Hi dear community
inxi -Faz
System: Kernel: 5.10.78-1-lts x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts root=UUID=86700a51-f7ab-443a-9348-cffe5258a13b rw
[email protected] quiet rd.udev.log_priority=3 vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1
loglevel=3 ipv6.disable_ipv6=1
Desktop: KDE Plasma 5.23.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Desktop Mobo: Gigabyte model: B550M DS3H v: x.x serial: <filter> UEFI: American Megatrends LLC. v: F13g
date: 03/25/2021
CPU: Info: 6-Core model: AMD Ryzen 5 PRO 4650G with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2 family: 17 (23)
model-id: 60 (96) stepping: 1 microcode: 8600106 cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 88636
Speed: 3582 MHz min/max: 1400/3700 MHz boost: enabled Core speeds (MHz): 1: 3582 2: 3857 3: 3951 4: 3515 5: 3471
6: 3645 7: 4149 8: 3665 9: 3953 10: 3985 11: 3963 12: 3798
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Renoir vendor: Gigabyte driver: amdgpu v: kernel bus-ID: 05:00.0
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: amdgpu,ati unloaded: modesetting
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2") s-diag: 1055mm (41.5")
Monitor-1: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 96 size: 510x287mm (20.1x11.3") diag: 585mm (23")
Monitor-2: HDMI-A-1 res: 1920x1080 hz: 60 dpi: 96 size: 510x287mm (20.1x11.3") diag: 585mm (23")
OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.10.78-1-lts LLVM 12.0.1) v: 4.6 Mesa 21.2.4 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] driver: snd_hda_intel v: kernel bus-ID: 05:00.1 chip-ID: 1002:1637
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
Device-3: GN Netcom Jabra SPEAK 410 type: USB driver: jabra,snd-usb-audio,usbhid bus-ID: 1-2:3 chip-ID: 0b0e:0410
Sound Server-1: ALSA v: k5.10.78-1-lts running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8168 v: 8.049.02-NAPI
modules: r8169 port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Drives: Local Storage: total: 232.89 GiB used: 14.96 GiB (6.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M8250G size: 232.89 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: S5Z42105 temp: 34.9 C scheme: GPT
Partition: ID-1: / raw-size: 232.63 GiB size: 232.63 GiB (100.00%) used: 14.96 GiB (6.4%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 562 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 232.63 GiB size: 232.63 GiB (100.00%) used: 14.96 GiB (6.4%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-4: /var/log raw-size: 232.63 GiB size: 232.63 GiB (100.00%) used: 14.96 GiB (6.4%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-5: /var/tmp raw-size: 232.63 GiB size: 232.63 GiB (100.00%) used: 14.96 GiB (6.4%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-1: swap-1 type: zram size: 7.22 GiB used: 134 MiB (1.8%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 31.0 C mobo: 16.8 C gpu: amdgpu temp: 27.0 C
Info: Processes: 301 Uptime: 38m wakeups: 0 Memory: 7.22 GiB used: 5.49 GiB (76.0%) Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1426 lib: 348 Shell: fish v: 3.3.1 running-in: konsole
inxi: 3.3.08
I need some help about firedragon :
- Every time i got some update i loose my theme and my language preference (i have to reconfig it, anytime)
- How i can stop firedragon to open favorite link in new tab ? I use middle click if i want to open in new tab
- How i can make thoes change permanent ?
I hope not have forgotten any information
Best regards.
