I recently installed Garuda Linux, and I am installing a 2D plotting package called grace from the AUR packages. I cloned the files and tried to install it with makepkg -si, but the installation was terminated with errors (see the screenshot below through the attached link).
Try
sudo pamac install grace
It is a shortcut to install any AUR package.
Why can't you just paste the text output?
This is a build issue caused by Arch's default CFLAGs. Please report to the AUR package maintainer. This is not a Garuda-specific issue.
