Hi
I am having a problem with my mouse clicks not registering. Moving the mouse works just fine but clicks do not generate events. Everything was working fine for a couple of days after installation but after a reboot it didn't work anymore.
Xev does not register any button press events, but other events work, the same happens with
libinput debug-events
. The mouse is using libinput as a driver, at least based on xorg log. I think scrolling is interpreted as button presses, so that doesn't work either. I tried to look if Click Methods from libinput were disabled for some reason, but it looks like that configuration option is not available.
I would appreciate assistance in getting the mouse buttons to work again.
garuda-inxi below as requested
Kernel: 6.1.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=49c25010-2c91-4bce-ac8f-f1252694d387 rw [email protected]
loglevel=3 ibt=off
Type: Desktop System: Micro-Star product: MS-7C37 v: 1.0
Mobo: Micro-Star model: MPG X570 GAMING EDGE WIFI (MS-7C37) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.B0
date: 09/07/2020
Device-1: hidpp_battery_0 model: Logitech Marathon Mouse/Performance Plus
M705 serial: <filter> charge: 50% (should be ignored) rechargeable: yes
status: N/A
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201006
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3698 high: 4624 min/max: 2200/5073 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3700 2: 3700
3: 3700 4: 3700 5: 3700 6: 3700 7: 3700 8: 3700 9: 3677 10: 3700 11: 3927
12: 3171 13: 3700 14: 3700 15: 3700 16: 3700 17: 3700 18: 3700 19: 3700
20: 3700 21: 3183 22: 3700 23: 4624 24: 3585 bogomips: 177600
Device-1: NVIDIA AD102 [GeForce RTX 4090] vendor: Gigabyte driver: nvidia
v: 525.85.05 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022-23+ pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 2d:00.0 chip-ID: 10de:2684 class-ID: 0300
compositor: kwin_x11 driver: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 5120x1440 s-dpi: 80 s-size: 1626x457mm (64.02x17.99")
s-diag: 1689mm (66.5")
Monitor-1: DP-0 res: 5120x1440 hz: 120 dpi: 130048
size: 1x1mm (0.04x0.04") diag: 1mm (0.06") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.85.05 renderer: NVIDIA GeForce RTX
4090/PCIe/SSE2 direct render: Yes
Device-1: NVIDIA AD102 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel bus-ID: 5-4.1:4 v: kernel pcie: chip-ID: 1395:005d
gen: 4 class-ID: 0300 speed: 16 GT/s serial: <filter> lanes: 16
bus-ID: 2d:00.1 chip-ID: 10de:22ba class-ID: 0403
bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: DSEA A/S Sennheiser Main Audio type: USB
Sound API: ALSA v: k6.1.8-zen1-1-zen running: yes
vendor: Micro-Star MSI X570-A PRO driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 27:00.0 chip-ID: 10ec:8168
IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 29:00.0
IF: wlp41s0 state: down mac: <filter>
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-4:2 chip-ID: 8087:0aa7 class-ID: e001
Local Storage: total: 6.88 TiB used: 23.02 GiB (0.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW020T9
lanes: 4 type: SSD serial: <filter> rev: 001C temp: 36.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung model: SSD 960 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 3B7QCXE7 temp: 38.9 C scheme: MBR
model: WD1003FZEX-00MK2A0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: MBR
ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 250GB
ID-5: /dev/sdc maj-min: 8:32 type: USB vendor: Western Digital
model: WD My Book 1140 size: 2.73 TiB block-size: physical: 4096 B
logical: 4096 B type: N/A serial: <filter> rev: 1022 scheme: MBR
ID-6: /dev/sdd maj-min: 8:48 type: USB vendor: Buffalo model: External HDD
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 0000 scheme: MBR
ID-7: /dev/sde maj-min: 8:64 type: USB model: USB DISK 2.0 size: 11.16 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: <filter>
rev: PMAP scheme: MBR
used: 23.02 GiB (9.9%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 608 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
System Temperatures: cpu: 52.8 C mobo: N/A gpu: nvidia temp: 44 C
Processes: 386 Uptime: 1h 56m wakeups: 6 Memory: 31.27 GiB
used: 6.32 GiB (20.2%) Init: systemd v: 252 default: graphical
pkgs: 1377 libs: 350 tools: octopi,paru Shell: fish v: 3.6.0 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.24
Garuda (2.6.14-1):
System install date: 2023-01-26
Last full system update: 2023-01-30 ↻
