Mouse-pointer disappearing and window key unusable upon sub-window creation
I’m having a major issue preventing me from using my system. Everything seems to be normal after booting. During the course of my work, I have to open many different applications and windows.
Sometimes when X opens a new window/sub-window, my mouse-pointer disappears, and my Window key doesn’t work anymore (Both problems happen simultaneously). When this happens, the mouse isn’t just hidden. It’s completely gone (Can’t click anything or hover). There is no specific application window that causes it but I think it might only be sub-windows (Usually settings in various applications). I have seen it happen when I opened the settings dialog in Blender and in Pycharm. Probably others as well that I’m not recalling.
Whenever this happens I have to either alt+tab to the terminal I have open or ctrl+alt+f3 so I can manually end my gnome session with gnome-session-quit --logout --force.I have tried clearing my gnome config via dconf reset -f / which did not resolve the issue.
journalctl -b | grep -i error (Today’s entries): https://hastebin.com/share/seboxifuma.yaml
inxi:
  Kernel: 6.5.6-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=cc8f8aae-9afb-48fc-9eff-62f9df1eb56c rw rootflags=subvol=@
    cryptdevice=UUID=cfffcf8a-c3da-46b8-b9c9-b4bc281caba8:luks-cfffcf8a-c3da-46b8-b9c9-b4bc281caba8
    root=/dev/mapper/luks-cfffcf8a-c3da-46b8-b9c9-b4bc281caba8 no
    resume=/dev/mapper/luks-4a58206a-a094-481e-8f36-013e250bfae4 loglevel=3
    no nvidia-drm.modeset=1 ibt=off
  Desktop: GNOME v: 44.5 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
  Type: Laptop System: ASUSTeK product: ROG Zephyrus G15 GA503RM_GA503RM
  Mobo: ASUSTeK model: GA503RM v: 1.0 serial: <superuser required>
    UEFI: American Megatrends LLC. v: GA503RM.313 date: 01/17/2023
  ID-1: BAT1 charge: 14.4 Wh (18.2%) condition: 79.0/90.2 Wh (87.6%)
    volts: 15.0 min: 15.9 model: ASUS A32-K55 type: Li-ion serial: N/A
    status: charging
  Info: model: AMD Ryzen 9 6900HS with Radeon Graphics bits: 64 type: MT MCP
    family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404101
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1279 high: 4591 min/max: 400/4935 scaling:
    4: 2482 5: 1605 6: 2933 7: 4591 8: 400 9: 2143 10: 1726 11: 400 12: 400
    13: 400 14: 400 15: 1393 16: 400 bogomips: 105399
  Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
    driver: nvidia v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
    status: current (as of 2023-09) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-23 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
    off: eDP-2 empty: DP-9,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:2520
  Device-2: AMD Rembrandt [Radeon 680M] vendor: ASUSTeK driver: amdgpu
    pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-1,
    DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, DP-8, eDP-1 bus-ID: 07:00.0
    chip-ID: 1002:1681 class-ID: 0300 temp: 59.0 C
  Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 13d3:56eb
    compositor: gnome-shell driver: X: loaded: amdgpu,nvidia
    unloaded: modesetting,nouveau,radeon alternate: fbdev,nv,vesa
    dri: radeonsi gpu: nvidia,nvidia-nvswitch display-ID: :1 screens: 1
    s-diag: 777mm (30.58")
  Monitor-1: eDP-2 mapped: DP-2 note: disabled model: ChiMei InnoLux 0x1540
    built: 2020 res: 2560x1440 dpi: 191 gamma: 1.2 size: 340x190mm (13.39x7.48")
    diag: 394mm (15.5") ratio: 16:9 modes: 2560x1440
  API: EGL v: 1.5 hw: drv: nvidia platforms: gbm: drv: nvidia
  API: OpenGL v: 4.6.0 vendor: nvidia v: 535.113.01 glx-v: 1.4
    direct-render: yes renderer: NVIDIA GeForce RTX 3060 Laptop GPU/PCIe/SSE2
    memory: 5.86 GiB
  API: Vulkan v: 1.3.264 layers: 8 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 3060 Laptop GPU driver: nvidia v: 535.113.01
    device-ID: 10de:2520 surfaces: xcb,xlib device: 1 type: integrated-gpu
    name: AMD Radeon Graphics (RADV REMBRANDT) driver: mesa radv
    v: 23.2.1-arch1.2 device-ID: 1002:1681 surfaces: xcb,xlib device: 2
    type: cpu name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe
    v: 23.2.1-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000 surfaces: xcb,xlib
    link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
  Device-2: AMD Rembrandt Radeon High Definition Audio vendor: ASUSTeK
    bus-ID: 07:00.1 chip-ID: 1002:1640 class-ID: 0403
    snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 07:00.5 chip-ID: 1022:15e2 class-ID: 0480
    bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.5.6-zen2-1-zen status: kernel-api tools: N/A
  Server-1: PipeWire v: 0.3.81 status: active with: 1: pipewire-pulse
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
    lanes: 1 bus-ID: 04:00.0 chip-ID: 14c3:7922 class-ID: 0280
  IF-ID-3: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:3 chip-ID: 13d3:3568
    rfk-block: hardware: no software: yes address: <filter> bt-v: 5.3 lmp-v: 12
  Local Storage: total: 1.38 TiB used: 398.37 GiB (28.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Smart Modular Tech.
    model: SHPP41-1000GM size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 51060A20 temp: 55.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:7 vendor: Western Digital model: WD PC
    SN735 SDBPNHH-512G-1002 size: 476.94 GiB block-size: physical: 512 B
    fw-rev: 70626000 temp: 41.9 C scheme: GPT
  ID-1: / raw-size: 451.59 GiB size: 451.59 GiB (100.00%)
    used: 398.33 GiB (88.2%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-cfffcf8a-c3da-46b8-b9c9-b4bc281caba8
    used: 724 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:8
  ID-3: /home raw-size: 451.59 GiB size: 451.59 GiB (100.00%)
  ID-4: /var/log raw-size: 451.59 GiB size: 451.59 GiB (100.00%)
  ID-5: /var/tmp raw-size: 451.59 GiB size: 451.59 GiB (100.00%)
  Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: no
  ID-1: swap-1 type: zram size: 22.77 GiB used: 4.05 GiB (17.8%)
  ID-2: swap-2 type: partition size: 25.05 GiB used: 34.3 MiB (0.1%)
    mapped: luks-4a58206a-a094-481e-8f36-013e250bfae4
  System Temperatures: cpu: 65.2 C mobo: N/A
  Fan Speeds (rpm): cpu: 4000
  GPU: device: nvidia screen: :1.0 temp: 52 C device: amdgpu temp: 59.0 C
  Processes: 500 Uptime: 1d 8h 46m wakeups: 47 Memory: total: 24 GiB
  note: est. available: 22.77 GiB used: 6.72 GiB (29.5%) Init: systemd v: 254
  default: graphical tool: systemctl Compilers: gcc: 13.2.1 alt: 6/7
  clang: 16.0.6 Packages: pm: pacman pkgs: 2380 libs: 586
  tools: gnome-software,pamac,paru pm: appimage pkgs: 0 Shell: Bash v: 5.1.16
  running-in: gnome-terminal inxi: 3.3.30
Garuda (2.6.17-1):
  System install date:     2022-10-15
  Last full system update: 2023-10-09 ↻
  Failed units:            anbox-container-manager.service
