acce
April 1, 2022, 5:06pm
1
i was going to play a game on lutris (the game was on my second drive) and wine, the game had just black screen and i rebooted my computer then my second drive was broken, when i try to acces the drive it says:
An error occurred while accessing 'Uusi asema', the system responded: The requested operation has failed: Error mounting /dev/sda2 at /run/media/acce/Uusi asema: wrong fs type, bad option, bad superblock on /dev/sda2, missing codepage or helper program, or other error.
pls help me
please post your garuda-inxi
acce
April 1, 2022, 5:25pm
3
Dragonized Gaming Edition, and when i do neofetch its showing up as
Garuda Linux
acce
April 1, 2022, 5:27pm
4
and the kde version is 5,24.4
tbg
April 1, 2022, 5:43pm
5
There have been a number of posts about this recently. The most likely reason for the error is because you are using an NTFS drive. Read the relevant posts from a forum search on your error terms:
https://forum.garudalinux.org/search?context=topic&context_id=18557&q=wrong%20fs%20type%2C%20bad%20option%2C%20bad%20superblock%20&skip_context=true
The garuda-inxi
command output must be posted to receive assistance on technical help requests on our forum. Failure to do so will result in your post being binned for non-compliance with forum policy.
Edit:
Please post the outputs of the following commands:
sudo blkid -o list
cat /etc/fstab
acce
April 1, 2022, 6:14pm
6
system: inixi
root=UUID=65dc40bd-0ec6-4747-9a2e-0c5a6f63ed2f rw rootflags=subvol=@
Type: Desktop System: ASUSTeK product: GR8 II v: 0401
Mobo: ASUSTeK model: GR8 II-K v: Rev 1.xx serial: <superuser required>
UEFI: American Megatrends v: 0401 date: 01/20/2017
Info: model: Intel Core i5-7400 bits: 64 type: MCP arch: Kaby Lake
family: 6 model-id: 0x9E (158) stepping: 9 microcode: 0xEC
desc: 1x6 MiB
Speed (MHz): avg: 3319 high: 3342 min/max: 800/3500 scaling:
driver: intel_pstate governor: performance cores: 1: 3283 2: 3325 3: 3342
4: 3329 bogomips: 24000
Type: l1tf
STIBP: disabled, RSB filling
Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: ASUSTeK
driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1c02 class-ID: 0300
loaded: nvidia unloaded: modesetting,nouveau alternate: fbdev,nv,vesa
gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 3600x1080 s-dpi: 92 s-size: 994x301mm (39.13x11.85")
s-diag: 1039mm (40.89")
Monitor-1: HDMI-0 pos: primary,left res: 1920x1080 hz: 60 dpi: 92
size: 532x304mm (20.94x11.97") diag: 613mm (24.12") modes: N/A
Monitor-2: HDMI-1 pos: right res: 1680x1050 hz: 60 dpi: 90
size: 474x296mm (18.66x11.65") diag: 559mm (22") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1060 3GB/PCIe/SSE2
v: 4.6.0 NVIDIA 510.54 direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
Device-2: NVIDIA GP106 High Definition Audio vendor: ASUSTeK
bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:24f3 class-ID: 0280
bus-ID: 1-6:5 chip-ID: 8087:0a2b class-ID: e001
Local Storage: total: 2.05 TiB used: 43.14 GiB (2.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M8250G
size: 232.89 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: S5Z42105
temp: 45.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LM015-2E8174
type: HDD rpm: 5400 serial: <filter> rev: 0001 scheme: GPT
used: 43.06 GiB (18.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 498 MiB size: 497 MiB (99.79%)
used: 82.5 MiB (16.6%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: zram size: 15.57 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 79.0 C pch: 69.5 C mobo: 27.8 C gpu: nvidia
temp: 58 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 24%
Processes: 245 Uptime: 1h 28m wakeups: 0 Memory: 15.57 GiB
used: 4.31 GiB (27.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: 1889 apt: 1 pacman: 1888 lib: 544 Shell: fish
v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.14
Garuda (2.5.6-2):
System install date: 2022-03-27
Last full system update: 2022-04-01
acce
April 1, 2022, 6:15pm
7
/dev/nvme0n1p2 btrfs (in use) 65dc40bd-0ec6-4747-9a2e-0c5a6f63ed2f
/dev/nvme0n1p1 vfat NO_LABEL /run/media/acce/NO_LABEL 7B77-569A
/dev/sda2 ntfs Uusi asema (not mounted) D02CE8772CE85A4C
/dev/sda1 vfat /boot/efi B522-6DE0
/dev/zram0 swap zram0 [SWAP]
Please in the future press the "</>" button so that your code is properly formatted like
garuda-inxi output
@acce create a directory such as /mnt/windows then try adding the following text to your /etc/fstab
UUID=7C1A71921A714A62 /mnt/windows ntfs-3g nofail,noatime,rw,user,uid=1000,gid=1000,dmask=022,fmask=133,windows_names,auto 0 0
Replace the UUID with what you get from the output of the following command for sda2.
sudo blkid -o list
Then install ntfs-3g package and say yes to removing the existing conflict. Then run
sudo mount -a
If no errors, then try rebooting and see if you can access your Windows drive via /mnt/windows or whatever you decide to name the folder.
acce
April 1, 2022, 7:31pm
10
it didint work yet, there is error : <$MFTMirr does not match $MFT (record 3).
Failed to mount '/dev/sda2': Input/output error
NTFS is either inconsistent, or there is a hardware fault, or it's a
SoftRAID/FakeRAID hardware. In the first case run chkdsk /f on Windows
then reboot into Windows twice. The usage of the /f parameter is very
important! If the device is a SoftRAID/FakeRAID then first activate
it and mount a different device under the /dev/mapper/ directory, (e.g.
/dev/mapper/nvidia_eahaabcc1). Please see the 'dmraid' documentation
for more details.>
tbg
April 1, 2022, 8:11pm
12
If you don't have Windows installed, you can try using the ntfs-fix
command. However, it is preferable to use Windows to correct errors with drives that are using a Windows file system.
The more relevant question might be, if you are not using Windows, why are you using a Windows file system with Linux? Best to ditch the NTFS file system if you are using Linux. Hopefully you have important data from this drive backed up and you can then format it to a Linux file system to put the issues that come from using a Windows file system behind you.
Open a terminal and type it?
acce
April 1, 2022, 8:20pm
15
it says find-the-command: command not found: ntfs-fix
Oops, I don't believe the hyphen should be included. Try this:
sudo ntfsfix /dev/sda2
acce
April 1, 2022, 9:22pm
17
i changed the format of the drive and deleted the
data
This is the best possible fix for an NTFS device.
Welcome to the community.
tbg
April 1, 2022, 9:48pm
19
Ya oops. I haven’t used NTFS in quite a while, so it appears I’m a little rusty on the command usage.
system
Closed
April 15, 2022, 9:48pm
20
