"Must-have" tools/packages
I'd like to get suggestions on what you peeps think are a couple of "must-haves". Like, what are the first apps you download when the OS is set-up and good to go?
For example: what is your favourite text editor? Preferred archive program?
Before i3wm was neutered to "lite", all programs I needed were available in the "ultimate" version. :smiley:
Are we including the AUR?
I always install gparted first thing on the KDE Lite version, KPM is too unreliable IMO.
Also smplayer with the skins and themes packages. Best video player by far.
Hehe that sucks. Isn't there a script you can run to get all the stuffs? :wink:
Yes, including AUR, Snap, Flatpak... whatever you like :cowboy_hat_face:
VScode, GitHub Desktop, Spotify-adblock, Telegram Desktop + Garuda-virtualbox :grin:
You can install GitHub Desktop on supported Windows or macOS operating systems. :scream:
Yep its available there as well, quite nice to see :slightly_smiling_face:
Ok, wat? This is a thing?
I'll probably miss a couple, but here goes:
 VSCode (Program editor)
Featherpad	(text editor)
Audacious (GTK) Music player
GIMP (art)
Inkscape (vector art)
Sigil (epub editor)
Seamonkey (for compose) (html editor)
LibreOffice (in case not already there)
conky-cairo (AUR)
conkywx (AUR)
jq (CLI json tool)
yad (script dialog access)
Yes its in the repo, quite useful if the browser isnt used :grin:
Visual Studio Code? I don't know how to code (unfortunately), but I like when I get colored text when editing files... it makes it so much easier to read, imo.
Just had a look at it and I think Imma give it a go :sunglasses:
I prefer atom. It's probably not the lightest and its also overkill for what my tasks are but, as I mentioned, I like it because it's easy to read.
Also part of my reason for Featherpad - it has syntax highlighting, and even a dark mode... like so:
As for VSCode - it has very good syntax highlight system - and even a user-created 'theme' for conky and conkywx - which certainly helps.
I wish you well with conkywx - it is certainly capable - but not entirely free of effort and a form of scripting. It can create a LOT of different looks though - I'll search through the screenshots for an example or two :grin:
Am available for help with conkywx if you get 'stuck' - but if you remember killall conky for when things aren't what you expect, you'll be fine!
Edit: Here's a link to some conkywx in action...
https://drive.google.com/file/d/1T7zKwOmR66FJ6vkWdYp39_YJUaaeWvq-/view?usp=sharing
