Using Garuda xfce.
I have a gaming laptop which I use for virtual machines(virt-manager) it's a intel 9750 h , 16 gb ram. My laptop is always on charging. I have noticed quite a lot of heating after getting my hands dirty in Garuda assistant. I have thermald both boxes checked. Coz it manages cpu temps well on recent intel machines. I don't use TLP because it messes up with turbo boost. I never touched intel undervolt stuff.
Now on to auto cpu Freq.
I have that on, always on. I guess it is just a utility to switch to max performance when cable plugged in. And battery saver when cable not plugged in. Like TLP. But works well with turbo boost.
Remember me telling I keep my laptop always plugged in? So is that a problem with auto cpu Freq? Like is it running at top speeds on idle usage? With a very minimal and optimized xfce install, I see 1% usage of cpu with some crazy hot keyboard surface temperatures and quite strong fan noises. I have seen the guide on optimising laptop for Garuda. Like I removed game mode and worked on optimus manager as given on the guide on this forum. Could you suggest me any tips to reduce heating further with least possible hit on performance? Is the on-demand governer from cpupower-gui recommended? I am not very knowledgeable about temperature management on Linux.
Also I have disabled performance tweaks and checked powersave tips. Also can powertop auto-tune help in reducing temps? I also have preload installed. I remember things were way worse with the older custom kernels. Things have gotten much better. But still my laptop is running hot like if compiling kernel when ideal on power. I have earlier used pop os with nvidia only mode, Manjaro, and many others but never had such a problem before. Seems some bad power configuration on my system that is running max performance governor unnecessarily on ideal and plugged in state. How can I solve it?
System: Kernel: 5.10.34-1-lts x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: Xfce 4.16.0 tk: Gtk 3.24.24
info: xfce4-panel, plank, vala-panel wm: xfwm4 vt: 7 dm: LightDM 1.30.0 Distro: Garuda Linux base: Arch Linux
Machine: Type: Laptop System: ASUSTeK product: ROG Strix G731GT_G731GT v: 1.0 serial: <filter>
Mobo: ASUSTeK model: G731GT v: 1.0 serial: <filter> UEFI: American Megatrends v: G731GT.307 date: 04/28/2020
Battery: ID-1: BAT0 charge: 39.8 Wh (100.0%) condition: 39.8/50.5 Wh (78.8%) volts: 12.5 min: 12.5
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Not charging
Device-1: hidpp_battery_0 model: Logitech M350 Wireless Mouse serial: <filter> charge: 100% (should be ignored)
rechargeable: yes status: Discharging
CPU: Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Kaby Lake note: check rev: D cache: L2: 12 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 62399
Speed: 894 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 894 2: 900 3: 894 4: 899 5: 900 6: 900 7: 881 8: 892
9: 900 10: 900 11: 900 12: 900
Graphics: Device-1: Intel UHD Graphics 630 vendor: ASUSTeK driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK driver: nvidia v: 465.27 bus-ID: 01:00.0
chip-ID: 10de:1f91 class-ID: 0300
Display: x11 server: X.Org 1.20.11 driver: loaded: modesetting,nvidia resolution: 1920x1080 s-dpi: 96
OpenGL: renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2 v: 4.6.0 NVIDIA 465.27 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.10.34-1-lts running: yes
Sound Server-4: PipeWire v: 0.3.27 running: yes
Network: Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel port: 5000 bus-ID: 00:14.3
chip-ID: 8086:a370 class-ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169 v: kernel port: 3000
bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth: Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB driver: btusb v: 0.8 bus-ID: 1-14:4
Drives: Local Storage: total: 476.94 GiB used: 18.06 GiB (3.8%)
ID-1: /dev/nvme0n1 vendor: Micron model: 2200V MTFDHBA512TCK size: 476.94 GiB speed: 31.6 Gb/s lanes: 4
rotation: SSD serial: <filter> rev: P1MA0V4 temp: 41.9 C scheme: GPT
Partition: ID-1: / size: 459.65 GiB used: 18.05 GiB (3.9%) fs: btrfs dev: /dev/dm-0
mapped: luks-61943d89-e377-44ac-8a75-b8b776b2a841
ID-2: /boot/efi size: 252 MiB used: 682 KiB (0.3%) fs: vfat dev: /dev/nvme0n1p1
ID-3: /home size: 459.65 GiB used: 18.05 GiB (3.9%) fs: btrfs dev: /dev/dm-0
ID-4: /var/log size: 459.65 GiB used: 18.05 GiB (3.9%) fs: btrfs dev: /dev/dm-0
ID-5: /var/tmp size: 459.65 GiB used: 18.05 GiB (3.9%) fs: btrfs dev: /dev/dm-0
Swap: ID-1: swap-1 type: partition size: 17.03 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/dm-1
mapped: luks-0a3d92e7-e950-47a5-acdf-c8b9f11112a4
ID-2: swap-2 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-3: swap-3 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-4: swap-4 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-5: swap-5 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-6: swap-6 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-7: swap-7 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-8: swap-8 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-9: swap-9 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram7
ID-10: swap-10 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram8
ID-11: swap-11 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram9
ID-12: swap-12 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram10
ID-13: swap-13 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram11
Sensors: System Temperatures: cpu: 59.0 C mobo: N/A gpu: nvidia temp: 53 C
Fan Speeds (RPM): cpu: 4300
Info: Processes: 326 Uptime: 34m wakeups: 5 Memory: 15.49 GiB used: 2 GiB (12.9%) Init: systemd v: 248 Compilers:
gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1313 Shell: fish v: 3.2.1 running-in: alacritty inxi: 3.3.04
