Need help with steam please
Hello, i noticed that downloading game on steam is really slow on linux, and i found why its so.
https://www.reddit.com/r/linux_gaming/comments/16e1l4h/slow_steam_downloads_try_this/?share_id=7gybXb1OgBt4K7glEk0MK&utm_content=2&utm_medium=android_app&utm_name=androidcss&utm_source=share&utm_term=1
i did this step and now i have full speed download.
problem is i dont know how to create a steam_dev.cfg on linux lol so i cant save this command @nClientDownloadEnableHTTP2PlatformLinux 0
is it possible that u guys can update steam launcher with this @nClientDownloadEnableHTTP2PlatformLinux 0 command build in?
that would be awsome! thanks
Please provide your
as per the forum template
Kernel: 6.9.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=25a8d5a9-d970-4e28-a2e5-627bf59c0c12 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.3 tk: Qt v: N/A info: frameworks v: 6.4.0
Type: Desktop System: Gigabyte product: X670E AORUS MASTER v: -CF
Mobo: Gigabyte model: X670E AORUS MASTER v: x.x
Megatrends LLC. v: F32a date: 07/05/2024
Info: model: AMD Ryzen 9 7900X3D bits: 64 type: MCP arch: Zen 4 gen: 5
Topology: cpus: 1x cores: 12 smt: <unsupported> cache: L1: 768 KiB
desc: d-12x32 KiB; i-12x32 KiB L2: 12 MiB desc: 12x1024 KiB L3: 128 MiB
desc: 1x32 MiB, 1x96 MiB
Speed (MHz): avg: 4673 high: 5116 min/max: 545/5660 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 4948 2: 3565 3: 4942
4: 3305 5: 4559 6: 4118 7: 5116 8: 5116 9: 5116 10: 5105 11: 5109 12: 5088
bogomips: 105599
Device-1: NVIDIA AD102 [GeForce RTX 4090] vendor: Micro-Star MSI
driver: nvidia v: 555.58.02 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none off: DP-3 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:2684 class-ID: 0300
alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: 0
Monitor-1: DP-3 res: 2560x1440 size: N/A modes: N/A
x11: drv: zink inactive: device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4090/PCIe/SSE2
memory: 23.43 GiB display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 11 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 4090 driver: nvidia v: 555.58.02
device-ID: 10de:2684 surfaces: xcb,xlib,wayland
Device-1: NVIDIA AD102 High Definition Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:22ba class-ID: 0403
Device-2: Logitech Yeti X driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 9-1.2:3
chip-ID: 046d:0aaf class-ID: 0300 serial: <filter>
Device-3: Creative Sound BlasterX G6
lanes: 1 mode: 2.0 bus-ID: 9-1.4:4 chip-ID: 041e:3256 class-ID: 0300
API: ALSA v: k6.9.10-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I225-V vendor: Gigabyte driver: igc v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 0d:00.0 chip-ID: 8086:15f3
IF: enp13s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 0e:00.0
IF: wlp14s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:4 chip-ID: 8087:0032
Report: btmgmt ID: hci0 rfk-id: 2 state: down bt-service: disabled
Local Storage: total: 10.92 TiB used: 119.73 GiB (1.1%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Kingston model: SFYRD2000G
lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK31.6 temp: 43.9 C
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Kingston model: SFYRDK4000G
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK31.6 temp: 41.9 C
ID-3: /dev/nvme2n1 maj-min: 259:2 vendor: Kingston model: SFYRD2000G
lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK31.6 temp: 40.9 C
ID-4: /dev/nvme3n1 maj-min: 259:0 vendor: Kingston model: SFYRDK4000G
lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK31.6 temp: 38.9 C
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 119.73 GiB (6.4%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:8
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:6
used: 119.73 GiB (6.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:8
ID-1: swap-1 type: zram size: 30.96 GiB used: 63 MiB (0.2%) priority: 100
System Temperatures: cpu: 60.4 C mobo: N/A
Memory: total: 32 GiB note: est. available: 30.96 GiB used: 6.52 GiB (21.0%)
Processes: 456 Power: uptime: 1h 5m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.34 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1817 libs: 532 tools: octopi,paru Compilers:
clang: 18.1.8 gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date:     2024-07-20
Last full system update: 2024-07-20
Failed units:`Preformatted text`
ok that’s an easy one.
Just run this command in a console
echo "@nClientDownloadEnableHTTP2PlatformLinux 0" > ~/.steam/steam/steam_dev.cfg
Never had this problem with linux. On the contrary, it is not uncommon for steam to completely exhaust my Gbit line.
