No Audio (Fresh Install)
Greetings everyone,
First and foremost, thanks for taking time off your day in order to assist me. Secondly, I apologize if my English is a bit broken, I’m not a native speaker. Now on to the issue, I just switched from Win11 to Garuda and I’m having one set-back, I’ve tried every audio option available and can’t get any sound from either my headphones or my speakers (I think that’s how you call them in English), about the specs, they’re as follow:
  Kernel: 6.5.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: tsc
    available: acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
    root=UUID=776040cd-8649-4cd6-9c60-e4d740abd812 rw rootflags=subvol=@ quiet quiet
    resume=UUID=823ef3f5-2096-4fd5-8780-b91f94d3d593 loglevel=3 ibt=off
  Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
  Type: Laptop System: ASUSTeK product: Vivobook_ASUSLaptop X3500PC_K3500PC v: 1.0
  Mobo: ASUSTeK model: X3500PC v: 1.0 serial: <superuser required> UEFI: American Megatrends LLC.
    v: X3500PC.302 date: 08/08/2022
  ID-1: BAT0 charge: 56.3 Wh (100.0%) condition: 56.3/63.0 Wh (89.4%) volts: 12.0 min: 12.0
    model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: not charging cycles: 96
  Info: model: 11th Gen Intel Core i5-11300H bits: 64 type: MT MCP arch: Tiger Lake gen: core 11
    level: v4 note: check built: 2020 process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
    microcode: 0xAC
  Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache: L1: 320 KiB
    desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 3100 min/max: 400/4400 scaling: driver: intel_pstate governor: powersave
    cores: 1: 3100 2: 3100 3: 3100 4: 3100 5: 3100 6: 3100 7: 3100 8: 3100 bogomips: 49766
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: ASUSTeK driver: i915 v: kernel
    arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1
    bus-ID: 0000:00:02.0 chip-ID: 8086:9a49 class-ID: 0300
  Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: ASUSTeK driver: nouveau v: kernel
    non-free: 535.xx+ status: current (as of 2023-08) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
    built: 2020-22 bus-ID: 0000:01:00.0 chip-ID: 10de:25a2 class-ID: 0302
  Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 3-6:4 chip-ID: 13d3:5458 class-ID: fe01 serial: <filter>
  Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.2.0 compositor: kwin_x11 driver: X:
    loaded: modesetting,nouveau alternate: fbdev,intel,nv,vesa dri: iris,nouveau gpu: i915
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22") s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: Samsung 0x4161 built: 2020 res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2
    size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 23.1.7-arch1.1 renderer: Mesa Intel Xe Graphics (TGL GT2)
    direct-render: Yes
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
    alternate: snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
  API: ALSA v: k6.5.2-zen1-1-zen status: kernel-api with: aoss type: oss-emulator
  Server-1: PipeWire v: 0.3.79 status: active with: 1: pipewire-pulse status: active
  Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3 chip-ID: 8086:a0f0
    mode: 1.1 bus-ID: 3-10:6 chip-ID: 8087:0026 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: disabled rfk-block: hardware: no
    software: no address: see --recommends
    bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Dr
ives:
  Local Storage: total: 1.4 TiB used: 8.64 GiB (0.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: HBRPEKNX0202A size: 476.94 GiB
    block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
    fw-rev: G002 temp: 36.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Intel model: HBRPEKNX0202AO size: 27.25 GiB
    fw-rev: K5110440 temp: 46.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: Expansion size: 931.51 GiB block-size:
    physical: 4096 B logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A
    serial: <filter> fw-rev: 0710 scheme: MBR
  ID-1: / raw-size: 467.84 GiB size: 467.84 GiB (100.00%) used: 8.64 GiB (1.8%) fs: btrfs
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 576 KiB (0.2%) fs: vfat
  ID-3: /home raw-size: 467.84 GiB size: 467.84 GiB (100.00%) used: 8.64 GiB (1.8%) fs: btrfs
  ID-4: /var/log raw-size: 467.84 GiB size: 467.84 GiB (100.00%) used: 8.64 GiB (1.8%) fs: btrfs
  ID-5: /var/tmp raw-size: 467.84 GiB size: 467.84 GiB (100.00%) used: 8.64 GiB (1.8%) fs: btrfs
  ID-1: swap-1 type: zram size: 7.46 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
    avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 8 dev: /dev/zram0
  ID-2: swap-2 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
    maj-min: 259:3
  System Temperatures: cpu: 44.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 2500
  Processes: 254 Uptime: 12m wakeups: 1660 Memory: total: 8 GiB note: est. available: 7.46 GiB
  used: 3.31 GiB (44.3%) Init: systemd v: 254 default: graphical tool: systemctl Compilers:
  gcc: 13.2.1 Packages: pm: pacman pkgs: 1800 libs: 519 tools: octopi,paru Client: shell wrapper
  v: 5.1.16-release inxi: 3.3.29
  System install date:     2023-09-12
  Last full system update: 2023-09-12
Thanks in advance and sorry for the noob question. I’ve already done some research around the forum and the solutions posted were of no help to me.
Have a nice day!
I have solved the issue, had to reinstall pipewire with alsa enabled and reboot, also reactivate the sound services.
