Multiple Monitor on garuda dragonized
I have installed garuda linux dragonized.. i am pretty new to linux environment.
multiple Monitor is not working tried xrandr -q which returned only 1 monitor.. but i have 2 connected.. so far tried ubuntu,pop os, arch, archcraft, garuda. multi monitor seems to work only in ubuntu and pop os.
how to solve this issue?
Use forum search function.
Read
please
and post
inxi -Fxxxza
as text! Even if you personally think it is unnecessary.
and
:slight_smile:
This likely not all that helpful to you in resolving but I have 3 monitors and they worked out of the box. Only thing I always have to change which isn't a garuda thing is the orientation on one since it is in portrait not landscape but obviously no way for system to know that. So not sure why it isn't working for you but it should be without any settings changes.
If you can provide more detail I am sure it can be resolved for you.
thank u but it worked. i had to switch graphics to nvidia.. after that it worked..
