Need help with Bluetooth headphones connectivity and audio issues
Hello everyone,
I hope you're doing well. I'm currently facing a problem with my Bluetooth headphones on my system, and I'm seeking some assistance and advice to resolve it.
The issue I'm experiencing is that my headphones frequently connect and disconnect on their own. When they do manage to connect, the audio playback is extremely laggy and stuttering. Furthermore, there are instances where the music cuts out intermittently and then resumes after a brief pause.
I have tried various troubleshooting steps, including:
  1. Verifying the Bluetooth connection settings on my system and ensuring that the headphones are properly paired.
  2. Updating the operating system and Bluetooth drivers to the latest versions available.
  3. Checking for any physical obstructions or distance-related issues between the headphones and my device.
  4. Testing the headphones with other devices to determine if the problem is specific to my system.
Despite my efforts, the problem persists, and I'm unable to enjoy a seamless audio experience with my headphones.
Here is my garuda-inxi output
  Kernel: 6.4.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=cfcee247-0e8a-49bb-95e1-c02da1962224 rw rootflags=subvol=@
    quiet splash loglevel=0 quiet quiet rd.udev.log_priority=3
    vt.global_cursor_default=0 loglevel=3 ibt=off
  Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_x11 dm: SDDM
  Type: Laptop System: ASUSTeK product: ASUS TUF Gaming F15 FX506LHB_FX506LHB
    v: 1.0 serial: <filter>
  Mobo: ASUSTeK model: FX506LHB v: 1.0 serial: <filter>
    UEFI: American Megatrends v: FX506LHB.311 date: 02/09/2022
  ID-1: BAT1 charge: 37.4 Wh (82.7%) condition: 45.2/48.1 Wh (94.1%)
    volts: 12.3 min: 11.7 model: ASUS A32-K55 type: Li-ion serial: N/A
    status: not charging
  Info: model: Intel Core i5-10300H socket: U3E1 bits: 64 type: MT MCP
    arch: Comet Lake gen: core 10 level: v3 note: check built: 2020
    process: Intel 14nm family: 6 model-id: 0xA5 (165) stepping: 2
    microcode: 0xF6
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 2142 high: 4040 min/max: 800/4500 base/boost: 2376/8300
    ext-clock: 100 MHz cores: 1: 2143 2: 952 3: 3141 4: 1187 5: 4040 6: 3667
    7: 1177 8: 835 bogomips: 39999
  Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: ASUSTeK driver: i915
    active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
  Device-2: NVIDIA TU117M vendor: ASUSTeK driver: nvidia v: 535.54.03
    alternate: nouveau,nvidia_drm non-free: 530.xx+
    status: current (as of 2023-05) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
    chip-ID: 10de:1f99 class-ID: 0300
  Device-3: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:3 chip-ID: 322e:202c
    class-ID: 0e02
  Display: server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x1521 built: 2020 res: 1920x1080
    hz: 144 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
    ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 23.1.3 renderer: Mesa Intel UHD Graphics (CML GT2)
    direct-render: Yes
  Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
    gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s
  API: ALSA v: k6.4.2-zen1-1-zen status: kernel-api tools: N/A
  Server-1: PipeWire v: 0.3.72 status: n/a (root, process) with:
  Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
    lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-14:4
    chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
  Local Storage: total: 476.94 GiB used: 53.69 GiB (11.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNU512GZ
    lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 32.9 C scheme: GPT
  SMART: yes health: PASSED on: 55d 15h cycles: 523
    read-units: 23,195,127 [11.8 TB] written-units: 9,626,863 [4.92 TB]
  ID-1: / raw-size: 87.89 GiB size: 87.89 GiB (100.00%)
    used: 53.66 GiB (61.1%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p7
    maj-min: 259:7
    used: 29.9 MiB (11.7%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1
  ID-3: /home raw-size: 87.89 GiB size: 87.89 GiB (100.00%)
    maj-min: 259:7
  ID-4: /var/log raw-size: 87.89 GiB size: 87.89 GiB (100.00%)
    maj-min: 259:7
  ID-5: /var/tmp raw-size: 87.89 GiB size: 87.89 GiB (100.00%)
    maj-min: 259:7
  ID-1: swap-1 type: zram size: 7.6 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 57.0 C pch: 48.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 0
  Processes: 287 Uptime: 12m wakeups: 1 Memory: available: 7.6 GiB
  used: 4.97 GiB (65.4%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 1502
  pm: pacman pkgs: 1499 libs: 361 tools: octopi,pamac,paru pm: flatpak pkgs: 3
  inxi: 3.3.27
  System install date:     2023-05-06
  Last full system update: 2023-07-08
  Is partially upgraded:   Yes
  Windows dual boot:       Yes
To provide more context and assist in troubleshooting, I would like to share the steps to replicate the bug:
  1. Turn on the Bluetooth headphones and put them in pairing mode.
  2. On my system, navigate to the Bluetooth settings and scan for available devices.
  3. Select the Bluetooth headphones from the list of available devices and initiate the pairing process.
  4. Once the headphones are successfully paired, open a music or media player application.
  5. Play any audio file or stream music through an online platform.
  6. Observe the audio playback for any signs of connectivity issues, lag, stuttering, or intermittent cuts.
I would greatly appreciate it if anyone could offer some guidance or suggestions on how to resolve this issue. If you have encountered a similar problem in the past or have expertise in Bluetooth audio troubleshooting, your insights would be invaluable.
Please feel free to share any specific steps, configurations, or software adjustments that might help in resolving this problem. Any relevant information or resources would be highly appreciated.
Thank you all in advance for your time and assistance. I'm looking forward to your valuable input.
Best regards,
You will need to resolve your partially upgraded state before any worthwhile troubleshooting can happen. Try running garuda-update in the terminal, and paste any errors you encounter into the thread.
The Windows “fast startup” feature can impair certain resources–including the network card–while Windows is supposedly “off”. It must be disabled from Windows itself:
is because I was precisely installing and reinstalling all the Bluetooth modules to check for changes, but the last time I updated the system was yesterday
doesn’t make much sense because I don’t have any issues with the network card, it works perfectly.
I’m not sure if the Bluetooth adapter and the network card are related.
How did you do so? Did you use the command @BluishHumility asked you to run?
Whether you like it or not, fast startup can be a real buzzkill for Linux users. That has happened to me, personally. Best to disable it.
They may or may not be on the same board, but typically have to be enabled separately (on decent BIOS’).
@BluishHumility is trying to help you troubleshoot this. A lot of the time that may involve a step-by-step process of elimination, as you are aware. You’ve done a fairly intense workout yourself–he’s just adding to that.
