N00b question about dr460nized more qestions
Hello Garuda users.
ok as requested, here would have been the output thing from garuda-inxi, but I apparently cannot upload a text document, so not sure how to do that.
After suggestions from others, I now have this working on hardware. For the avoidance of confusion, this is Garuda Dr460nized KDE.
I jumped through a few hoops to get it working and look as I want, so all good.
Couple of minor things left, which I shall guess are down to the apps, not the OS. Obviously, any assistance would be welcome :slight_smile:
  1. In Brave (don't hate me) it usurps the system title bar by default. I have to go into Brave settings, then un-tick that, then re-enable the same tick-box, then it works as it should.
  2. I have custom windows 'decorations' set so the buttons in the title-bar are more easily recognisable to me. All apps respect that except Thunderbird which insists on using the Dr460nized default decorations. Maybe it's a flatpak or something? No idea.
For the garuda-inxi there's no text file required, it's a simple copy-paste of the output from Terminal/Konsole.
For 1-, which package manager did you use to install it? Flatpak, snap, appimage, pacman, etc...
For 2-, well if you installed Thunderbird from a flatpak package, you're basically screwed. Flatpaks, snaps and appimages, pretty much all don't respect something from the UI, they are not intended to specifically use all UI you want, but rather what the packager packaged in the package. Not all UI, but some of it cannot be accessed by the package. Maybe it works fine for some apps, but many don't respect the Theme 100%.
If there is no important reason to install it from flatpak, I highly suggest you trash it and install the Arch package (paru -S thunderbird-bin) v115.1.1.
Or use garuda-assistant, Systeminfos.
Okay, first thanks to those who helped thus far!
Last remaining thing right now. All the 'window decorations' in every window are themed for the Dragon except Brave, which insists on its own decorations. I want it 'perfect'! Maybe it's coming in as some kind of flatpak or other pre-built thing that doesn't see local preferences...?
Below is the full output of the diag thing so that I don't get shouted at :slight_smile:
  Kernel: 6.4.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=71b1e62c-d654-48c1-af1e-8a223d06b2c3 rw rootflags=subvol=@
    rd.luks.uuid=e8a6fb96-5032-479b-879e-a2ebb6d0796e rd.udev.log_priority=3
    vt.global_cursor_default=0
    rd.luks.uuid=ce206e64-4908-4ef3-8ddc-5036de2f084a
    resume=/dev/mapper/luks-ce206e64-4908-4ef3-8ddc-5036de2f084a loglevel=3
  Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 wm: kwin_x11 dm: SDDM
  Type: Laptop System: HP product: HP EliteBook 840 G3 v: N/A serial: <filter>
    Chassis: type: 10 serial: <filter>
  Mobo: HP model: 8079 v: KBC Version 85.77 serial: <filter> UEFI: HP
    v: N75 Ver. 01.18 date: 10/17/2017
  ID-1: BAT0 charge: 40.8 Wh (99.0%) condition: 41.2/41.2 Wh (100.0%)
    volts: 12.8 min: 11.4 model: Hewlett-Packard Primary type: Li-ion
  Info: model: Intel Core i7-6600U socket: U3E1 bits: 64 type: MT MCP
    arch: Skylake gen: core 6 level: v3 note: check built: 2015
    process: Intel 14nm family: 6 model-id: 0x4E (78) stepping: 3
    microcode: 0xF0
    L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 822 high: 888 min/max: 400/3400 base/boost: 2600/8300
    scaling: driver: intel_pstate governor: powersave volts: 1.0 V
    ext-clock: 100 MHz cores: 1: 800 2: 888 3: 800 4: 800 bogomips: 22399
  Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Hewlett-Packard
    EliteBook 840 G3 driver: i915 v: kernel arch: Gen-9 process: Intel 14n
    built: 2015-16 ports: active: DP-1 off: eDP-1
    empty: DP-2,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1916
  Device-2: Lite-On HP HD Webcam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9:5 chip-ID: 04ca:7054
  Display: server: X.Org v: 21.1.8 with: Xwayland v: 23.2.0
  Monitor-1: DP-1 pos: primary model: HP E24 G4 serial: <filter> built: 2022
    res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65")
    diag: 604mm (23.8") ratio: 16:9 modes: max: 1920x1080 min: 720x400
  Monitor-2: eDP-1 note: disabled model: LG Display 0x04f3 built: 2014
    res: 1920x1080 dpi: 210 gamma: 1.2 size: 310x174mm (12.2x6.85")
