No Audio - pretty lame
ixni whatever follows. Who cares? Literally powered on. No audio. Something about James. I don't know him and I don't use DE/WM/distros that can't get audio basic PLAYING SOUND correct out of the box.
It's a shame. I dug Garuda.
  Kernel: 5.17.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=d9125faf-89ad-4e51-ab03-8a28cdef6869
    rw rootflags=subvol=@ quiet quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
  Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.4 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: LENOVO product: 82K2 v: IdeaPad Gaming 3 15ACH6
    serial: <superuser required> Chassis: type: 10 v: IdeaPad Gaming 3 15ACH6
  Mobo: LENOVO model: LNVNB161216 v: SDK0T76461 WIN serial: <superuser required> UEFI: LENOVO
    v: H3CN31WW(V2.01) date: 11/18/2021
  ID-1: BAT1 charge: 39.4 Wh (86.2%) condition: 45.7/45.0 Wh (101.5%) volts: 12.4 min: 11.5
    model: 0x43 0x65 0x6C 0x78 0x70 0x 0x4C 0x32 0x30 0x43 0x33 0x50 0x4500 type: Li-ion
    serial: <filter> status: discharging cycles: 8
  Info: model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64 type: MT MCP arch: Zen 3
    family: 0x19 (25) model-id: 0x50 (80) stepping: 0 microcode: 0xA50000C
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache: L1: 512 KiB
    desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 3288 high: 4106 min/max: 1200/4462 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 3552 2: 3552 3: 1421 4: 1718 5: 3559 6: 3552
    7: 3553 8: 3913 9: 4056 10: 3998 11: 4106 12: 3553 13: 3552 14: 3606 15: 3519 16: 1400
    bogomips: 102206
    mitigation: Retpolines, IBPB: conditional, IBRS_FW, STIBP: always-on, RSB filling
  Device-1: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: Lenovo driver: nvidia v: 515.43.04
    alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current (as of 2022-05) arch: Ampere
    pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
    bus-ID: 01:00.0 chip-ID: 10de:25a2 class-ID: 0302
  Device-2: AMD Cezanne vendor: Lenovo driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 05:00.0
    chip-ID: 1002:1638 class-ID: 0300
  Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo bus-ID: 1-3:2
    chip-ID: 13d3:56ff class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.1 compositor: kwin_x11 driver: X:
    loaded: modesetting,nvidia gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22") s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: BOE Display 0x0a81 built: 2021 res: 1920x1080 hz: 120 dpi: 142
    gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080
    min: 640x480
  OpenGL: renderer: AMD RENOIR (LLVM 13.0.1 DRM 3.44 5.17.9-zen1-1-zen) v: 4.6 Mesa 22.0.4
    direct render: Yes
  Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo driver: snd_hda_intel v: kernel
    pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1
    alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_sof_amd_renoir
    pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.5
  Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_int
el v: kernel pcie:
    gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6
  Sound Server-1: ALSA v: k5.17.9-zen1-1-zen running: yes
  Sound Server-4: PipeWire v: 0.3.51 running: yes
  Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168
  Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter vendor: Lenovo
    driver: rtw89_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 03:00.0
    chip-ID: 10ec:8852 class-ID: 0280
  Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 1-4:3
    chip-ID: 0bda:4852 class-ID: e001 serial: <filter>
  Local Storage: total: 476.94 GiB used: 125.89 GiB (26.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZALQ512HBLU-00BL2 size: 476.94 GiB
    rev: 5L2QFXM7 temp: 31.9 C scheme: GPT
  ID-1: / raw-size: 474.73 GiB size: 474.73 GiB (100.00%) used: 125.89 GiB (26.5%) fs: btrfs
    dev: /dev/nvme0n1p5 maj-min: 259:3
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 3.6 MiB (1.4%) fs: vfat
  ID-3: /home raw-size: 474.73 GiB size: 474.73 GiB (100.00%) used: 125.89 GiB (26.5%) fs: btrfs
  ID-4: /var/log raw-size: 474.73 GiB size: 474.73 GiB (100.00%) used: 125.89 GiB (26.5%)
    fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:3
  ID-5: /var/tmp raw-size: 474.73 GiB size: 474.73 GiB (100.00%) used: 125.89 GiB (26.5%)
  ID-1: swap-1 type: zram size: 13.57 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
  System Temperatures: cpu: 63.0 C mobo: N/A gpu: amdgpu temp: 54.0 C
  Processes: 375 Uptime: 7m wakeups: 1 Memory: 13.57 GiB used: 3.79 GiB (27.9%) Init: systemd
  v: 250 tool: systemctl Compilers: gcc: 12.1.0 Packages: pacman: 1609 lib: 377
  Client: shell wrapper v: 5.1.16-release inxi: 3.3.16
Garuda (2.6.3-2):
  System install date:     2022-05-22
  Last full system update: 2022-05-22
You've been using Garuda for over a year, and now you're having a hissy fit and gonna stomp your feet and hold your breath till someone designs the foolproof OS.
Good luck with that.
I'll anonymized your account now, as you requested.
BahBye. :wave:
