My dual monitor setup broke after running Hearts of Iron 3 with Wine
Here you go:
  Kernel: 5.18.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
    root=UUID=5411b7ff-d53c-4780-9b50-82a7b4183826 rw rootflags=subvol=@
  Desktop: KDE Plasma v: 5.25.0 tk: Qt v: 5.15.5 info: latte-dock
  Type: Laptop System: Acer product: Nitro AN515-57 v: V1.10
  Mobo: TGL model: Scala_TLS v: V1.10 serial: <superuser required>
    UEFI: Insyde v: 1.10 date: 09/19/2021
  ID-1: BAT1 charge: 34.4 Wh (61.2%) condition: 56.2/57.5 Wh (97.8%)
    volts: 15.3 min: 15.4 model: LGC AP18E8M type: Li-ion serial: <filter>
    status: discharging cycles: 202
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
    charge: 5% (should be ignored) rechargeable: yes status: discharging
  Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 built: 2020 process: Intel 10nm family: 6
    model-id: 0x8D (141) stepping: 1 microcode: 0x3E
    L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 1000 high: 1339 min/max: 800/4600 scaling:
    driver: intel_pstate governor: powersave cores: 1: 1166 2: 1027 3: 801
    4: 1063 5: 1192 6: 897 7: 1010 8: 938 9: 880 10: 1217 11: 894 12: 801
    13: 788 14: 1339 15: 835 16: 1159 bogomips: 73728
  Device-1: Intel TigerLake-H GT1 [UHD Graphics]
    vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen12.1
    process: Intel 10nm built: 2020-21 ports: active: eDP-1 empty: DP-1,DP-2
    bus-ID: 0000:00:02.0 chip-ID: 8086:9a60 class-ID: 0300
  Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile]
    vendor: Acer Incorporated ALI driver: nvidia v: 515.48.07
    alternate: nouveau,nvidia_drm non-free: 515.xx+
    status: current (as of 2022-06) arch: Ampere process: TSMC n7 (7nm)
    built: 2020-22 bus-ID: 0000:01:00.0 chip-ID: 10de:25a2 class-ID: 0300
  Device-3: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 3-9:4
    chip-ID: 0408:a061 class-ID: 0e02
    compositor: kwin_x11 driver: X: loaded: intel,nvidia
    unloaded: modesetting,nouveau,vesa alternate: fbdev,nv gpu: i915
  Monitor-1: eDP-1 mapped: eDP1 model: ChiMei InnoLux 0x1521 built: 2020
    res: 1920x1080 hz: 144 dpi: 143 gamma: 1.2 size: 340x190mm (13.39x7.48")
  OpenGL: renderer: Mesa Intel UHD Graphics (TGL GT1) v: 4.6 Mesa 22.1.1
    direct render: Yes
  Device-1: Intel Tiger Lake-H HD Audio driver: snd_hda_intel v: kernel
    alternate: snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3 chip-ID: 8086:43c8
  Device-2: NVIDIA vendor: Acer Incorporated ALI driver: snd_hda_intel
    v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:2291 class-ID: 0403
  Sound Server-1: ALSA v: k5.18.5-zen1-1-zen running: yes
  Sound Server-3: PulseAudio v: 16.0 running: no
  Sound Server-4: PipeWire v: 0.3.52 running: yes
  Device-1: Intel Tiger Lake PCH CNVi WiFi vendor: Rivet Networks
    driver: iwlwifi v: kernel bus-ID: 0000:00:14.3 chip-ID: 8086:43f0
  Device-2: Realtek vendor: Acer Incorporated ALI driver: r8169 v: kernel
    port: 3000 bus-ID: 0000:2c:00.0 chip-ID: 10ec:2600 class-ID: 0200
  IF: enp44s0 state: down mac: <filter>
    bus-ID: 3-14:5 chip-ID: 8087:0026 class-ID: e001
    v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev:
    class-ID: 0104
  Local Storage: total: 2.29 TiB used: 240.11 GiB (10.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM512GD3JX016N
    speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 41020C20
    temp: 43.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 2TB
    type: SSD serial: <filter> rev: 2B6Q scheme: MBR
  ID-1: / raw-size: 297.4 GiB size: 297.4 GiB (100.00%)
    used: 240.06 GiB (80.7%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
    used: 50.5 MiB (52.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 297.4 GiB size: 297.4 GiB (100.00%)
  ID-4: /var/log raw-size: 297.4 GiB size: 297.4 GiB (100.00%)
  ID-5: /var/tmp raw-size: 297.4 GiB size: 297.4 GiB (100.00%)
  ID-1: swap-1 type: zram size: 15.41 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 27.8 C mobo: N/A
  Processes: 349 Uptime: 5m wakeups: 4 Memory: 15.41 GiB
  used: 2.84 GiB (18.4%) Init: systemd v: 251 default: graphical
  tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 2055
  lib: 529 Shell: Bash v: 5.1.16 running-in: terminator inxi: 3.3.18
Garuda (2.6.4-1):
  System install date:     2022-02-16
  Last full system update: 2022-06-20
I have no idea how or why this happened. Now, every time the other monitor is plugged in, instead of creating a new desktop, it just moves it over to the other monitor. On top of that the secondary monitor is incredibly slow and laggy. Only one screen will ever be present in the display config.
Never mind! I solved it myself! So no need to help, but I'd still like to know why/how this is able to happen. How a program could mess with things like that
Glad to hear it, however please take a moment to describe exactly how you fixed it so folks searching the forum for troubleshooting clues in the future may benefit from your discovery.
wisdom_of_the_ancients
All I did was press Fn+F6 and select the proper screen setting. I'm guessing you could fix the issue by also reconfiguring xrandr/arandr. What seemed to happen was that HOI3 just reset all my monitor settings.
