No audio devices
Hello Garuda users. My issue is that none of my onboard or external audio devices are detected.
root=UUID=5ad87e9d-b4b7-48d0-bbec-4bde3520a5b9 rw rootflags=subvol=@
resume=UUID=bc294b7c-46f6-45f7-b445-ad17603d3727 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 1
Type: Desktop Mobo: ASRock model: B550 Extreme4 serial: <superuser required>
UEFI: American Megatrends LLC. v: L2.62 date: 01/31/2023
Info: model: AMD Ryzen 7 5800X3D bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 3410 high: 3567 min/max: 2200/4549 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3400 2: 3400
3: 3400 4: 3400 5: 3400 6: 3400 7: 3400 8: 3567 9: 3400 10: 3400 11: 3400
12: 3400 13: 3400 14: 3400 15: 3400 16: 3400 bogomips: 108801
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX] vendor: ASUSTeK
driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm)
built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-3
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 07:00.0 chip-ID: 1002:744c
s-diag: 777mm (30.58")
Monitor-1: DP-3 mapped: DisplayPort-2 model: ViewSonic XG270QC
serial: <filter> built: 2020 res: 2560x1440 hz: 60 dpi: 109 gamma: 1.2
max: 2560x1440 min: 720x400
API: OpenGL v: 4.6 Mesa 23.1.5 renderer: AMD Radeon RX 7900 XT (gfx1100
LLVM 15.0.7 DRM 3.49 6.2.13-zen-1-zen) direct-render: Yes
Device-1: AMD driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 07:00.1 chip-ID: 1002:ab30 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: FiiO K3 driver: snd-usb-audio type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 1-6:5 chip-ID: 2972:0047 class-ID: fe01
API: ALSA v: k6.2.13-zen-1-zen status: kernel-api with: aoss
Device-1: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0
Local Storage: total: 11.38 TiB used: 18.38 GiB (0.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT2000P5SSD8
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: P4CR324 temp: 40.9 C
model: WD80EDAZ-11TA3A0 size: 7.28 TiB block-size: physical: 4096 B
fw-rev: 0A81 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000BX500SSD1
tech: SSD serial: <filter> fw-rev: 030 scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT480BX500SSD1
tech: SSD serial: <filter> fw-rev: 056 scheme: MBR
ID-5: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WDS100T2B0B-00YS70 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 20WD
ID-6: /dev/sde maj-min: 8:64 vendor: Toshiba model: KIOXIA TransMemory
size: 28.85 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: PMAP scheme: MBR
ID-1: / raw-size: 896.82 GiB size: 896.82 GiB (100.00%)
used: 18.38 GiB (2.0%) fs: btrfs dev: /dev/sdd2 maj-min: 8:50
used: 576 KiB (0.2%) fs: vfat dev: /dev/sdd1 maj-min: 8:49
ID-3: /home raw-size: 896.82 GiB size: 896.82 GiB (100.00%)
ID-4: /var/log raw-size: 896.82 GiB size: 896.82 GiB (100.00%)
ID-5: /var/tmp raw-size: 896.82 GiB size: 896.82 GiB (100.00%)
ID-1: swap-1 type: partition size: 34.39 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdd3 maj-min: 8:51
ID-2: swap-2 type: zram size: 31.27 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 44.1 C mobo: N/A gpu: amdgpu temp: 50.0 C
mem: 64.0 C
Processes: 377 Uptime: 21m wakeups: 0 Memory: total: 32 GiB
available: 31.27 GiB used: 3.44 GiB (11.0%) Init: systemd v: 254
pm: pacman pkgs: 1822 libs: 523 tools: octopi,paru Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.29
System install date:     2023-08-17
Last full system update: 2023-08-17 ↻
Fixed the problem.
Changed Kernel to Zen 3.
What is “Zen 3”?
The 6.2.13 kernel is nearly four months old–probably, you just installed it today but are using an old ISO. Then, you brought your system up to date:
So you had updated the kernel, but not rebooted (if you had rebooted before running that inxi command, your kernel version would be 6.4.10 or whatever it is now). A lot of times after updating the kernel, a restart is needed to get everything working correctly.
Most likely, the fix was just rebooting the device.
