Networkmanager and wpa_supplicant won't shutdown since kernel 6.6.5
Hello,
Since the last kernel update (6.6.5) system can’t shutdown or reboot because networkmanager and wpa_supplicant won’t shutdown, it’s not related to Garuda as i saw the same problem on arch forum but for those who have this problem just restore a snapshot with an older kernel version (i took one from 2 days ago with 6.6.4) and the system Shutdown and reboot normaly.
yup same issue for me . There’s iwd as an alternative .
but i couldn’t find a setup guide to switch to iwd .
Request for garuda maintainers to provide a setup guide to switch to iwd .
I don’t suppose either of you tried a different kernel? I read the Arch thread and switching kernels (to LTS) didn’t work for one user.
The problem seems to be specific network cards.
Yes with a snapshot from 2 days ago and Kernel 6.6.4 it works normaly, it’s just the 6.6.5 that cause that problem.
666 is out now.
You mean the devil, right? :grin:
The End Times are near!!!
I guess we may now add one to the list.
You can manually add iwd yourself, (if you want to test out iwd).
How to replace wpa_supplicant with iwd:
With a text editor, create the required iwd configuration file for Network Manager:
/etc/NetworkManager/conf.d/wifi_backend.conf
With the following contents:
[device]
wifi.backend=iwd
Then, save the configuration file.
Next, Install and enable iwd, and mask wpa_supplicant:
sudo pacman -Syu iwd
systemctl stop NetworkManager
systemctl stop wpa_supplicant
systemctl mask wpa_supplicant
systemctl enable --now iwd.service
systemctl daemon-reload
systemctl start NetworkManager
A restart may be required afterwards.
How to revert your changes and restore wpa_supplicant:
To restore wpa_supplicant usage, comment out the lines you created in /etc/NetworkManager/conf.d/wifi_backend.conf , as so:
#[device]
#wifi.backend=iwd
Save the changes, then execute:
systemctl disable --now iwd.service
systemctl mask iwd.service
systemctl unmask wpa_supplicant
systemctl enable --now wpa_supplicant
Worked the last time I did this, but it’s been awhile.
I have a problem with reconnections if the wifi restarts
Please open a separate topic. this one has been solved.
