96%) used: 29.9 MiB (31.4%) fs: vfat
dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 104.87 GiB size: 104.87 GiB (100.00%) used: 37.75 GiB (36.0%) fs: btrfs
ID-4: /var/log raw-size: 104.87 GiB size: 104.87 GiB (100.00%) used: 37.75 GiB (36.0%)
fs: btrfs dev: /dev/sda5 maj-min: 8:5
ID-5: /var/tmp raw-size: 104.87 GiB size: 104.87 GiB (100.00%) used: 37.75 GiB (36.0%)
ID-1: swap-1 type: zram size: 7.65 GiB used: 23 MiB (0.3%) priority: 100 dev: /dev/zram0
System Temperatures: cpu: 59.0 C mobo: N/A
Processes: 273 Uptime: 32m wakeups: 1 Memory: 7.65 GiB used: 3.31 GiB (43.3%) Init: systemd
v: 250 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.1 Packages: 1834 pacman: 1829 lib: 392
flatpak: 5 Client: shell wrapper v: 5.1.16-release inxi: 3.3.12
Garuda (2.5.4-2):
System install date: 2022-01-22
Last full system update: 2022-02-14
