System: Kernel: 5.15.5-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=da559862-c45f-4717-93ae-279bef9b18b8
Desktop: Cinnamon 5.0.7 tk: GTK 3.24.30 wm: muffin vt: 7 dm: LightDM 1.30.0
Machine: Type: Desktop Mobo: WIPRO model: H61H2-M4 v: 1.0 serial: <superuser required>
BIOS: American Megatrends v: 4.6.5 date: 06/20/2013
CPU: Info: Dual Core model: Intel Pentium G2020 bits: 64 type: MCP arch: Ivy Bridge family: 6
model-id: 3A (58) stepping: 9 microcode: 21 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 11574
Speed: 2081 MHz min/max: 1600/2900 MHz Core speeds (MHz): 1: 2754 2: 2595
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Graphics: Device-1: Intel Xeon E3-1200 v2/3rd Gen Core processor Graphics vendor: Elite Systems
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0152 class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 driver: loaded: intel unloaded: modesetting
Screen-1: 0 s-res: 1360x768 s-dpi: 96 s-size: 359x203mm (14.1x8.0") s-diag: 412mm (16.2")
Monitor-1: VGA1 res: 1360x768 hz: 60 dpi: 49 size: 700x390mm (27.6x15.4") diag: 801mm (31.5")
Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio vendor: Elite Systems
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20 class-ID: 0403
Sound Server-1: ALSA v: k5.15.5-zen1-1-zen running: yes
Network: Device-1: Qualcomm Atheros AR8161 Gigabit Ethernet vendor: Elite Systems driver: alx v: kernel
port: e000 bus-ID: 02:00.0 chip-ID: 1969:1091 class-ID: 0200
Drives: Local Storage: total: 718.18 GiB used: 13.58 GiB (1.9%)
ID-1: /dev/sda maj-min: 8:0 type: USB vendor: Kingston model: DataTraveler 3.0 size: 28.85 GiB
block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: PMAP
scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD5000AAKX-60U6AA0 size: 465.76 GiB
block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1H18 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WDS240G2G0A-00JH30 size: 223.57 GiB
block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s type: SSD serial: <filter> rev: 0400
scheme: MBR
Partition: ID-1: / raw-size: 48.83 GiB size: 48.83 GiB (100.00%) used: 10.99 GiB (22.5%) fs: btrfs
dev: /dev/sdc1 maj-min: 8:33
ID-2: /home raw-size: 48.83 GiB size: 48.83 GiB (100.00%) used: 10.99 GiB (22.5%) fs: btrfs
ID-3: /var/log raw-size: 48.83 GiB size: 48.83 GiB (100.00%) used: 10.99 GiB (22.5%) fs: btrfs
ID-4: /var/tmp raw-size: 48.83 GiB size: 48.83 GiB (100.00%) used: 10.99 GiB (22.5%) fs: btrfs
ID-1: swap-1 type: zram size: 3.72 GiB used: 33 MiB (0.9%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 29.8 C mobo: 27.8 C
Info: Processes: 193 Uptime: 2h 33m wakeups: 0 Memory: 3.72 GiB used: 2.09 GiB (56.4%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1201 lib: 303
Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.09
New Laptop's Inxi
✦ ╰─λ inxi -Faz
Kernel: 5.15.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=e99e1554-282d-482c-af98-1b2c5cb9c3d5 rw rootflags=subvol=@
resume=UUID=52c4c4e3-15a4-4169-a025-60eb990956f7 loglevel=3
Desktop: Cinnamon 5.0.7 tk: GTK 3.24.31 wm: muffin vt: 7
dm: LightDM 1.30.0 Distro: Garuda Linux base: Arch Linux
Type: Laptop System: HP product: OMEN Laptop 15-en1xxx v: N/A
Mobo: HP model: 88D1 v: 75.31 serial: <superuser required> UEFI: AMI
v: F.06 date: 05/05/2021
ID-1: BAT0 charge: 19.2 Wh (27.7%) condition: 69.4/69.4 Wh (100.0%)
volts: 12.1 min: 11.6 model: HP Primary type: Li-ion serial: <filter>
status: Charging cycles: 3
arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000B
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2913 high: 4275 min/max: 1200/3200 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2645 2: 3120
3: 4275 4: 2514 5: 2235 6: 3549 7: 2948 8: 2592 9: 2189 10: 2395 11: 2871
12: 3057 13: 2912 14: 2874 15: 3045 16: 3401 bogomips: 102206
IBRS_FW, STIBP: always-on, RSB filling
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
vendor: Hewlett-Packard driver: nvidia v: 495.46
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:2520
Device-2: AMD Cezanne vendor: Hewlett-Packard driver: amdgpu v: kernel
bus-ID: 06:00.0 chip-ID: 1002:1638 class-ID: 0300
Device-3: Quanta HP Wide Vision HD Camera type: USB driver: uvcvideo
bus-ID: 1-3:2 chip-ID: 0408:5425 class-ID: fe01 serial: <filter>
Display: x11 server: X.Org 1.21.1.2 driver: loaded: modesetting,nvidia
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 144 dpi: 142
size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
Device-1: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Hewlett-Packard driver: snd_rn_pci_acp3x v: kernel
alternate: snd_pci_acp3x,snd_pci_acp5x bus-ID: 06:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 06:00.6 chip-ID: 1022:15e3
Sound Server-1: ALSA v: k5.15.12-zen1-1-zen running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel port: e000 bus-ID: 02:00.0
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 03:00.0
chip-ID: 8086:2723 class-ID: 0280
bus-ID: 1-4:3 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 953.87 GiB used: 9.47 GiB (1.0%)
model: MZVLB1T0HBLR-000H1 size: 953.87 GiB block-size: physical: 512 B
rev: HPS0NEXF temp: 30.9 C scheme: GPT
ID-1: / raw-size: 75.2 GiB size: 75.2 GiB (100.00%) used: 9.47 GiB (12.6%)
ID-2: /boot/efi raw-size: 883 MiB size: 881.3 MiB (99.80%)
used: 580 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p7 maj-min: 259:7
ID-3: /home raw-size: 75.2 GiB size: 75.2 GiB (100.00%)
used: 9.47 GiB (12.6%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-4: /var/log raw-size: 75.2 GiB size: 75.2 GiB (100.00%)
ID-5: /var/tmp raw-size: 75.2 GiB size: 75.2 GiB (100.00%)
ID-1: swap-1 type: partition size: 17.58 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: swap-2 type: zram size: 15.06 GiB used: 2.5 MiB (0.0%)
System Temperatures: cpu: 47.0 C mobo: N/A gpu: amdgpu temp: 43.0 C
Processes: 394 Uptime: 26m wakeups: 2 Memory: 15.06 GiB
used: 3.46 GiB (23.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1265 lib: 311 Shell: Zsh v: 5.8
running-in: gnome-terminal inxi: 3.3.11
