Mouse & track pad freezing issue
Kernel: 6.4.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=647e731d-2d7b-4d32-bb3e-73141eaf0bc1 rw rootflags=subvol=@
Type: Laptop System: HP product: HP Notebook v: Type1ProductConfigId
Mobo: HP model: 81F0 v: 63.21 serial: <superuser required> UEFI: Insyde
v: F.44 date: 08/07/2018
ID-1: BAT1 charge: 12.9 Wh (60.8%) condition: 21.2/32.6 Wh (65.1%)
volts: 15.6 min: 14.8 model: COMPAL PABAS0241231 type: Li-ion
Info: model: Intel Core i3-5005U bits: 64 type: MT MCP arch: Broadwell
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1896 high: 1897 min/max: 500/1900 scaling:
driver: intel_cpufreq governor: performance cores: 1: 1896 2: 1897 3: 1896
4: 1895 bogomips: 15961
Device-1: Intel HD Graphics 5500 vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen-8 process: Intel 14nm built: 2014-15 ports:
active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1616
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 M430 Radeon
520 Mobile] vendor: Hewlett-Packard driver: radeon v: kernel
alternate: amdgpu arch: GCN-1 code: Southern Islands process: TSMC 28nm
built: 2011-20 pcie: gen: 2 speed: 5 GT/s lanes: 4 link-max: gen: 3
speed: 8 GT/s lanes: 8 bus-ID: 0d:00.0 chip-ID: 1002:6660 class-ID: 0380
temp: 46.0 C
Device-3: Chicony HP TrueVision HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-5:3 chip-ID: 04f2:b56c
compositor: kwin_x11 driver: X: loaded: modesetting,radeon
alternate: fbdev,intel,vesa dri: iris,radeonsi gpu: i915 display-ID: :0
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: AU Optronics 0x70ec built: 2015 res: 1366x768
hz: 60 dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
API: OpenGL v: 4.6 Mesa 23.1.6-arch1.4 renderer: Mesa Intel HD Graphics
5500 (BDW GT2) direct-render: Yes
Device-1: Intel Broadwell-U Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c
chip-ID: 8086:9ca0 class-ID: 0403
API: ALSA v: k6.4.12-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.79 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 5000
bus-ID: 07:00.0 chip-ID: 10ec:8136 class-ID: 0200
Device-2: Broadcom BCM43142 802.11b/g/n vendor: Hewlett-Packard driver: wl
v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 13:00.0 chip-ID: 14e4:4365 class-ID: 0280
IF: wlp19s0 state: up mac: <filter>
Device-1: Broadcom BCM43142A0 Bluetooth 4.0 driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-4:2 chip-ID: 0a5c:216d
rfk-block: hardware: no software: yes address: <filter> bt-v: 4.0 lmp-v: 6
Local Storage: total: 1.14 TiB used: 35.76 GiB (3.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT250MX500SSD1
size: 232.89 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 045 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: HGST (Hitachi) model: HTS541010A9E680
tech: HDD rpm: 5400 serial: <filter> fw-rev: A7G0 scheme: MBR
used: 35.76 GiB (15.4%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 7.67 GiB used: 190.5 MiB (2.4%)
System Temperatures: cpu: 58.0 C pch: 50.5 C mobo: N/A gpu: radeon
temp: 46.0 C
Processes: 212 Uptime: 30m wakeups: 1 Memory: total: 8 GiB
available: 7.67 GiB used: 3.96 GiB (51.6%) Init: systemd v: 254
pm: pacman pkgs: 1857 libs: 549 tools: octopi,paru Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.29
head: cannot open '/var/log/pacman.log' for reading: No such file or directory
System install date:
Last full system update: 2023-09-04
My mouse track pad often freezing & not working but it works when I reboot .Give me a solution please
It works after a reboot but then at some point I assume it breaks again. Do you see any pattern with this? Is it happening after you sleep then wake the computer or maybe plug and/or unplug certain devices?
Take note of the time this happens next time, then check the journal logs around that time.
Instead of rebooting, try switching to a tty and then back to the graphical session.
No only after booting up for the first time in the day & not all time at random times only then only rebooting can solve the issue after rebooting it works fine no problem but its so annoying for me as I use the track-pad for all the time
Bro I didn’t get u can u be more specific as I am new to garuda what is journal & tty please guide
Really sorry, but this is not supposed to be a linux teaching forum. You will need some self learning.
For the journal check this:
https://wiki.archlinux.org/title/Systemd/Journal#Filtering_output
To switch to TTY and back:
Ctrl + Alt+F4 to go to a TTY (other Fx can be used as well)
Ctrl + Alt+F1 back to the graphical session (the proper number may vary)
OK today the issue happened again I switched to tty & back to normal nothing happened also checked journal logs but nothing found suspicious but instead I found this some written in yellow & some in red also my laptop is running hot (sometimes only) even when doing light works & also having higher fan noise
DMAR: [Firmware Bug]: No firmware reserved region can cover this RMRR [0x0>
Sep 24 20:40:05 aravind-hp kernel: DMAR: [Firmware Bug]: Your BIOS is broken; bad RMRR [0x000000009d800000-0x>
BIOS vendor: Insyde; Ver: F.44; Product Version: Type1ProductConfigId
ENERGY_PERF_BIAS: Set to ‘normal’, was ‘performance’
MDS CPU bug present and SMT on, data leak possible. See https://www.kernel>
Check BIOS, the problem is not Garuda Linux related.
Will updating BIOS solve the issue ?
