Hello,
My garuda is often freezing and I have no idea why .
It often happen when I'm using google chrome or when I make update via yay or pacman at the time where is it "syncing filesystem"
I have no idea what is the problem, could you help me ?
Here is inxi -Faz
result :
Kernel: 5.15.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=83004ee3-d6f4-4737-bbfa-faae9ee9d2ed rw rootflags=subvol=@
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
Type: Desktop System: Gigabyte product: TRX40 AORUS PRO WIFI v: -CF
Mobo: Gigabyte model: TRX40 AORUS PRO WIFI serial: <superuser required>
UEFI: American Megatrends LLC. v: FCa date: 10/20/2021
Info: model: AMD Ryzen Threadripper 3990X bits: 64 type: MT MCP arch: Zen 2
family: 0x17 (23) model-id: 0x31 (49) stepping: 0 microcode: 0x8301039
Topology: cpus: 1x cores: 64 tpc: 2 threads: 128 smt: enabled cache:
L1: 4 MiB desc: d-64x32 KiB; i-64x32 KiB L2: 32 MiB desc: 64x512 KiB
L3: 256 MiB desc: 16x16 MiB
Speed (MHz): avg: 3613 high: 4343 min/max: 2200/4375 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3593 2: 3577
3: 3590 4: 3591 5: 3588 6: 3817 7: 4341 8: 3777 9: 3586 10: 3592 11: 3591
12: 3591 13: 3594 14: 3593 15: 3593 16: 3591 17: 3664 18: 3538 19: 3576
20: 3591 21: 3593 22: 3594 23: 3593 24: 3587 25: 3596 26: 3588 27: 3584
28: 3593 29: 3589 30: 3589 31: 3598 32: 3591 33: 3593 34: 3596 35: 3597
36: 3594 37: 3595 38: 3586 39: 3591 40: 3594 41: 3592 42: 3592 43: 3592
44: 3597 45: 3593 46: 3592 47: 3592 48: 3593 49: 3593 50: 3593 51: 3590
52: 3587 53: 3589 54: 3594 55: 3589 56: 3594 57: 3588 58: 3514 59: 3539
60: 3588 61: 3594 62: 3596 63: 3585 64: 3593 65: 3541 66: 3594 67: 3530
68: 3546 69: 4342 70: 4324 71: 4343 72: 3494 73: 3588 74: 3594 75: 3589
76: 3582 77: 3585 78: 3590 79: 3596 80: 3589 81: 3677 82: 3488 83: 3481
84: 3587 85: 3591 86: 3591 87: 3587 88: 3592 89: 3587 90: 3592 91: 3585
92: 3512 93: 3595 94: 3599 95: 3587 96: 3593 97: 3595 98: 3597 99: 3596
100: 3591 101: 3598 102: 3592 103: 3592 104: 3591 105: 3592 106: 3591
107: 3593 108: 3595 109: 3594 110: 3592 111: 3592 112: 3593 113: 3589
114: 3592 115: 3592 116: 3593 117: 3583 118: 3593 119: 3590 120: 3591
121: 3593 122: 3588 123: 3592 124: 3585 125: 3590 126: 3590 127: 3588
128: 3588 bogomips: 741041
Device-1: NVIDIA TU116 [GeForce GTX 1660] vendor: ZOTAC driver: nvidia
v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 21:00.0 chip-ID: 10de:2184
Display: x11 server: X.Org 1.21.1.2 compositor: xfwm4 v: 4.16.1 driver:
loaded: nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 5760x1080 s-dpi: 96 s-size: 1524x286mm (60.0x11.3")
s-diag: 1551mm (61")
Monitor-1: DP-0 res: 1920x1080 hz: 60 dpi: 94
size: 521x293mm (20.5x11.5") diag: 598mm (23.5")
Monitor-2: HDMI-0 res: 1920x1080 hz: 60 dpi: 70
size: 698x392mm (27.5x15.4") diag: 801mm (31.5")
Monitor-3: DP-5 res: 1920x1080 hz: 60 dpi: 82
size: 598x336mm (23.5x13.2") diag: 686mm (27")
Device-1: NVIDIA TU116 High Definition Audio vendor: ZOTAC
driver: snd_hda_intel v: kernel bus-ID: 21:00.1 chip-ID: 10de:1aeb
Device-2: AMD Starship/Matisse HD Audio driver: snd_hda_intel v: kernel
bus-ID: 23:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Focusrite-Novation Scarlett Solo (3rd Gen.) type: USB
driver: snd-usb-audio bus-ID: 1-2:2 chip-ID: 1235:8211 class-ID: 0102
Device-4: Nektar Impact LX61+ type: USB driver: snd-usb-audio
bus-ID: 7-4.1:5 chip-ID: 2467:2017 class-ID: 0103
Device-5: Giga-Byte USB Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 7-5:4 chip-ID: 0414:a002
Sound Server-1: ALSA v: k5.15.12-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.42 running: no
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
port: 9000 bus-ID: 43:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp67s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 44:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlo2 state: up mac: <filter>
IF-ID-1: br-6f9b3b7fb6bc state: down mac: <filter>
IF-ID-2: br-7c1fb8f13621 state: down mac: <filter>
IF-ID-3: docker0 state: down mac: <filter>
bus-ID: 9-5:2 chip-ID: 8087:0029 class-ID: e001
address: <filter>
Local Storage: total: 2.73 TiB used: 501.88 GiB (18.0%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 type: SSD serial: <filter> rev: 3B2QGXA7 temp: 32.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter> rev: 3B2QGXA7
temp: 33.9 C scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 501.85 GiB (26.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:6
used: 27.5 MiB (10.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:5
ID-1: swap-1 type: zram size: 125.71 GiB used: 21.8 MiB (0.0%)
System Temperatures: cpu: 16.8 C mobo: N/A gpu: nvidia temp: 37 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 38%
Processes: 1595 Uptime: 1d 8h 46m wakeups: 0 Memory: 125.71 GiB
used: 21.53 GiB (17.1%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 Packages: 1816 pacman: 1806 lib: 353 snap: 10 Shell: Zsh v: 5.8
running-in: terminator inxi: 3.3.11
