nxi -Faz
Kernel: 5.15.10-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=eaada518-9789-45a6-96d5-9ea2e9563ec6 rw [email protected]
cryptdevice=UUID=12d783ca-85f9-4344-8e01-a57b4947f1a0:luks-12d783ca-85f9-4344-8e01-a57b4947f1a0
root=/dev/mapper/luks-12d783ca-85f9-4344-8e01-a57b4947f1a0
systemd.unified_cgroup_hierarchy=1 loglevel=3 apparmor=1
security=apparmor delayacct
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Server Mobo: Intel model: S2600CP v: G50768-509
serial: <superuser required> BIOS: Intel
v: SE5C600.86B.02.06.0007.082420181029 date: 08/24/2018
Info: model: Intel Xeon E5-2650 v2 bits: 64 type: MT MCP SMP
arch: Ivy Bridge family: 6 model-id: 0x3E (62) stepping: 4 microcode: 0x42E
Topology: cpus: 2x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 2x 512 KiB (1024 KiB) desc: d-8x32 KiB; i-8x32 KiB L2: 2x 2 MiB (4 MiB)
desc: 8x256 KiB L3: 2x 20 MiB (40 MiB) desc: 1x20 MiB
Speed (MHz): avg: 2594 min/max: 1200/2600 scaling: driver: intel_cpufreq
governor: powersave cores: 1: 2594 2: 2594 3: 2594 4: 2594 5: 2594 6: 2594
7: 2594 8: 2594 9: 2594 10: 2594 11: 2594 12: 2594 13: 2594 14: 2594
15: 2594 16: 2594 17: 2594 18: 2594 19: 2594 20: 2594 21: 2594 22: 2594
23: 2594 24: 2594 25: 2594 26: 2594 27: 2594 28: 2594 29: 2594 30: 2594
31: 2594 32: 2594 bogomips: 166286
Type: l1tf
Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] vendor: Micro-Star MSI
driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 02:00.0
chip-ID: 10de:1b06 class-ID: 0300
Device-2: Matrox Systems MGA G200e [Pilot] ServerEngines vendor: Intel
driver: mgag200 v: kernel bus-ID: 09:00.0 chip-ID: 102b:0522 class-ID: 0300
loaded: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 92 s-size: 707x402mm (27.8x15.8")
s-diag: 813mm (32")
Monitor-1: HDMI-0 res: 2560x1440 hz: 144 dpi: 93
size: 698x393mm (27.5x15.5") diag: 801mm (31.5")
OpenGL: renderer: NVIDIA GeForce GTX 1080 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 495.46 direct render: Yes
Device-1: NVIDIA GP102 HDMI Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 02:00.1 chip-ID: 10de:10ef
Device-2: Creative SB X-Fi Surround 5.1 Pro type: USB
driver: snd-usb-audio bus-ID: 2-1.8:6 chip-ID: 041e:3237 class-ID: 0102
Sound Server-1: ALSA v: k5.15.10-zen1-1-zen running: yes
Device-1: Intel I350 Gigabit Network driver: igb v: kernel port: 1020
bus-ID: 07:00.0 chip-ID: 8086:1521 class-ID: 0200
IF: eno0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel I350 Gigabit Network driver: igb v: kernel port: 1000
bus-ID: 07:00.1 chip-ID: 8086:1521 class-ID: 0200
IF: enp7s0f1 state: down mac: <filter>
IF-ID-2: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Hardware-1: Adaptec Series 7 6G SAS/PCIe 3 driver: aacraid
v: 1.2.1[50983]-custom port: 4000 bus-ID: 01:00.0 chip-ID: 9005:028c
rev: N/A class-ID: 0104
Local Storage: total: 21.83 TiB used: 6.24 TiB (28.6%)
ID-1: /dev/sda maj-min: 8:0 model: root size: 21.83 TiB block-size:
physical: 512 B logical: 512 B type: N/A serial: N/A rev: V1.0 scheme: GPT
ID-1: / raw-size: 21.83 TiB size: 21.83 TiB (100.00%)
used: 6.24 TiB (28.6%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-12d783ca-85f9-4344-8e01-a57b4947f1a0
ID-2: /boot raw-size: 1024 MiB size: 1022 MiB (99.80%)
used: 324.7 MiB (31.8%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 21.83 TiB size: 21.83 TiB (100.00%)
ID-4: /var/log raw-size: 21.83 TiB size: 21.83 TiB (100.00%)
ID-5: /var/tmp raw-size: 21.83 TiB size: 21.83 TiB (100.00%)
ID-1: swap-1 type: zram size: 125.78 GiB used: 85.5 MiB (0.1%)
Permissions: Unable to run ipmi sensors. Root privileges required.
System Temperatures: cpu: 41.0 C mobo: N/A gpu: nvidia temp: 54 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 54%
Processes: 576 Uptime: 7h 42m wakeups: 0 Memory: 125.78 GiB
used: 15.73 GiB (12.5%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 alt: 10 clang: 13.0.0 Packages: 2867 pacman: 2830 lib: 577
flatpak: 37 Shell: fish v: 3.3.1 default: Zsh v: 5.8 running-in: konsole
inxi: 3.3.11
