Kernel: 5.16.13-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=1027140a-a9e9-4e0b-bfb2-a019fc83dd0f rw rootflags=subvol=@
resume=UUID=b2fa7c50-101c-4c44-85a9-b4ad60450f1e loglevel=3
Type: Laptop System: Micro-Star product: GS75 Stealth 10SE v: REV:1.0
Mobo: Micro-Star model: MS-17G3 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E17G3IMS.106 date: 03/19/2020
ID-1: BAT1 charge: 56.8 Wh (95.9%) condition: 59.2/80.3 Wh (73.8%)
volts: 16.4 min: 15.2 model: MSI BIF0_9 type: Li-ion serial: N/A
status: N/A
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
family: 6 model-id: 0xA5 (165) stepping: 2 microcode: 0xEC
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1715 high: 4303 min/max: 800/5000 scaling:
driver: intel_pstate governor: powersave cores: 1: 3348 2: 800 3: 800
4: 800 5: 800 6: 800 7: 1261 8: 2887 9: 3190 10: 4303 11: 800 12: 800
bogomips: 62399
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Micro-Star MSI
driver: i915 v: kernel ports: active: eDP-1 empty: none bus-ID: 00:02.0
chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: none off: HDMI-A-1 empty: DP-1,DP-2,eDP-2 bus-ID: 01:00.0
chip-ID: 10de:1f15 class-ID: 0300
Device-3: Acer HD Camera type: USB driver: uvcvideo bus-ID: 1-11:4
chip-ID: 5986:2127 class-ID: 0e02 serial: <filter>
loaded: modesetting,nvidia gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.9x11.2")
s-diag: 1052mm (41.4")
Monitor-1: HDMI-1-0 pos: right res: 1920x1080 hz: 60 dpi: 96
size: 509x286mm (20.0x11.3") diag: 584mm (23")
Monitor-2: eDP-1 pos: primary,left res: 1920x1080 hz: 240 dpi: 128
size: 382x215mm (15.0x8.5") diag: 438mm (17.3")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.3.7
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f9
Sound Server-1: ALSA v: k5.16.13-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.48 running: yes
Device-2: Intel driver: igc v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
port: N/A bus-ID: 03:00.0 chip-ID: 8086:3100 class-ID: 0200
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
bus-ID: 1-14:5 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 1.38 TiB used: 31.39 GiB (2.2%)
model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
rev: 111110WD temp: 52.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung
model: MZVLB512HAJQ-00000 size: 476.94 GiB block-size: physical: 512 B
rev: EXA7301Q temp: 26.9 C scheme: GPT
ID-1: / raw-size: 914.23 GiB size: 914.23 GiB (100.00%)
used: 31.39 GiB (3.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 580 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 914.23 GiB size: 914.23 GiB (100.00%)
ID-4: /var/log raw-size: 914.23 GiB size: 914.23 GiB (100.00%)
ID-5: /var/tmp raw-size: 914.23 GiB size: 914.23 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.98 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 15.44 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 70.0 C pch: 51.0 C mobo: N/A
Processes: 407 Uptime: 29m wakeups: 1 Memory: 15.44 GiB
used: 5.9 GiB (38.2%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 2013 lib: 438 Shell: fish
v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.13
Garuda (2.5.5-1):
System install date: 2022-03-10
Last full system update: 2022-03-11
Hello.
This is my garuda-inxi and my headphones are not working. First I thought it might be jack problem but system can detect my headphones. I have no problem with speaker but when I plug my headphones it is not working. Can anyone help me with it please?
