My mic and sound doesnt work
Hello.
just the title + btw icant update my sys
(1/6) Creating Timeshift snapshot before upgrade...
Using system disk as snapshot device for creating snapshots in BTRFS mode
/dev/sda1 is mounted at: /run/timeshift/backup, options: rw,relatime,compress=zstd:3,ssd,space_cache,autodefrag,subvolid=5,subvol=/
E: The system partition has an unsupported subvolume layout. Only ubuntu-type layouts with @ and @home subvolumes are currently supported.
Application will exit.
Unable to run timeshift-autosnap! Please close Timeshift and try again. Script will now exit...
The information you posted doesn't tell us anything about either of your problems, please edit your post to include inxi -Faz terminal output.
For your update issue it would be good to also have some context - has the system been updated successfully before? Have you used Timeshift to perform a system restore before this started showing?
System:    Kernel: 5.13.9-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
           parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=11a09b47-5533-4943-81ea-96d1477e672f rw
           [email protected] quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
           Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine:   Type: Laptop System: Dell product: Latitude E5440 v: 00 serial: <filter> Chassis: type: 9 serial: <filter>
           Mobo: Dell model: 08RCYC v: A00 serial: <filter> BIOS: Dell v: A14 date: 01/06/2016
Battery:   ID-1: BAT0 charge: 37.4 Wh (100.0%) condition: 37.4/65.5 Wh (57.0%) volts: 12.8 min: 11.1
           model: Samsung SDI DELL CXF6651 type: Li-ion serial: <filter> status: Full
CPU:       Info: Dual Core model: Intel Core i7-4600U bits: 64 type: MT MCP arch: Haswell family: 6 model-id: 45 (69)
           stepping: 1 microcode: 26 cache: L2: 4 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 21550
           Speed: 2694 MHz min/max: 800/3300 MHz Core speeds (MHz): 1: 2694 2: 2774 3: 2665 4: 2694
Graphics:  Device-1: Intel Haswell-ULT Integrated Graphics vendor: Dell driver: i915 v: kernel bus-ID: 00:02.0
           chip-ID: 8086:0a16 class-ID: 0300
           Device-2: NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT 620M/625M/630M/720M] vendor: Dell driver: N/A
           alternate: nouveau, nvidia_drm, nvidia bus-ID: 03:00.0 chip-ID: 10de:1140 class-ID: 0302
           Device-3: Microdia Laptop_Integrated_Webcam_HD type: USB driver: uvcvideo bus-ID: 1-1.6:3 chip-ID: 0c45:649d
           class-ID: 0e02
           Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: intel unloaded: modesetting
           Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 112 size: 310x170mm (12.2x6.7") diag: 354mm (13.9")
           OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2) v: 4.5 Mesa 21.1.6 compat-v: 3.0 direct render: Yes
Audio:     Device-1: Intel Haswell-ULT HD Audio vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 00:03.0
           chip-ID: 8086:0a0c class-ID: 0403
           Device-2: Intel 8 Series HD Audio vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20
           Sound Server-1: ALSA v: k5.13.9-zen1-1-zen running: yes
Network:   Device-1: Intel Ethernet I218-LM vendor: Dell driver: N/A modules: e1000e port: f080 bus-ID: 00:19.0
           chip-ID: 8086:155a class-ID: 0200
           Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel port: f040 bus-ID: 02:00.0 chip-ID: 8086:08b1
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-1.8.2:5 chip-ID: 8087:07dc
RAID:      Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0 port: f060 bus-ID: 00:1f.2
           chip-ID: 8086.282a rev: 04 class-ID: 0104
Drives:    Local Storage: total: 761.98 GiB used: 130.96 GiB (17.2%)
           ID-1: /dev/sda maj-min: 8:0 vendor: TwinMOS model: SSD size: 238.47 GiB block-size: physical: 512 B logical: 512 B
           speed: 6.0 Gb/s type: SSD serial: <filter> rev: 210a scheme: MBR
           ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST500VT000-1DK142 size: 465.76 GiB block-size: physical: 4096 B
           logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: SDC1 scheme: MBR
           ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Toshiba model: TransMemory size: 57.74 GiB block-size:
           physical: 512 B logical: 512 B type: N/A serial: <filter> rev: 1.00 scheme: MBR
Partition: ID-1: / raw-size: 238.47 GiB size: 238.47 GiB (100.00%) used: 48.18 GiB (20.2%) fs: btrfs dev: /dev/sda1
           maj-min: 8:1
           ID-2: /home raw-size: 465.76 GiB size: 465.76 GiB (100.00%) used: 51.95 GiB (11.2%) fs: btrfs dev: /dev/sdb1
           maj-min: 8:17
           ID-3: /var/log raw-size: 238.47 GiB size: 238.47 GiB (100.00%) used: 48.18 GiB (20.2%) fs: btrfs dev: /dev/sda1
           maj-min: 8:1
           ID-4: /var/tmp raw-size: 238.47 GiB size: 238.47 GiB (100.00%) used: 48.18 GiB (20.2%) fs: btrfs dev: /dev/sda1
           maj-min: 8:1
           ID-1: swap-1 type: zram size: 3.74 GiB used: 1.02 GiB (27.3%) priority: 100 dev: /dev/zram0
Sensors:   System Temperatures: cpu: 53.0 C mobo: 46.0 C sodimm: SODIMM C
           Fan Speeds (RPM): cpu: 3501
Info:      Processes: 274 Uptime: 1h 42m wakeups: 1 Memory: 3.74 GiB used: 2.91 GiB (77.7%) Init: systemd v: 249
           tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1436 lib: 370 Shell: fish v: 3.3.1
           running-in: konsole inxi: 3.3.06
and the system has upgraded once before + no i dont know for real
Seems you do not use Btrfs.
im using it .....
any ideas ?
sudo killall timeshift
And reboot, its KDE :slight_smile:
Maybe try updating with that no autosnap variable and see if the hooks/Timeshift update fix it.
For the audio - try:
  • Adding user to audio and realtime groups
  • Reinstalling pipewire-support
  • Replacing with pulseaudio-support
 ╰─λ sudo pacman -S pipewire-support
[sudo] password for radwan:
يحلّ الاعتماديّات...
يبحث عن الحزم المتضاربة...
الحزم (1) pipewire-support-1-5
:: مواصلة التثبيت؟ [Y/n] y
(1/1) يفحص المفاتيح في حلقة المفاتيح        [----------------------------------------------------------------------] 100%
(1/1) يفحص سلامة الحز        [----------------------------------------------------------------------] 100%
(1/1) يحمّل ملفّات الحزم        [----------------------------------------------------------------------] 100%
(1/1) يفحص تعارضات الملفّات        [----------------------------------------------------------------------] 100%
(1/1) يفحص مساحة القرص المتوفّرة        [----------------------------------------------------------------------] 100%
(1/1) Creating Timeshift snapshot before upgrade...
wow great
Well you'd have to run this with SKIP_AUTOSNAP=1 as well
Do you use right click on Speaker icon (volume control?)
traget is not detected
Some update possible?
what ? like right clicking the tray ico ?
how ? :neutral_face: :neutral_face: ..............
@zoeruda like its in arabic : didnt find the goal
Can you post exact text of both command and output please?
خطأ:لم يتم العثور على الهدف: SKIP_AUTOSNAP=1
SKIP_AUTOSNAP=1 should go before command
