Nemo trying to use xterm but default is alacritty
i am trying to use alacritty as default. as archwiki says i ran those commands to use alacritty as default for nemo.
so when i try "open in terminal" it uses alacritty which is fine. but when i try to open a file which usually opens in terminal like "micro" (a fork of nano i think), it doesn't launch the terminal.
what have i tried:
  1. i installed xterm and my file opened with xterm and micro
  2. i installed pcmanfm and my file open with alacritty and micro (which i want)
  3. tried running nemo --debug which throws this when i try to open my terminal: (nemo:1143079): GLib-GIO-DEBUG: 20:51:14.459: Couldn’t find a known terminal
  4. i added custom command to open file like : alacritty -e micro and that works. (i don't want this method, because the title becomes 'alacritty' so if i add multiples like this, all will show as alacritty but they run different programs such as micro, vscode etc.
garuda-inxi:
  Kernel: 6.0.1-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    root=UUID=5a1a7018-04d3-413c-8c48-65d37ccf7308 rw rootflags=subvol=@
    resume=UUID=4d1231c9-2dd3-48e1-9758-f32fd70cbe97 loglevel=3
  Desktop: Qtile v: 0.22.2.dev9+g946908b9 vt: 1 dm: SDDM
  Type: Desktop Mobo: Gigabyte model: B450M S2H v: x.x
    serial: <superuser required> UEFI: American Megatrends v: F50
    date: 11/27/2019
  Info: model: AMD Ryzen 3 3100 bits: 64 type: MT MCP arch: Zen 2 gen: 3
    L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB
    L3: 16 MiB desc: 2x8 MiB
  Speed (MHz): avg: 3551 high: 3604 min/max: 2200/3906 boost: enabled
    scaling: driver: acpi-cpufreq governor: performance cores: 1: 3590 2: 3588
    3: 3600 4: 3600 5: 3604 6: 3226 7: 3600 8: 3600 bogomips: 57492
    protection
    vendor: Sapphire driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
    ports: active: HDMI-A-2 empty: DP-1, DP-2, DVI-D-1, HDMI-A-1
    bus-ID: 0a:00.0 chip-ID: 1002:67df class-ID: 0300 temp: 55.0 C
  Display: x11 server: X.Org v: 21.1.4 compositors: 1: Qtile
    v: 0.22.2.dev9+g946908b9 2: Picom v: git-8a373 driver: X: loaded: amdgpu
    unloaded: modesetting alternate: fbdev,vesa dri: radeonsi gpu: amdgpu
  Monitor-1: HDMI-A-2 mapped: HDMI-A-1 model: LG (GoldStar) FULL HD
    serial: <filter> built: 2020 res: 1920x1080 dpi: 102 gamma: 1.2
    size: 480x270mm (18.9x10.63") diag: 551mm (21.7") ratio: 16:9 modes:
  OpenGL: renderer: AMD Radeon RX 570 Series (polaris10 LLVM 14.0.6 DRM
    3.48 6.0.1-zen2-1-zen) v: 4.6 Mesa 22.2.1 direct render: Yes
    vendor: Sapphire driver: snd_hda_intel bus-ID: 3-1:2 v: kernel
    chip-ID: 0c76:16cb pcie: gen: 3 class-ID: 0300 speed: 8 GT/s lanes: 16
    bus-ID: 0a:00.1 chip-ID: 1002:aaf0 class-ID: 0403
  Device-3: JMTek LLC. FANTECH CAPTAIN 7.1 type: USB
  Sound API: ALSA v: k6.0.1-zen2-1-zen running: yes
    lanes: 1 port: f000 bus-ID: 09:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp9s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  IF-ID-1: docker0 state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IF-ID-2: vethf56907c state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  Local Storage: total: 1.14 TiB used: 794.2 GiB (67.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SanDisk model: ADATA SX6000PNP
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B
    speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: V9002s34
    temp: 40.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
    speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: CC43
  ID-1: / raw-size: 221.05 GiB size: 221.05 GiB (100.00%) used: 103.56 GiB
    (46.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 25.9 MiB
    (8.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 221.05 GiB size: 221.05 GiB (100.00%) used: 103.56
    GiB (46.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-4: /var/log raw-size: 221.05 GiB size: 221.05 GiB (100.00%) used: 103.56
  ID-5: /var/tmp raw-size: 221.05 GiB size: 221.05 GiB (100.00%) used: 103.56
  ID-1: swap-1 type: zram size: 15.56 GiB used: 84.1 MiB (0.5%)
  ID-2: swap-2 type: partition size: 17.13 GiB used: 0 KiB (0.0%)
  System Temperatures: cpu: 63.4 C mobo: N/A gpu: amdgpu temp: 55.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 789
  Processes: 319 Uptime: 5h 46m wakeups: 0 Memory: 15.57 GiB used: 4.06 GiB
  (26.1%) Init: systemd v: 251 default: graphical tool: systemctl
  Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1781
  libs: 498 tools: paru,yay pm: rpm pkgs: 0 Shell: Zsh v: 5.9
  running-in: alacritty inxi: 3.3.22
Garuda (2.6.8-1):
  System install date:     2022-08-04
  Last full system update: 2022-10-16 ↻
  Failed units:            bluetooth-autoconnect.service irqbalance.service swapfile.swap
Have you ever managed to fix this? I have the same problem.
Please open new thread and follow the template.
Or check the issue list ans ask there.
This topic is very old :slight_smile:
