My benchmark with Path Of Exile, Zen, XanMod and Tkg-BMQ
This are my results
Maybe do some maps and repeat
Mostly better lows on Tkg-BMQ
MOBO b350gaming3
OS: Garuda Linux
DE: Plasma 5.21.5
WM: KWin
WM Theme: Sweet-Dark
Terminal: konsole
CPU: AMD Ryzen 5 1600 (12) @ 3.7GHz
GPU: AMD ATI Radeon RX 590 FATBOY 8GB VRAM
System Memory 15.64GiB
ZEN
01-zen_bench
XANMOD
02-xanmod_bench
TKG-BMQ
Thanks for the benchmarks!
With Zen and Proton experimental
01-zen_bench-experiental-small
TKG-PDS Proton experimental
010-tkg-pds_bench-experiental-small
TKG-BMQ with Proton Experimental
020-small-tkg-bmq-experimental-small
I will try high fps in the future, if i solve cooling for my gpu
does anyone test the -ne and -ma kernel
and where to find change logs or new features
for gaming?
not for me i'm not a gamer but more performance and buggerfree is okay for me i think also for gamer
Why not Zen?
I am really not the core connoisseur and changer am quite satisfied with the Tkg-bmq
but wonder what the latest cores can do
I am certainly no expert, Tkg made it pretty simple to compile his kernels. Zen is the default and xanmod is in chaotic
what distro you use always start garuda welcome and choose kernel "core" there you can change easy to every kernel always the newest
tkg pds is not there though, and I like applying Zen optimizations. But mainly I wanted to checkk what TKG says about PDS
i have a 5 year old laptop and a raspberry pi 8gb maximum
abba what use is a kernel that maybe only supports new things
sorry i talk like this i know new hardware brings difficulties
but i have now a simple system and almost no losses compared to windows
on the contrary I have win 10 running on external disk and can also emulate
2 ways to help others
I myself do not want to go back
sometimes i have to tinker a bit to achieve what i want
but compared to linux 20 years ago a world of difference
you had to do it yourself and hack LOOOOOOOL
Translated with www.DeepL.com/Translator (free version)
High FPS results
Tkg-PDS (with 500hz timer)
PathOfExile_x64Steam_2021-05-26_08-47-34-PDS-Proton_experimental-120
Tkg-PDS (with 750hz timer) I had a fps freeze but didn't have the ping enabled so can't if it was that)
PathOfExile_x64Steam_2021-05-26_10-44-37-TKG_PDS-750hz
Garuda Zen-zen1
PathOfExile_x64Steam_2021-05-26_09-52-17Garuda-Zen-120
TKG-BMQ Chicken dinner!
PathOfExile_x64Steam_2021-05-26_10-00-24-TKG-BMQ-120
