Hello
Using my mouse on my external monitor has become extremely laggy but in only very specific conditions and I cant figure out why. It lags unless:
- I’m using my laptop’s mouse-pad
- I’m playing a game where my mouse is locked
- My cursor is on the internal monitor on my laptop
By laggy I mean the mouse is very snappy and unresponsive, and also my current task on the monitor freezes for a moment or two. This doesn’t effect the internal monitor of my laptop.
I have tried using different USB ports, using a different mouse and there is no effect. Ive tried switching the HDMI cable and nothing changes either. Ive also looked online and there’s nothing very similar to this specific issue as far as I can see, however I did check my CPU usage and it seems that my mouse on my external monitor uses only one core and causes it to peak. In fact any input from my mouse to my monitor seems to do this, including using right or left click.
I tried switching to my NVIDIA GPU, and while it worked initially the lag got worse and worse over time until it got into the same condition. I also noticed this happened over the day in general, where the more i would use my mouse (outside of the previous conditions) the worse the lag would get.
This only started after I updated recently. Might be a coincidence but I figured it was worth mentioning.
Edit: Using my mousepad is still peaking my CPU, but not causing as much lag. Its still someone noticeable though
garuda-inxi:
Kernel: 6.12.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=46edefa1-ac3b-4083-98be-118cae6a7a8a rw rootflags=subvol=@
quiet resume=UUID=a392202c-619f-449d-bda2-75b6d61a9900 loglevel=3 ibt=off
Desktop: Hyprland v: 0.45.2 with: waybar tools:
avail: hyprlock,swayidle,swaylock vt: 1 dm: SDDM Distro: Garuda
Type: Laptop System: Dell product: Dell G15 5535 v: 1.7.1
serial: <superuser required> Chassis: type: 10 v: 1.7.1
Mobo: Dell model: 0XMT14 v: A01 serial: <superuser required> part-nu: 0C56
uuid: <superuser required> UEFI: Dell v: 1.7.1 date: 03/19/2024
ID-1: BAT1 charge: 74.4 Wh (100.0%) condition: 74.4/86.0 Wh (86.5%)
volts: 12.9 min: 11.4 model: SMP-COS3.82 DELL 70N2F3BF type: Li-poly
serial: <filter> status: full cycles: 89
Device-1: wacom_battery_0 model: Wacom Intuos BT M serial: N/A
charge: 100% status: discharging
Info: model: AMD Ryzen 7 7840HS w/ Radeon 780M Graphics bits: 64
microcode: 0xA704107
Speed (MHz): avg: 400 min/max: 400/5137 boost: enabled scaling:
4: 400 5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400
14: 400 15: 400 16: 400 bogomips: 121383
Device-1: NVIDIA AD107M [GeForce RTX 4050 Max-Q / Mobile] vendor: Dell
driver: nvidia v: 565.77 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s ports: active: none off: HDMI-A-1
empty: none bus-ID: 01:00.0 chip-ID: 10de:28e1 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Phoenix1 vendor: Dell
driver: amdgpu v: kernel arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm)
built: 2023+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1
empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, DP-8, Writeback-1
bus-ID: 05:00.0 chip-ID: 1002:15bf class-ID: 0300 temp: 34.0 C
Device-3: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 0bda:567e
compositor: Hyprland v: 0.45.2 driver: X: loaded: amdgpu,nvidia
dri: radeonsi gpu: amdgpu,nvidia,nvidia-nvswitch d-rect: 3840x1080
display-ID: 1
Monitor-1: HDMI-A-1 pos: right model: LG (GoldStar) FULL HD
serial: <filter> built: 2021 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
scale: 1 size: 480x270mm (18.9x10.63") diag: 551mm (21.7") ratio: 16:9
Monitor-2: eDP-1 pos: primary,left model: Najing CEC Panda 0x005f
built: 2021 res: 1920x1080 hz: 120 dpi: 142 gamma: 1.2 scale: 1
max: 1920x1080 min: 640x480
API: Vulkan v: 1.4.303 layers: 11 device: 0 type: integrated-gpu name: AMD
Radeon 780M (RADV GFX1103_R1) driver: N/A device-ID: 1002:15bf
surfaces: xcb,xlib,wayland device: 1 type: discrete-gpu name: NVIDIA
GeForce RTX 4050 Laptop GPU driver: N/A device-ID: 10de:28e1
Device-1: NVIDIA AD107 High Definition Audio vendor: Dell
speed: 16 GT/s lanes: 16 bus-ID: 05:00.1 chip-ID: 1002:1640 class-ID: 0403
vendor: Dell driver: snd_pci_ps v: kernel alternate: snd_pci_acp3x,
snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
snd_sof_amd_vangogh, snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
vendor: Dell driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.12.4-zen1-1-zen status: kernel-api tools: N/A
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
lanes: 1 bus-ID: 04:00.0 chip-ID: 14c3:7961 class-ID: 0280
Device-1: Foxconn / Hon Hai MediaTek MT7921 Bluetooth driver: btusb v: 0.8
type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:4
chip-ID: 0489:e0c8 class-ID: e001 serial: <filter>
Local Storage: total: 476.94 GiB used: 160.66 GiB (33.7%)
model: PC SN740 NVMe WD 512GB size: 476.94 GiB block-size: physical: 512 B
fw-rev: 73914108 temp: 33.9 C scheme: GPT
ID-1: / raw-size: 460.21 GiB size: 460.21 GiB (100.00%)
used: 160.66 GiB (34.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 460.21 GiB size: 460.21 GiB (100.00%)
ID-4: /var/log raw-size: 460.21 GiB size: 460.21 GiB (100.00%)
ID-5: /var/tmp raw-size: 460.21 GiB size: 460.21 GiB (100.00%)
ID-1: swap-1 type: zram size: 14.93 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.43 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 44.0 C mobo: 40.0 C sodimm: SODIMM C gpu: amdgpu
temp: 35.0 C
Fan Speeds (rpm): cpu: 1900 mobo: 4300
Memory: total: 16 GiB note: est. available: 14.93 GiB used: 5.63 GiB (37.7%)
Processes: 351 Power: uptime: 19m states: freeze,mem,disk suspend: s2idle
image: 5.92 GiB services: upowerd Init: systemd v: 257 default: graphical
Packages: pm: pacman pkgs: 1418 libs: 413 tools: pacseek,paru,yay
Compilers: gcc: 14.2.1 Shell: garuda-inxi default: Bash v: 5.2.37
running-in: kitty inxi: 3.3.36
System install date: 2024-10-19
Last full system update: 2024-12-17 ↻
