New Firedragon Not Listed In Default Applications
Kernel: 6.7.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=ca46cfb3-682f-4d27-ab75-37f70793ff5a rw rootflags=subvol=@
quiet resume=UUID=b8625a64-75a5-4b7a-9aeb-c6aef537fd04 loglevel=3
split_lock_detect=off sysrq_always_enabled=1 ibt=off
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_wayland vt: 1
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X515EA_X515EA
Mobo: ASUSTeK model: X515EA v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: X515EA.309 date: 05/16/2022
ID-1: BAT0 charge: 21.7 Wh (60.1%) condition: 36.1/37.1 Wh (97.2%)
volts: 7.8 min: 7.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 31
Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
microcode: 0xB4
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 654 high: 1163 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 1049
5: 1163 6: 1021 7: 400 8: 400 bogomips: 38707
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: ASUSTeK
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 0000:00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 322e:2103
class-ID: 0e02
Monitor-1: eDP-1 res: 1670x939 size: N/A modes: N/A
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.3.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
device-ID: 8086:9a49 memory: 14.96 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.276 layers: 3 device: 0 type: integrated-gpu name: Intel
Xe Graphics (TGL GT2) driver: mesa intel v: 23.3.5-arch1.1
device-ID: 8086:9a49 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 23.3.5-arch1.1 (LLVM 16.0.6) device-ID: 10005:0000
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: ASUSTeK
bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
API: ALSA v: k6.7.4-zen1-1-zen status: kernel-api tools: N/A
bus-ID: 0000:02:00.0 chip-ID: 8086:2725 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:3 chip-ID: 8087:0032
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 931.51 GiB used: 63.61 GiB (6.8%)
fw-rev: 2B2QEXM7 temp: 32.9 C scheme: GPT
ID-1: / raw-size: 914.36 GiB size: 914.36 GiB (100.00%)
used: 63.61 GiB (7.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 914.36 GiB size: 914.36 GiB (100.00%)
ID-4: /var/log raw-size: 914.36 GiB size: 914.36 GiB (100.00%)
ID-5: /var/tmp raw-size: 914.36 GiB size: 914.36 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.32 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.86 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 37.0 C mobo: N/A
Fan Speeds (rpm): cpu: 2300
Processes: 257 Uptime: 20m wakeups: 0 Memory: total: 16 GiB note: est.
available: 15.32 GiB used: 3.48 GiB (22.7%) Init: systemd v: 255
pm: pacman pkgs: 1518 libs: 403 tools: octopi,paru Shell: fish v: 3.7.0
Garuda (2.6.23-1):
System install date:     2024-01-25
Last full system update: 2024-02-07
Failed units
I have uninstalled Firedragon. After that, I did:
sudo rm -rf /usr/lib/firedragon
Delete everything from your Home Firedragon folder:
rm -rf ~/.firedragon
Then cleaned packages cache, cleaned caches
Installed Firedragon.
What I have observed:
Ublock Origin shows when I go to install extensions, however it does not show in the hamburger menu for the extensions.
Went to select Firedragon as default browser and Firedragon is not listed.
uBlock installs at the same time as FD, you don’t “go to install” it.
Let’s try by removing Plasma Integration in the other thread, it’s a start.
Here?
Glad you showed me where to look. The thing is Firedragon does not show (perhaps I am blind or worse an inveterate liar)
The thing about Ublock Origin not showing in the hamburger menu is a Floorp issue
Just installed Floorp and it does not show in the hamburger menu (again annother lie from an inveterate liar)
This icon?
Or this one?
I remember having to play around to get it out of the Extensions Overflow menu, it was annoying. I think you have to right-click the bar and CUSTOMIZE TOOLBAR and find the extension from there.
I have never seen an extension showing up in the Hamburger Menu (first screenshot above in this post).
Just add it. Use the “Other…” item in from the drop down menu.
Sorry to say, I’ve had it with Firedragon.
Best wishes with this endeavour.
