Network Manager not allowing to connect to 5 Ghz Network
I upgraded my system recently and found that network manager is not allowing me to connect to 5 Ghz network. If i connect my 2.5 Ghz adapter it connects automatically.
Here is the relevant aoutput
Linux ganesan-asusdesktop 5.12.2-zen2-1-zen #1 ZEN SMP PREEMPT Mon, 10 May 2021 20:18:35 +0000 x86_64 GNU/Linux
Output of Inxi - Fxxxxza
System:    Kernel: 5.12.2-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=14ab71bb-812e-4e2b-9e7b-c04af69c31d2
rw [email protected] quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
systemd.unified_cgroup_hierarchy=1 resume=UUID=b7f2a5e4-bca3-4b55-b5bc-eaa633f88a6b loglevel=3
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine:   Type: Desktop Mobo: ASUSTeK model: H110M-CS v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 4210 date: 07/03/2019
CPU:       Info: Dual Core model: Intel Core i3-7100 bits: 64 type: MT MCP arch: Kaby Lake family: 6
model-id: 9E (158) stepping: 9 microcode: DE cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 31199
Speed: 3900 MHz min/max: 800/3900 MHz Core speeds (MHz): 1: 3900 2: 3901 3: 3901 4: 3896
Graphics:  Device-1: NVIDIA GT218 [GeForce 210] driver: nouveau v: kernel bus-ID: 01:00.0
chip-ID: 10de:0a65 class-ID: 0300
Device-2: Logitech Webcam C170 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-8:4
chip-ID: 046d:082b class-ID: 0102
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: nouveau
unloaded: modesetting alternate: fbdev,nv,vesa display-ID: :0 screens: 1
Monitor-1: HDMI-1 res: 1920x1080 hz: 60 dpi: 102 size: 480x270mm (18.9x10.6")
diag: 551mm (21.7")
OpenGL: renderer: NVA8 v: 3.3 Mesa 21.1.0 direct render: Yes
Audio:     Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170 class-ID: 0403
Device-2: NVIDIA High Definition Audio driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:0be3 class-ID: 0403
Device-3: Logitech Webcam C170 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-8:4
Sound Server-1: ALSA v: k5.12.2-zen2-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.27 running: yes
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169
v: kernel port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: TP-Link TL-WN722N v2/v3 [Realtek RTL8188EUS] type: USB driver: r8188eu bus-ID: 1-1:14
chip-ID: 2357:010c class-ID: 0000 serial: <filter>
IF: wlan0 state: up mac: <filter>
Drives:    Local Storage: total: 1.93 TiB used: 19.98 GiB (1.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: TeamGroup model: T253LE120G size: 111.79 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 61.2
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000VM003-1ET164 size: 1.82 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 5900 rpm serial: <filter>
rev: SC12 scheme: GPT
Partition: ID-1: / raw-size: 102.73 GiB size: 102.73 GiB (100.00%) used: 19.98 GiB (19.4%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.45%) used: 546 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 102.73 GiB size: 102.73 GiB (100.00%) used: 19.98 GiB (19.4%) fs: btrfs
ID-4: /var/log raw-size: 102.73 GiB size: 102.73 GiB (100.00%) used: 19.98 GiB (19.4%)
ID-5: /var/tmp raw-size: 102.73 GiB size: 102.73 GiB (100.00%) used: 19.98 GiB (19.4%)
Swap:      Kernel: swappiness: 10 (default 60) cache-pressure: 75 (default 100)
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3
maj-min: 8:3
ID-2: swap-2 type: zram size: 1.93 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-3: swap-3 type: zram size: 1.93 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-4: swap-4 type: zram size: 1.93 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-5: swap-5 type: zram size: 1.93 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
Sensors:   System Temperatures: cpu: 51.0 C mobo: 27.8 C gpu: nouveau temp: 58.0 C
Info:      Processes: 216 Uptime: 2h 11m wakeups: 0 Memory: 7.7 GiB used: 3.56 GiB (46.2%) Init: systemd
v: 248 tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1307 lib: 316
Shell: fish v: 3.2.2 running-in: konsole inxi: 3.3.04
Does the previous solution no longer work?
No, its not working. It is just asking for password
Which package is this driver from? If it's a DKMS driver, have you rebuilt it? Have you tried with a different kernel, e.g. linux-lts?
Please also think about what you could try rather than relying on someone to provide a copy-paste solution. Then, you can feed back and say what you have tried and what does - or doesn't - work.
Ok Jonathon
I'm kind of with Jonathon in that you haven't provided any background info on this. You never even mentioned your prior related thread on this issue (big time waster).
That said I would try only allowing 5 GHz connections through your routers setup and also through Network Manager to see if you can force a 5GHz connection.
Oh, also, remove and re-add the connection.
