Report everything you have already attempted to solve your problem.***
garuda-inxi output:
Kernel: 5.16.2-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=5517fde1-302f-4da8-8c64-ffcf4214d0b7 rw [email protected]
Type: Desktop System: LENOVO product: 10ALCTO1WW v: ThinkCentre M83
Mobo: LENOVO model: SHARKBAY v: SDK0E50510 WIN
serial: <superuser required> UEFI: LENOVO v: FBKTDFAUS date: 06/18/2021
Info: model: Intel Core i7-4790 bits: 64 type: MT MCP arch: Haswell
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3590 high: 3595 min/max: 800/4000 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3592 2: 3592
3: 3592 4: 3582 5: 3585 6: 3592 7: 3593 8: 3595 bogomips: 57469
Type: l1tf
Type: spectre_v2 mitigation: Full generic retpoline, IBPB:
conditional, IBRS_FW, STIBP: conditional, RSB filling
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated
Graphics
vendor: Lenovo ThinkCentre M83 driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:0412 class-ID: 0300
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
Screen-1: 0 s-res: 4480x900 s-dpi: 96 s-size: 1184x237mm (46.6x9.3")
s-diag: 1207mm (47.5")
Monitor-1: HDMI1 res: 1600x900 hz: 60 dpi: 92
size: 440x250mm (17.3x9.8") diag: 506mm (19.9")
Monitor-2: HDMI2 res: 1600x900 hz: 60 dpi: 92
Monitor-3: VGA1 res: 1280x768 hz: 60 dpi: 74
OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2)
v: 4.5 Mesa 21.3.4 compat-v: 3.0 direct render: Yes
vendor: Lenovo ThinkCentre M83 driver: snd_hda_intel v: kernel
bus-ID: 00:03.0 chip-ID: 8086:0c0c class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio
bus-ID: 00:1b.0 chip-ID: 8086:8c20 class-ID: 0403
Device-3: Focusrite-Novation LaunchKey Mini MK3 type: USB
driver: snd-usb-audio,usb-storage bus-ID: 3-4:4 chip-ID: 1235:0102
class-ID: 0806 serial: <filter>
Sound Server-1: ALSA v: k5.16.2-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.43 running: yes
Device-1: Intel Ethernet I217-LM vendor: Lenovo ThinkCentre M83
driver: e1000e v: kernel port: f080 bus-ID: 00:19.0 chip-ID: 8086:153a
Device-2: Realtek RTL8812AU 802.11a/b/g/n/ac 2T2R DB WLAN Adapter
type: USB driver: N/A bus-ID: 3-9:5 chip-ID: 0bda:8812 class-ID: 0000
Local Storage: total: 1.49 TiB used: 24.69 GiB (1.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DX001-1CM162
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: CC62
model: WD6401AALS-00L3B2 size: 596.17 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: 3B01
ID-3: /dev/sdc maj-min: 8:32 type: USB
model: Novation Onboarding Drive size: 192 KiB block-size:
physical: 512 B logical: 512 B type: N/A serial: <filter> rev: 0.01
scheme: MBR
ID-1: / raw-size: 595.87 GiB size: 595.87 GiB (100.00%)
used: 24.69 GiB (4.1%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 576 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 595.87 GiB size: 595.87 GiB (100.00%)
ID-4: /var/log raw-size: 595.87 GiB size: 595.87 GiB (100.00%)
ID-5: /var/tmp raw-size: 595.87 GiB size: 595.87 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.42 GiB used: 768 KiB (0.0%)
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Processes: 276 Uptime: 10m wakeups: 0 Memory: 15.42 GiB
used: 3.74 GiB (24.2%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1588 lib: 446 Shell: Zsh
v: 5.8 running-in: terminator inxi: 3.3.12
Garuda:
System install date: 2022-01-23
Last full system update: 2022-01-27
Using TLP: No
My Issue:
I've always had this problem with any distro/DE I use, but figured I'd try here anyway. When I use multiple monitors (3 monitors in this case) my OS will freeze up at any given time. I have no idea what's causing this, and can't seem to find any helpful information. I'd like this distro/DE setup to be stable enough to use as my daily driver, but I'm at a loss. Also, since having to hard reboot since the last freeze, my top-bar that comes with Garuda KDE is now gone. If anyone can please help me with this issue, I'd greatly appreciate it.
