My spacebar is notworking
╭─batman@vitcus in ~
╰─λ garuda-inxi
Kernel: 6.8.7-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=744736bd-ab80-41dd-ade6-eb0f243d02ce rw rootflags=subvol=@
Type: Laptop System: HP product: Victus by HP Gaming Laptop 15-fb1xxx v: N/A
Mobo: HP model: 8C30 v: 88.14 serial: <superuser required>
part-nu: 8L083PA#ACJ uuid: <superuser required> UEFI: AMI v: F.03
date: 08/10/2023
ID-1: BAT0 charge: 41.8 Wh (84.8%) condition: 49.3/49.3 Wh (100.0%)
power: 30.0 W volts: 11.9 min: 11.6 model: HP Primary type: Li-ion
serial: <filter> status: discharging cycles: 99
Info: model: AMD Ryzen 5 7535HS with Radeon Graphics bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404102
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1675 high: 2395 min/max: 400/4603 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1915 2: 1895 3: 1381
4: 1368 5: 2395 6: 1991 7: 1413 8: 1402 9: 1860 10: 1722 11: 1397 12: 1368
bogomips: 79044
Device-1: NVIDIA GA107 [GeForce RTX 2050] vendor: Hewlett-Packard
driver: nvidia v: 550.76 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-04; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 4 speed: 16 GT/s
lanes: 8 link-max: lanes: 16 ports: active: none empty: HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:25ad class-ID: 0300
Device-2: AMD Rembrandt [Radeon 680M] vendor: Hewlett-Packard
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1
empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, DP-8, Writeback-1
bus-ID: 06:00.0 chip-ID: 1002:1681 class-ID: 0300 temp: 53.0 C
Device-3: Chicony HP Wide Vision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 04f2:b766
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x094d built: 2020
res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
surfaceless: drv: nvidia x11: drv: radeonsi inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.0.5-arch1.1
rembrandt LLVM 17.0.6 DRM 3.57 6.8.7-zen1-2-zen) device-ID: 1002:1681
memory: 500 MiB unified: no
API: Vulkan v: 1.3.279 layers: 14 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV REMBRANDT) driver: mesa radv v: 24.0.5-arch1.1
device-ID: 1002:1681 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 2050 driver: nvidia v: 550.76
device-ID: 10de:25ad surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.5-arch1.1 (LLVM
Device-1: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:2291 class-ID: 0403
Device-2: AMD Rembrandt Radeon High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 06:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
snd_sof_amd_acp63 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 06:00.5
Device-4: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.8.7-zen1-2-zen status: kernel-api with: aoss
vendor: AzureWave driver: mt7921e v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 link-max: gen: 2 speed: 5 GT/s bus-ID: 03:00.0 chip-ID: 14c3:7961
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 13d3:3567
Local Storage: total: 476.94 GiB used: 17.66 GiB (3.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
SN810 SDCPNRY-512G-1006 size: 476.94 GiB block-size: physical: 512 B
fw-rev: HPS2 temp: 44.9 C scheme: GPT
used: 17.66 GiB (3.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 6.97 GiB used: 1.42 GiB (20.3%)
System Temperatures: cpu: 55.1 C mobo: 50.0 C gpu: amdgpu temp: 53.0 C
Fan Speeds (rpm): fan-1: 2702 fan-2: 0
Memory: total: 8 GiB note: est. available: 6.97 GiB used: 5.18 GiB (74.4%)
Processes: 423 Power: uptime: 26m states: freeze,mem,disk suspend: s2idle
image: 2.75 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 255 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1845 libs: 542 tools: octopi,paru Compilers:
clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date:     2024-08-25
Last full system update: 2024-08-25
Is partially upgraded:   Yes
first of all update your system properly (I hope you will be able to do it without space :eyes: )
If this problem has happened after an update then you can go back to your previous working snapshot from boot menu itself and check in which snapshot your space bar is working then restore that one
Worst case if your password has a space in it you can copy/paste a space from anywhere and it should work. I have had to do this once before a long time ago.
Or use onboard :slight_smile:
BTW, write normal text, please, the search function can’t work with
" My+spacebar+isnotworkingplsineedhelp"
You can also test your space bar online later, to check for a HW issue.
For example:
https://keyboard-tester.com
