Hi there community. I am here to ask for your help to figure the problem why i can't unpin a folder from latte dock. I have the unpin/pin option for software but for folder i don't have that option. Actually the folder pin inside the dock accidentally.
And my another question is if i wanted to change a software icon inside the latte dock what should i do?
It probably isn’t pinned but actually added to the dock. Right click on the dock and go to edit settings and then hover over it and an icon to remove it should appear.
Right-click on the launcher icon and select edit applications. You can change the icon from there.
If and only if it is added in applications folder too. If you will create .desktop in home folder, (or say, at desktop) it won’t get entry to other system utilities, like menu or “open with” dialog box.
But you can still pin it to dock or panels, just like files can be pinned.
