No back light control after waking from sleep
Hello! Having a issue with back light. I was able to rectify my no back light control issue by adding acpi_backlight=video to the grub. However when I wake from sleep I have no control again and my brightness is stuck at 0% so it becomes unusable and i have to reboot to gain control again. My sleep back light issue has persisted across several different distros, nobara, Pop and now garuda. I am using an Optimus laptop, brightness control does work when waking from sleep on windows. I have had to add the grub command across all distros as well for initial control. Also if it helps ls /sys/class/backlight returns
lrwxrwxrwx 0 root 27 Jul 14:29  acpi_video0 -> ../../devices/pci0000:00/0000:00:01.0/0000:01:00.0/backlight/a
cpi_video0
lrwxrwxrwx 0 root 27 Jul 14:29  acpi_video1 -> ../../devices/pci0000:00/0000:00:02.0/backlight/acpi_video1
lrwxrwxrwx 0 root 27 Jul 14:29  acpi_video2 -> ../../devices/pci0000:00/0000:00:02.0/backlight/acpi_video2
Kernel: 6.4.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=024648f7-0078-44d6-9ef5-d6016beaa022 rw rootflags=subvol=@
Type: Laptop System: Acer product: Predator PT516-51s v: V1.06
Mobo: TGL model: Countryman_TLS v: V1.06 serial: <superuser required>
UEFI: Insyde v: 1.06 date: 12/03/2021
ID-1: BAT1 charge: 72.5 Wh (96.5%) condition: 75.1/100.0 Wh (75.1%)
volts: 14.9 min: 15.2 model: Getac AP20BHU type: Li-ion serial: <filter>
status: discharging cycles: 106
Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
microcode: 0x44
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 1796 high: 2300 min/max: 800/4600 scaling:
driver: intel_pstate governor: powersave cores: 1: 887 2: 988 3: 2300
4: 2300 5: 2300 6: 983 7: 2300 8: 2300 9: 2300 10: 2300 11: 1000 12: 2300
13: 2300 14: 2300 15: 920 16: 969 bogomips: 73728
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Acer Incorporated ALI
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 0000:00:02.0
chip-ID: 8086:9a60 class-ID: 0300
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
vendor: Acer Incorporated ALI driver: nvidia v: 535.86.05
alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-07) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 bus-ID: 0000:01:00.0
chip-ID: 10de:2520 class-ID: 0300
Device-3: Chicony HD User Facing driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:2 chip-ID: 04f2:b6dd
Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.65x16.65")
s-diag: 798mm (31.43")
Monitor-1: eDP-1 model: BOE Display 0x0990 built: 2020 res: 2560x1600
hz: 165 dpi: 189 gamma: 1.2 size: 344x215mm (13.54x8.46") diag: 406mm (16")
ratio: 16:10 modes: 2560x1600
API: OpenGL v: 4.6 Mesa 23.1.4 renderer: Mesa Intel UHD Graphics (TGL GT1)
direct-render: Yes
Device-1: Intel Tiger Lake-H HD Audio driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3 chip-ID: 8086:43c8
Device-2: NVIDIA GA106 High Definition Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:228e
API: ALSA v: k6.4.5-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.75 status: active with: 1: pipewire-pulse
Device-1: Intel Tiger Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 0000:00:14.3 chip-ID: 8086:43f0
Device-2: Realtek Killer E3000 2.5GbE vendor: Acer Incorporated ALI
driver: r8169 v: kernel port: 4000 bus-ID: 0000:56:00.0 chip-ID: 10ec:3000
IF: enp86s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-14:4 chip-ID: 8087:0026
address: <filter>
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 1.82 TiB used: 234.14 GiB (12.6%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 32.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 25.9 C
ID-1: / raw-size: 455.57 GiB size: 455.57 GiB (100.00%)
used: 19.4 GiB (4.3%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:5
ID-2: /boot/efi raw-size: 200 MiB size: 196 MiB (98.00%)
used: 51.6 MiB (26.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
ID-3: /home raw-size: 455.57 GiB size: 455.57 GiB (100.00%)
ID-4: /var/log raw-size: 455.57 GiB size: 455.57 GiB (100.00%)
ID-5: /var/tmp raw-size: 455.57 GiB size: 455.57 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.4 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 36.0 C mobo: N/A
Processes: 384 Uptime: 1m wakeups: 3 Memory: total: 16 GiB
available: 15.4 GiB used: 2.88 GiB (18.7%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 Packages:
pm: pacman pkgs: 1848 libs: 528 tools: octopi,pamac,paru Shell: fish
v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.28
System install date:     2023-07-18
Last full system update: 2023-07-24
