Hello, I am John Garcia,. I have just begun using Garuda. and have a small problem:
In the KDE system settings I do not have a printer configuration icon.
I did install my printer using the CUPS web page. Every thing appears to work on the printer/scanner (HP 3700)
I was just wondering where the printer set up icon is.
Install hplip
package, reboot then use the HP icon in the menu to run the setup routine (there are several choices and you may have to fiddle with them if you're new to the routine). After that i's just a click or two to add in under the System Settings.
Thanks for your help.
