Multiple dependency issues
update
 garuda is up to date
 core is up to date
 extra is up to date
 multilib is up to date
 chaotic-aur is up to date
 garuda downloading...
 core downloading...
 extra downloading...
 multilib downloading...
 chaotic-aur downloading...
--> Applying keyring updates before starting full system update..
warning: chaotic-keyring-20230616-1 is up to date -- skipping
warning: garuda-hotfixes-1.1.2-1 is up to date -- skipping
resolving dependencies...
Packages (1) archlinux-keyring-20231017-1
Total Download Size:   1.14 MiB
Total Installed Size:  1.62 MiB
Net Upgrade Size:      0.00 MiB
:: Retrieving packages...
 archlinux-keyring-20231017-1-any downloading...
checking keyring...
checking package integrity...
loading package files...
checking for file conflicts...
checking available disk space...
snapper snapshots skipped
upgrading archlinux-keyring...
==> Appending keys from archlinux.gpg...
==> Locally signing trusted keys in keyring...
  -> Locally signed 1 keys.
==> Importing owner trust values...
gpg: inserting ownertrust of 4
==> Disabling revoked keys in keyring...
  -> Disabled 1 keys.
==> Updating trust database...
gpg: marginals needed: 3  completes needed: 1  trust model: pgp
gpg: depth: 0  valid:   1  signed:  10  trust: 0-, 0q, 0n, 0m, 0f, 1u
gpg: depth: 1  valid:  10  signed:  94  trust: 0-, 0q, 0n, 10m, 0f, 0u
gpg: depth: 2  valid:  71  signed:  27  trust: 71-, 0q, 0n, 0m, 0f, 0u
gpg: next trustdb check due at 2023-10-31
(1/7) Reloading system manager configuration...
(2/7) Arming ConditionNeedsUpdate...
(3/7) Foreign/AUR package notification
caja-rename 23.10.1-1
libmagick6 6.9.12.98-1
python-pytaglib 2.0.0-1
rss-glx 0.9.1-35
(4/7) Orphaned package notification...
boston-icon-theme 2.0-1
chrpath 0.16-4
cmake-extras-git r291-1
cython 3.0.4-1
garuda-backgrounds r15.cd07442-1
ghostpcl 10.02.0-2
ghostxps 10.02.0-2
gnome-common 3.18.0-4
gobject-introspection 1.78.1-1
gptfdisk 1.0.9-2
gst-python 1.22.6-1
opencl-headers 2:2023.04.17-2
openfortivpn 1.20.5-1
python-build 1.0.3-1
python-caja 1.27.0-2
python-installer 0.7.0-3
python-polib 1.2.0-1.2
python-pytest 7.4.2-1
python-reportlab 3.6.12-3
python-wheel 0.40.0-3
samba-support 1-7
sweet-theme-full-git r336.900343a-1
(5/7) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/shells.pacnew
/etc/pamac.conf.pacnew
Please check and merge
(6/7) Performing snapper post snapshots for the following configurations...
(7/7) Syncing all file systems...
warning: vdhcoapp-git: local (2.0.0.r0.g6beaae1-1) is newer than chaotic-aur (1.6.3.r36.gedad10d-2)
:: installing kcmutils5 (5.111.0-1) breaks dependency 'kcmutils' required by amarok
:: installing kdoctools5 (5.111.0-1) breaks dependency 'kdoctools' required by amarok
:: installing kdnssd5 (5.111.0-1) breaks dependency 'kdnssd' required by amarok
:: installing knewstuff5 (5.111.0-1) breaks dependency 'knewstuff' required by amarok
:: installing ktexteditor5 (5.111.0-1) breaks dependency 'ktexteditor' required by amarok
:: installing threadweaver5 (5.111.0-1) breaks dependency 'threadweaver' required by amarok
What should I do?
Please, always use the forum search function.
There are multiple threads about, you just must wait until the devs fix the dependencies.
I did use the search, and didn’t see my problem.
I’ll just wait.
That’s correct, but somewhere dr460nf1r3 wrote, that we can only fix Garuda apps. Not the Rest :wink: .
So there are many apps around with the changing to the next plasma release.
Or you can remove amarok :wink: if you need updates.
Updated today and the first package downloaded was garuda-update and the upgrade performed perfectly.
