Hey there! I just received a update for discord and tried updating it through pacman -S discord
it said reinstalling discord and when i opened it back up it still says update needed
My terminal - 591lDEwe9j | SourceBin
I said I wasn't going to help you, but here I am helping you. So, please use the </> in a reply to post your terminal output.
Secondly, nothing there shows you still have a pending update, and you cut off whatever command you typed at the top.
It said it was up to date and reinstalled. What still shows an update? From what I see - it looks to me like you type pacman -S discord
If you wanna keep your grudge i am fine with it. cheers
I do have discord so shouldn't the repo be activated?
see your scource.bin seems you reinstall the latest software or am i wrong
To working computers. Cheers*
Like you haven't messed up your PC even once
But when i launch discord it says, "Hey it seems you are in luck a new update is available, version 0.0.15"
It was flagged out of date today. . . you can try one of the AUR packages if you want - discord-canary probably ismore up to date; albeit probably more problems. BUT, until the maintainer updates the Arch package, that's where you're at for now.
you can use Discord Canary | The Discord Wiki
there is version 123
or you use ptb versions but it can have more bugs
get the AUR version... i had the same problem but installed discord_arch_electron version from AUR and discord runs great again.
And less than 8 hours later, the main repo package is updated already.. . .
