root=UUID=dd3b181e-c334-4d28-8cdd-b1a1db3e6edc rw rootflags=subvol=@
resume=UUID=d4e754ff-8b48-4291-8a95-9edf974158a9 loglevel=3
Desktop: LXQt v: 1.1.0 tk: Qt v: 5.15.6 info: cairo-dock, lxqt-panel
Type: Convertible System: LENOVO product: 81EM v: Lenovo ideapad FLEX
6-14IKB serial: <superuser required> Chassis: type: 31 v: Lenovo ideapad
FLEX 6-14IKB serial: <superuser required>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
serial: <superuser required> UEFI-[Legacy]: LENOVO v: 7QCN46WW
date: 11/26/2020
ID-1: BAT0 charge: 39.4 Wh (100.0%) condition: 39.4/45.5 Wh (86.5%)
volts: 8.4 min: 7.7 model: CPT-COS L17C4PB0 type: Li-poly serial: <filter>
status: full
Device-1: apple_mfi_fastcharge model: N/A serial: N/A charge: N/A
status: N/A
Device-2: wacom_battery_0 model: Wacom HID 517D serial: N/A charge: 0%
rechargeable: yes status: N/A
Info: model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1550 high: 1800 min/max: 400/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 1800 2: 800 3: 1800
4: 1800 5: 1800 6: 800 7: 1800 8: 1800 bogomips: 28800
vulnerable
PBRSB-eIBRS: Not affected
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: Logitech CrystalCam type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-3:3 chip-ID: 046d:0894 class-ID: 0102 serial: <filter>
Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-8:6 chip-ID: 13d3:56b2 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.4
Monitor-1: eDP-1 model: AU Optronics 0x403d built: 2016 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81")
diag: 354mm (13.9") ratio: 16:9 modes: 1920x1080
driver: snd_hda_intel v: kernel bus-ID: 1-3:3
alternate: snd_soc_skl,snd_soc_avs chip-ID: 046d:0894 bus-ID: 00:1f.3
class-ID: 0102 serial: <filter> chip-ID: 8086:9d71 class-ID: 0403
Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter vendor: Lenovo
ThinkPad E595 driver: rtw_8822be v: N/A modules: rtw88_8822be pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 01:00.0
chip-ID: 10ec:b822 class-ID: 0280
IF-ID-1: enp0s20f0u1c4i2 state: down mac: <filter>
Device-1: Realtek RTL8822BE Bluetooth 4.2 Adapter type: USB driver: btusb
v: 0.8 bus-ID: 1-7:5 chip-ID: 0bda:b023 class-ID: e001 serial: <filter>
address: <filter>
Local Storage: total: 119.24 GiB used: 16.28 GiB (13.7%)
model: MZVLW128HEGR-000L2 size: 119.24 GiB block-size: physical: 512 B
rev: 4L1QCXB7 temp: 32.9 C scheme: MBR
ID-1: / raw-size: 110.44 GiB size: 110.44 GiB (100.00%) used: 16.28 GiB
(14.7%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /home raw-size: 110.44 GiB size: 110.44 GiB (100.00%) used: 16.28
GiB (14.7%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /var/log raw-size: 110.44 GiB size: 110.44 GiB (100.00%) used: 16.28
ID-4: /var/tmp raw-size: 110.44 GiB size: 110.44 GiB (100.00%) used: 16.28
ID-1: swap-1 type: zram size: 7.55 GiB used: 9.2 MiB (0.1%) priority: 100
System Temperatures: cpu: 41.0 C pch: 40.0 C mobo: N/A
Processes: 225 Uptime: 2h 10m wakeups: 7 Memory: 7.55 GiB used: 2.51 GiB
(33.3%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1408
libs: 370 tools: octopi,paru Shell: Bash v: 5.1.16 running-in: qterminal
inxi: 3.3.22
Garuda (2.6.9-1):
System install date: 2022-10-22
Last full system update: 2022-10-23 ↻
I am having audio problems in Zoom. I opened the application for the first time and everything worked without issue. During the meeting my internet went down and it ultimately borked the audio in the application. When I try to use zoom now, while I still have the option to choose different audio settings, it stays locked on James DSP. I try to select the correct audio inside the application but it will not actually change it. I've tried to reboot my system and restart the application. I've tried uninstall and reinstall the application. I have looked for the setting in the global audio settings in Garuda. I've also searched the forums for an answer but the posts concerning zoom are about microphone audio rather than desktop audio failing. Please help.