    diag: 355mm (14") ratio: 16:9 modes: 2560x1440
  API: OpenGL v: 4.6 Mesa 23.1.6 renderer: Mesa Intel HD Graphics 520 (SKL
    GT2) direct-render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard EliteBook
    840 G3 driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_soc_avs
    bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
  Device-2: HP USB Audio driver: hid-generic,snd-usb-audio,usbhid type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5.2.2:6
    chip-ID: 03f0:056b class-ID: 0300 serial: <filter>
  API: ALSA v: k6.4.12-zen1-1-zen status: kernel-api tools: N/A
  Server-1: PipeWire v: 0.3.78 status: n/a (root, process) with:
  Device-1: Intel Ethernet I219-LM vendor: Hewlett-Packard EliteBook 840 G3
    driver: e1000e v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:156f
  Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24f3 class-ID: 0280
    rev: 3.2 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-5.2.4:6
  IF: enp0s20f0u5u2u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:3 chip-ID: 8087:0a2b
  Local Storage: total: 1.38 TiB used: 662.39 GiB (47.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SD8SN8U-512G-1006
    family: Marvell based SSDs size: 476.94 GiB block-size: physical: 4096 B
    logical: 512 B sata: 3.2 speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 0006 temp: 41 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 1y 241d 0h cycles: 879
  ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: PSSD T7
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
    fw-rev: FXG42P2Q temp: 32 Celsius C
  SMART: yes health: PASSED on: 345d 6h cycles: 981
    read-units: 11,433,233 [5.85 TB] written-units: 8,939,291 [4.57 TB]
  ID-1: / raw-size: 442.28 GiB size: 442.28 GiB (100.00%)
    used: 15.95 GiB (3.6%) fs: btrfs block-size: 4096 B dev: /dev/dm-1
    maj-min: 254:1 mapped: luks-e8a6fb96-5032-479b-879e-a2ebb6d0796e
    used: 720 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 442.28 GiB size: 442.28 GiB (100.00%)
  ID-4: /var/log raw-size: 442.28 GiB size: 442.28 GiB (100.00%)
  ID-5: /var/tmp raw-size: 442.28 GiB size: 442.28 GiB (100.00%)
  ID-1: swap-1 type: partition size: 34.35 GiB used: 0 KiB (0.0%)
    mapped: luks-ce206e64-4908-4ef3-8ddc-5036de2f084a
  ID-2: swap-2 type: zram size: 31.23 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 43.0 C pch: 37.5 C mobo: N/A
  Processes: 242 Uptime: 2h 23m wakeups: 3 Memory: total: 32 GiB
  available: 31.23 GiB used: 4.13 GiB (13.2%) igpu: 32 MiB Init: systemd
  v: 254 default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages:
  pm: pacman pkgs: 1360 libs: 375 tools: octopi,paru Shell: garuda-inxi (sudo)
  default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.29
  System install date:     2023-08-28
  Last full system update: 2023-08-28
Bugger. Updating to say that now with Firefox (or strictly speaking, Garuda's version here which is "FireDragon"), I still lose the system title-bar on maximise so have no window decorations at all, unless I manually drag it down off the top - then I get a 'normal' un-maximised window with decorations as they should be.
Maybe it's just bloody browsers that don't stick to the rules?!
For Brave, can you copy the output of paru -Ss brave.
I have an application that lose the Menu Bar (not Title Bar in my case) on maximize and I never found why or how to bring it back. These issues are typical on Plasma when you use GTK-based applications, like Inkscape, Firefox-based, Remmina, Brave... there are a lot unfortunately.
If you open up ~/.config/kwinrc file and look for section [Windows], you could set the following BorderlessMaximizedWindows=false. I suggest to logout and relogin after that change, it will apply to all windows of all apps.
If that does not bring back the Title Bar I think there are other things to look for which I don't remember at the moment.
BRAVE
Well I decided to be brave and try out Brave. :smiley: I found something. IF your GTK Theme settings are set right on your system globally, then go in Brave Settings and click on Use GTK.
It will change from this:
To this:
Even if your GTK settings aren't set right, try it out anyway.
Curiously, Use QT does not use the Dr460nized Window Decorations.
You absolute star - that works perfectly!
