I was install on two my PC KDE Garuda linux and update both. Problem is that is one PC I have possibility, have tab in setting: Network drive but in another PC not exist this tab. Sending in atach print screen of PC where I can see and find this tab. I try to update second PC but its write that have last update, nothing to update. Please where can be problem?
Hi!
please post
inxi -Fxxxza
(Also is there a welcome back to the garuda linux forum
badge.)
Hello Thank you for fast help. This is from PC where is not show Network tab.
System: Kernel: 5.11.16-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=85e99b34-6c41-4228-bf5b-f8d9fbb20696
systemd.unified_cgroup_hierarchy=1 resume=UUID=19610d06-be11-45a2-8ad7-040fe25d0771 loglevel=3
Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 2 dm: SDDM
Machine: Type: Desktop Mobo: Intel model: NUC6i7KYB v: H90766-406 serial: UEFI-[Legacy]: Intel
v: KYSKLi70.86A.0053.2018.0312.1143 date: 03/12/2018
Battery: Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K360 serial:
CPU: Info: Quad Core model: Intel Core i7-6770HQ bits: 64 type: MT MCP arch: Skylake-S family: 6
model-id: 5E (94) stepping: 3 microcode: E2 cache: L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 41599
Speed: 3500 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 3500 2: 3382 3: 3442 4: 3405
5: 3465 6: 3443 7: 3401 8: 3401
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Graphics: Device-1: Intel Iris Pro Graphics 580 driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:193b
Device-2: Logitech HD Pro Webcam C920 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-4:3
chip-ID: 046d:082d class-ID: 0102 serial:
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: intel
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0") s-diag: 777mm (30.6")
Monitor-1: DP3 res: 2560x1440 hz: 60 dpi: 92 size: 710x400mm (28.0x15.7") diag: 815mm (32.1")
OpenGL: renderer: Mesa Intel Iris Pro Graphics 580 (SKL GT4) v: 4.6 Mesa 21.0.3
direct render: Yes
Audio: Device-1: Intel 100 Series/C230 Series Family HD Audio driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:a170 class-ID: 0403
Sound Server-1: ALSA v: k5.11.16-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.26 running: yes
Network: Device-1: Intel Ethernet I219-LM driver: e1000e v: kernel port: f040 bus-ID: 00:1f.6
chip-ID: 8086:15b7 class-ID: 0200
IF: eno1 state: down mac:
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel port: f040 bus-ID: 03:00.0
chip-ID: 8086:24f3 class-ID: 0280
IF: wlp3s0 state: up mac:
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-9:8
chip-ID: 8087:0a2b class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: up address:
Drives: Local Storage: total: 256.17 GiB used: 14.86 GiB (5.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT275MX300SSD4 size: 256.17 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: rev: R060
scheme: MBR
Partition: ID-1: / raw-size: 239.1 GiB size: 239.1 GiB (100.00%) used: 14.86 GiB (6.2%) fs: btrfs
dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 239.1 GiB size: 239.1 GiB (100.00%) used: 14.86 GiB (6.2%) fs: btrfs
ID-3: /var/log raw-size: 239.1 GiB size: 239.1 GiB (100.00%) used: 14.86 GiB (6.2%) fs: btrfs
ID-4: /var/tmp raw-size: 239.1 GiB size: 239.1 GiB (100.00%) used: 14.86 GiB (6.2%) fs: btrfs
ID-1: swap-1 type: partition size: 17.07 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda2
maj-min: 8:2
ID-2: swap-2 type: zram size: 1.94 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-3: swap-3 type: zram size: 1.94 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-4: swap-4 type: zram size: 1.94 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-5: swap-5 type: zram size: 1.94 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-6: swap-6 type: zram size: 1.94 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-7: swap-7 type: zram size: 1.94 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-8: swap-8 type: zram size: 1.94 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-9: swap-9 type: zram size: 1.94 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram7
Sensors: System Temperatures: cpu: 41.5 C mobo: 29.8 C
Info: Processes: 249 Uptime: 46m wakeups: 7 Memory: 15.52 GiB used: 4.25 GiB (27.4%) Init: systemd
v: 248 tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1429 lib: 366
Shell: fish v: 3.2.1 running-in: konsole inxi: 3.3.04
Have you enable samba support is setup assistent?
Garuda seting/System Components, Priting and scaning have chack Sampa support
It might be that one computer does not support it,
But that is odd.
This is news comp, not so much old...Normaly can from doplhin add network with samba. All is working fine, but if I do from seting add Netwok Drives is mount me automaticly so its like drive after. Maybe when download first update was intertent conection down so process was stoped and after was write that is all updated. Maybe its last update with Network drive?
That is odd.
Yes I do. as well
I did new install, also from boot live usb tab network drives is not exist in setting. Now I try to boot usb live disk on PC where its show tab Network drives, and is not show. So from Garuda live disk is not exist this tab. Please look one more time on your setting that you hace this setting. In atach sending. Maybe I install something that dont know?
Install
sudo pacman -S kdenetwork-filesharing
Also install
samba-mounter-git
Hello, thank you so much. This is working perfect.
And use three ~ below and above post to make it look organized.
