Multiple sound device
I was using my Garuda and then connected to my wireless earbuds but when I connected them to my PC it showed multiple audio devices connected, but I had only 2 my internal speaker and my earbuds, and when I tried to decrease the volume on my earbuds it automatically increases to 100.
Kernel: 6.4.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=377b3793-ae8b-4ea9-adac-8cc5c5f3188f rw rootflags=subvol=@
Type: Laptop System: LENOVO product: 80E5 v: Lenovo G50-80
serial: <superuser required> Chassis: type: 10 v: Lenovo G50-80
Mobo: LENOVO model: Lenovo G50-80 v: NO DPK serial: <superuser required>
UEFI: LENOVO v: B0CNA0WW date: 09/30/2016
ID-1: BAT0 charge: 15.9 Wh (100.0%) condition: 15.9/28.5 Wh (55.9%)
volts: 16.1 min: 14.4 model: Lenovo IdeaPad type: Unknown serial: <filter>
status: full
Info: model: Intel Core i3-5005U bits: 64 type: MT MCP arch: Broadwell
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 914 high: 1155 min/max: 500/1900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 798 2: 831 3: 872
4: 1155 bogomips: 15963
Device-1: Intel HD Graphics 5500 vendor: Lenovo driver: i915 v: kernel
arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1616
Device-2: Bison Lenovo EasyCamera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:4 chip-ID: 5986:014f
class-ID: 0e02
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: BOE Display 0x061d built: 2014 res: 1366x768
hz: 60 dpi: 112 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 389mm (15.3")
ratio: 16:9, 15:9 modes: 1366x768
API: OpenGL v: 4.6 Mesa 23.1.5 renderer: Mesa Intel HD Graphics 5500 (BDW
GT2) direct-render: Yes
Device-1: Intel Broadwell-U Audio vendor: Lenovo driver: snd_hda_intel
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Lenovo
API: ALSA v: k6.4.8-zen1-1-zen status: kernel-api
vendor: Lenovo driver: r8168 v: 8.051.02-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168
Device-2: Intel Wireless 3160 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:08b4 class-ID: 0280
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:5 chip-ID: 8087:07dc
Report: bt-adapter ID: hci0 rfk-id: 4 state: up address: <filter>
Local Storage: total: 223.57 GiB used: 15.15 GiB (6.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
tech: SSD serial: <filter> fw-rev: 0103 scheme: GPT
ID-1: / raw-size: 83.49 GiB size: 83.49 GiB (100.00%)
used: 15.12 GiB (18.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 1 GiB size: 1023 MiB (99.80%)
used: 25.9 MiB (2.5%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 83.49 GiB size: 83.49 GiB (100.00%)
ID-4: /var/log raw-size: 83.49 GiB size: 83.49 GiB (100.00%)
ID-5: /var/tmp raw-size: 83.49 GiB size: 83.49 GiB (100.00%)
ID-1: swap-1 type: zram size: 3.74 GiB used: 2.55 GiB (68.1%)
ID-2: swap-2 type: partition size: 7.73 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda7 maj-min: 8:7
System Temperatures: cpu: 55.0 C mobo: N/A
Processes: 224 Uptime: 2h 25m wakeups: 2 Memory: total: 4 GiB
available: 3.74 GiB used: 3 GiB (80.1%) Init: systemd v: 254
pm: pacman pkgs: 1315 libs: 367 tools: octopi,paru,yay Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.28
System install date:     2023-07-15
Last full system update: 2023-08-08
Is partially upgraded:   Yes
Screenshot_20230812_231617
It seems you are partially updated. Please run
garuda-update
to fix it. Also I have been facing similar issues where restarting pipewire is the only fix I have found until now.
systemctl restart --user pipewire-pulse.socket pipewire.socket wireplumber.service
you can map this to a keyboard shortcut like Super+r Until a fix from upstream arrives.
Think this is the same on the thread that i have here.
https://forum.garudalinux.org/t/connected-audio-piling-up-in-ui/30256/6
Oks after an update this morning. Mine alraedy fixed.
It can seem that way but something triggers it again, at least for me.
