No Audio Below 20% volume
Hey all, I'm having a minor issue with some audio. When I set my system audio to 20% or below, it results in no audio coming through my speakers. I do have my audio setup through my Arctis Pro Wireless DAC, so when my headset is not on it goes to my external speakers. This audio is handled by a USB connection. I've searched up around for the answer, but I'm not seeing anyone else with pipewire reporting the same or similar issue.
System:    Kernel: 5.14.10-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
           parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=b27e29cc-e65b-42d4-be2f-761502e322f9
           rw [email protected] quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
           systemd.unified_cgroup_hierarchy=1 resume=UUID=994f7455-bd08-4bca-b59b-08cb62e0b55b loglevel=3
           Desktop: GNOME 40.5 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1 Distro: Garuda Linux
Machine:   Type: Desktop System: Gigabyte product: Z390 I AORUS PRO WIFI v: N/A serial: <filter>
           Mobo: Gigabyte model: Z390 I AORUS PRO WIFI-CF v: x.x serial: <filter>
           UEFI-[Legacy]: American Megatrends v: F8i date: 01/19/2021
CPU:       Info: 6-Core model: Intel Core i7-8086K bits: 64 type: MT MCP arch: Kaby Lake note: check
           family: 6 model-id: 9E (158) stepping: A (10) microcode: EA cache: L2: 12 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 95999
           Speed: 4811 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 4811 2: 4862 3: 4946 4: 4737
           5: 4963 6: 4920 7: 4678 8: 4910 9: 4910 10: 4600 11: 4763 12: 4883
Graphics:  Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT / 6800M] driver: amdgpu v: kernel bus-ID: 03:00.0
           chip-ID: 1002:73df class-ID: 0300
           Display: x11 server: X.Org 1.20.13 compositor: gnome-shell driver: loaded: amdgpu,ati
           unloaded: modesetting,radeon alternate: fbdev,vesa display-ID: :1 screens: 1
           Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0") s-diag: 777mm (30.6")
           Monitor-1: HDMI-A-0 res: 2560x1440 hz: 60 dpi: 123 size: 527x296mm (20.7x11.7")
           diag: 604mm (23.8")
           OpenGL:
           renderer: AMD Radeon RX 6700 XT (NAVY_FLOUNDER DRM 3.42.0 5.14.10-zen1-1-zen LLVM 12.0.1)
           v: 4.6 Mesa 21.2.3 direct render: Yes
Audio:     Device-1: Intel Cannon Lake PCH cAVS vendor: Gigabyte driver: snd_hda_intel v: kernel
           alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
           Device-2: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT] driver: snd_hda_intel
           v: kernel bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
           Device-3: SteelSeries ApS Arctis Pro Wireless type: USB
           driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-8.3:10 chip-ID: 1038:1294 class-ID: 0300
           Sound Server-1: ALSA v: k5.14.10-zen1-1-zen running: yes
           Sound Server-4: PipeWire v: 0.3.38 running: yes
Network:   Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3
           chip-ID: 8086:a370 class-ID: 0280
           Device-2: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel port: efa0
           bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
           IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth: Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB driver: btusb v: 0.8
           bus-ID: 1-14:9 chip-ID: 8087:0aaa class-ID: e001
Drives:    Local Storage: total: 4.59 TiB used: 667.58 GiB (14.2%)
           ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: KXG50ZNV1T02 NVMe 1024GB
           size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
           serial: <filter> rev: AADA4104 temp: 39.9 C scheme: GPT
           ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Samsung model: PM961 NVMe 1024GB size: 953.87 GiB
           rev: CXY74D1Q temp: 38.9 C scheme: MBR
           ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Apple model: HDD HTS541010A9E662
           size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: HDD rpm: 5400
           serial: <filter> scheme: GPT
           ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: Toshiba model: MQ04ABD200 size: 1.82 TiB
           block-size: physical: 4096 B logical: 512 B type: HDD rpm: 5400 serial: <filter> scheme: GPT
Partition: ID-1: / raw-size: 919.45 GiB size: 919.45 GiB (100.00%) used: 113.49 GiB (12.3%) fs: btrfs
           dev: /dev/nvme1n1p1 maj-min: 259:3
           ID-2: /home raw-size: 919.45 GiB size: 919.45 GiB (100.00%) used: 113.49 GiB (12.3%) fs: btrfs
           ID-3: /var/log raw-size: 919.45 GiB size: 919.45 GiB (100.00%) used: 113.49 GiB (12.3%)
           fs: btrfs dev: /dev/nvme1n1p1 maj-min: 259:3
           ID-4: /var/tmp raw-size: 919.45 GiB size: 919.45 GiB (100.00%) used: 113.49 GiB (12.3%)
           ID-1: swap-1 type: partition size: 34.41 GiB used: 0 KiB (0.0%) priority: -2
           dev: /dev/nvme1n1p2 maj-min: 259:4
           ID-2: swap-2 type: zram size: 31.29 GiB used: 2.8 MiB (0.0%) priority: 100 dev: /dev/zram0
Sensors:   System Temperatures: cpu: 48.0 C mobo: 44.0 C gpu: amdgpu temp: 55.0 C mem: 66.0 C
           Fan Speeds (RPM): N/A gpu: amdgpu fan: 748
Info:      Processes: 401 Uptime: 1h 3m wakeups: 0 Memory: 31.29 GiB used: 6.15 GiB (19.6%) Init: systemd
           v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1399 lib: 432
           Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: gnome-terminal inxi: 3.3.06
Is the DAC detecting the low input level as silence and disabling its output?
I've been testing and I doubt it as it wasn't an issue under Windows, but things can change.
The DAC is being recognized as a Headset due to the USB plugin though.
It would be worth removing the DAC and seeing if the issue persists with the built-in audio hardware.
[Solved]
Turns out it's an issue with the config file usb-gaming-headset-output-stereo.conf.
In /usr/share/alsa-card-profile/mixer/paths/usb-gaming-headset-output-stereo.conf I added
db-values = "0:-36  30:45"
I would love to explain how this works, but I genuinely have no clue how or why. Just going with it for now.
