Need help how to underclocking or limit my CPU
As the title said, I need to under clock/limit my CPU work which normally at 100% into 95%. How to do it on Garuda Linux? I was reading on ArchWiki and i got cpulimit. But i need input from Garuda Linux users or best from the Garuda team devs.
Then that is your answer.
Ok then :relaxed:
What is PID btw?
Normally refers to "Process Identifier".
where can i find/see the PID of the program that i wan to limit the CPU work?
Rather than answer a series of questions about how to use Linux, I'll point you towards a web search engine:
https://searx.garudalinux.org/search?q=linux%20see%20pid&categories=general&language=en-US
Thanks. Sorry, I'm still newbie at Linux :laughing: :pray:
Horray. Finally i learn how to release my gameplay from stuttering.
From what i learn in this forum on other thread, i just need to "disable auto cpu frequency" with "sudo systemctl disable --now auto-cpufreq"
or
much easier way because of the cool feature from Garuda Linux is,
just go to Garuda Welcome>Garuda Assistant>settings tab>turn off the two "auto cpufreq".
I'm not regret at all clean install my SSD into Garuda Linux and throw away Windows 10 from my PC :grin:
