Multimonitor Problems with Triple Monitor Setup
Hello Community i searched in the Forum and couldnt find my Problem because of that i create this Post.
  1. The issue
I Have the Issue that when my 4k 165 HZ Display connected is with my 2 2560x1440@144hz Displays and i want to aktivate 144hz and 165 hz My entire desktop Crashes und my My Displays are Flickering in alot of different Colors on a Black Background
2. Attempts to solve it
I have Installed Garuda OS Gaming Edition complete anew Installed the Nvidia DKMS Driver with the Linux Headers needed and tried at which point the desktop crashes if i use 2560x1440 instead of 4k on my 4k Monitor i can use all three Monitors with their Maximum Refresh Rates ( 2x 144 hz and 1x 165 HZ for my Main Monitor).
I Can use my 4k Monitor with 120 HZ if my 2x 2560x1440 Monitors are yousing 60 hz any higher than that and it crashes. i Tried to Use 120 HZ for All three Monitors and it Crashes, I Tried using Wayland did the neccesary pre work so that nvidia and wayland are Working and the same Happens i did deactivate VRR on Wayland it changed nothing.
if i Try to activate HDR for my Main Monitor the same Happens except if the 2 2560x1440 Monitors are deaktivated ( i know this doesnt Help with my Problem i just wanted to try it and the Same Problem did happen)
I Tried Windows which is Installed on another internal Drive and i have no Problems whats so ever even if i activate VRR and 12 bit Color Depth and Maximum Refresh rates on all Monitors and HDR it works perfekt because of that i think it is not a Hardware or Cable Problem.
Here iis my Garuda-inxi iutput :
Kernel: 6.8.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=0b773e3f-c28a-4095-ad87-b1d85dfc7b75 rw rootflags=subvol=@
quiet loglevel=3 nvidia_drm.modeset=1 ibt=off
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Mobo: ASUSTeK model: ROG STRIX X670E-E GAMING WIFI v: Rev 1.xx
serial: <filter> part-nu: SKU uuid: 951157a8-18bc-211a-147f-a036bcacb122
UEFI: American Megatrends v: 1807 date: 12/14/2023
Info: model: AMD Ryzen 9 7950X3D socket: AM5 bits: 64 type: MT MCP
arch: Zen 4 gen: 5 level: v4 note: check built: 2022+ process: TSMC n5 (5nm)
family: 0x19 (25) model-id: 0x61 (97) stepping: 2 microcode: 0xA601206
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 16 MiB desc: 16x1024 KiB
L3: 128 MiB desc: 1x32 MiB, 1x96 MiB
Speed (MHz): avg: 704 high: 5485 min/max: 400/5759 base/boost: 4200/5750
scaling: driver: amd-pstate-epp governor: performance volts: 1.3 V
ext-clock: 100 MHz cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 5050
7: 400 8: 400 9: 5485 10: 400 11: 400 12: 400 13: 400 14: 400 15: 400
16: 400 17: 400 18: 400 19: 400 20: 400 21: 400 22: 400 23: 400 24: 400
25: 400 26: 400 27: 400 28: 400 29: 400 30: 400 31: 400 32: 400
bogomips: 268782
Device-1: NVIDIA AD104 [GeForce RTX 4070] vendor: PNY driver: nvidia
v: 550.78 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-04) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 ports: active: none off: DP-1,DP-2,HDMI-A-1
empty: DP-3 bus-ID: 01:00.0 chip-ID: 10de:2786 class-ID: 0300
Display: server: X.Org v: 23.2.6 with: Xwayland v: 23.2.6
gpu: nvidia,nvidia-nvswitch display-ID: :1 screens: 1
Screen-1: 0 s-res: 5440x2560 s-dpi: 96 s-size: 1439x677mm (56.65x26.65")
s-diag: 1590mm (62.61")
Monitor-1: DP-1 note: disabled pos: right model: 27E1QA serial: <filter>
built: 2022 res: 1440x2560 hz: 60 dpi: 111 gamma: 1.2
size: 330x600mm (12.99x23.62") diag: 685mm (27") ratio: 16:9 modes:
max: 2560x1440 min: 640x480
Monitor-2: DP-2 note: disabled pos: left model: 27E1QA serial: <filter>
built: 2022 res: 1440x2560 hz: 120 dpi: 111 gamma: 1.2
Monitor-3: HDMI-A-1 note: disabled pos: primary,center
model: Samsung Odyssey G7 serial: <filter> built: 2023 res: 2560x1440
hz: 120 dpi: 93 gamma: 1.2 size: 700x400mm (27.56x15.75")
diag: 806mm (31.7") ratio: 16:9 modes: max: 3840x2160 min: 640x480
drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: zink
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.78
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4070/PCIe/SSE2
memory: 11.71 GiB
API: Vulkan v: 1.3.279 layers: 10 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 4070 driver: nvidia v: 550.78 device-ID: 10de:2786
surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe (LLVM 17.0.6 256
bits) driver: mesa llvmpipe v: 24.0.6-arch1.2 (LLVM 17.0.6)
Device-1: NVIDIA vendor: PNY driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:22bc class-ID: 0403
Device-2: Creative Sound BlasterX G5
lanes: 1 mode: 2.0 bus-ID: 1-4.1:6 chip-ID: 041e:3243 class-ID: 0300
Device-3: RODE Microphones Podcaster v2
lanes: 1 mode: 1.1 bus-ID: 3-4:2 chip-ID: 19f7:0008 class-ID: 0300
Device-4: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:4
API: ALSA v: k6.8.9-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.6 status: n/a (root, process) with:
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 0a:00.0
IF: wlp10s0 state: down mac: <filter>
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 0b:00.0
IF: eno1 state: up speed: 2500 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:5 chip-ID: 8087:0032
Local Storage: total: 10.92 TiB used: 36.94 GiB (0.3%)
ID-1: /dev/nvme0n1 maj-min: 259:6 vendor: Fanxiang model: S770 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3.W.J.1 temp: 40.9 C
scheme: MBR
SMART: yes health: PASSED on: 80d 15h cycles: 604
read-units: 12,098,979 [6.19 TB] written-units: 8,952,329 [4.58 TB]
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Fanxiang model: S770 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3.W.J.1 temp: 44.9 C
scheme: MBR
SMART: yes health: PASSED on: 80d 17h cycles: 601
read-units: 12,097,644 [6.19 TB] written-units: 8,890,894 [4.55 TB]
ID-3: /dev/nvme2n1 maj-min: 259:0 vendor: Fanxiang model: S770 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3.W.J.1 temp: 35.9 C
scheme: MBR
SMART: yes health: PASSED on: 80d 16h cycles: 601
read-units: 12,080,489 [6.18 TB] written-units: 8,883,806 [4.54 TB]
ID-4: /dev/nvme3n1 maj-min: 259:4 vendor: Fanxiang model: S770 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3.W.J.1 temp: 34.9 C
scheme: MBR
SMART: yes health: PASSED on: 80d 16h cycles: 604
read-units: 12,112,603 [6.20 TB] written-units: 8,959,812 [4.58 TB]
ID-5: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 1000GB
family: Marvell based SSDs size: 931.51 GiB block-size: physical: 512 B
logical: 512 B sata: 3.2 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 04RL temp: 27 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 154d 2h cycles: 1491
ID-6: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SSD PLUS 1000GB
fw-rev: 04RL temp: 26 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 154d 5h cycles: 1493
ID-7: /dev/sdc maj-min: 8:32 vendor: SanDisk model: SDSSDH3 1T00
logical: 512 B sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 00RL temp: 25 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 130d 3h cycles: 3854
ID-8: /dev/sdd maj-min: 8:48 vendor: SanDisk model: SSD PLUS 1000GB
SMART: yes state: enabled health: PASSED on: 154d 2h cycles: 1493
used: 36.92 GiB (4.0%) fs: btrfs block-size: 4096 B dev: /dev/sda2
maj-min: 8:2
used: 25.9 MiB (8.6%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
maj-min: 8:2
maj-min: 8:2
maj-min: 8:2
ID-1: swap-1 type: zram size: 31.05 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 32 dev: /dev/zram0
System Temperatures: cpu: 48.1 C mobo: N/A
Memory: total: 32 GiB note: est. available: 31.05 GiB used: 4.1 GiB (13.2%)
Processes: 572 Power: uptime: 15m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.36 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2014 libs: 579 tools: octopi,paru pm: flatpak
pkgs: 0 Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi (sudo)
default: Bash v: 5.2.26 running-in: konsole inxi: 3.3.34
System install date:     2024-04-05
Last full system update: 2024-05-10 ā†»
Windows dual boot:       Yes
this about hdr: HDR monitor support - ArchWiki
this helped me a lot to fix unresponsive/laggy desktop: 433094 ā€“ No way to disable tearing prevention
Comment #16
Also I assume you are a gamer given the setup, if you feel games being laggy despite the high fps: alt+shift+f12 to disable kde effects (search equivalent for other WM), do it again to re-enable them.
Thanks for Help with HDR, I have no Problems with a laggy desktop because i already did the changes from the post, i have no Performance Problems in Games.
Do you have any Idea why i cant use my 3 Monitors at maximum refresh Rates and resolution together ? i can use them together only if my 4k monitor resolution is set to 2560x1440@120hz instead of 3840x2160@120hz and my other 2 Monitors are set to 2560x1440@60hz instead of 144hz ?
In doing the changes from the post, did you set the highest refresh rate between your monitors? Ignore the values displayed in the settings and do a test with glxgears (or alternatives) to monitor the actual FPS in each monitor.
Iā€™d use this to search more infos, there is a troubleshooting section: xrandr - ArchWiki
I tested it all 3 of my Monitors have 120 HZ Refresh Rate that is the Refresh Rate that all 3 of my Monitors share. I Did Read Xrandr and the Multihead wiki page but did find anythin that is usefull for my Problem and nothing that is shown as incorect.
