My laptop running Garuda won’t Display to my Monitors
I have restarted my laptop and my monitors and I have used xrandr and several YouTube guides.
╰─λ garuda-inxi
root=UUID=c6fc7466-ceb8-4cd1-9531-a8539a97ee63 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Laptop System: ASUSTeK product: ROG Zephyrus M15 GU502LU_GU502LU
Mobo: ASUSTeK model: GU502LU v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: GU502LU.312 date: 04/06/2021
ID-1: BAT0 charge: 61.8 Wh (98.7%) condition: 62.6/76.0 Wh (82.4%)
status: not charging cycles: 128
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0xF8
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2536 high: 4601 min/max: 800/5000 scaling:
driver: intel_pstate governor: performance cores: 1: 4600 2: 1247 3: 800
4: 800 5: 1912 6: 800 7: 4599 8: 4601 9: 4600 10: 800 11: 4600 12: 1081
bogomips: 62399
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: ASUSTeK driver: i915
active: eDP-1 empty: none bus-ID: 0000:00:02.0 chip-ID: 8086:9bc4
Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: ASUSTeK
driver: nvidia v: 545.29.02 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2023-10; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 bus-ID: 0000:01:00.0
chip-ID: 10de:2191 class-ID: 0300
Monitor-1: eDP-1 res: 1536x864 size: N/A modes: N/A
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: nvidia
inactive: device-2
device-ID: 8086:9bc4 memory: 15.05 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.269 layers: 10 device: 0 type: integrated-gpu
name: Intel UHD Graphics (CML GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:9bc4 surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce GTX 1660 Ti driver: nvidia
v: 545.29.02 device-ID: 10de:2191 surfaces: xcb,xlib,wayland device: 2
type: cpu name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe
v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 0000:00:1f.3
Device-2: NVIDIA TU116 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:1aeb
API: ALSA v: k6.6.1-zen1-1-zen status: kernel-api with: aoss
bus-ID: 0000:00:14.3 chip-ID: 8086:06f0 class-ID: 0280
vendor: ASUSTeK driver: r8169 v: kernel port: 3000 bus-ID: 0000:3b:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 8087:0026
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.2
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c010c
Hardware-1: Intel Comet Lake PCH-H RAID driver: intel_nvme_remap v: N/A
port: 5060 bus-ID: 0000:00:17.0 chip-ID: 8086:06d7 rev: class-ID: 0104
Local Storage: total: 937.21 GiB used: 17.34 GiB (1.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8
size: 476.94 GiB block-size: physical: 512 B logical: 512 B tech: SSD
serial: <filter> fw-rev: 002C temp: 33.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: USB 3.2Gen1
size: 460.27 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 1.00 scheme: MBR
used: 17.34 GiB (3.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.41 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: N/A pch: 54.0 C mobo: N/A
Fan Speeds (rpm): cpu: 2800
Processes: 366 Uptime: 2m wakeups: 0 Memory: total: 16 GiB
available: 15.41 GiB used: 2.93 GiB (19.0%) Init: systemd v: 254
pm: pacman pkgs: 1884 libs: 567 tools: octopi,pamac,paru Shell: fish
v: 3.6.1 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-2):
System install date:     2023-11-18
Last full system update: 2023-11-18
You are trying to use xrandr on wayland naturally all those guides failed. Switch to X11 instead and see if it helps. You can do so from the login screen when you boot there is a small drop down just below the place to enter password click on it and select x11 instead of wayland and see if it helps.
Thank you! It works now.
