ModuleNotFoundError: No module named 'sdl2'
I try to run Tauon-music-box but it doesn't work, instead this message appears.
  File "/opt/tauon-music-box/tauon.py", line 8, in <module>
    from sdl2 import *
I've tried reinstalling but it didn't work.
inxi -Faz below
  Kernel: 5.10.78.55.realtime1-1-rt-lts x86_64 bits: 64 compiler: gcc
    v: 11.1.0 parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-rt-lts
    root=UUID=92738ace-d95f-4f3e-9a50-f9170e33d3ba rw [email protected]
  Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop System: Gigabyte product: AX370M-DS3H v: N/A
  Mobo: Gigabyte model: AX370M-DS3H-CF v: x.x serial: <superuser required>
    UEFI-[Legacy]: American Megatrends v: F22 date: 03/15/2018
  Info: model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+
    L3: 16 MiB desc: 2x8 MiB
  Speed (MHz): avg: 3834 high: 3864 min/max: 1550/3400 boost: enabled
    scaling: driver: acpi-cpufreq governor: performance cores: 1: 3864 2: 3860
    3: 3853 4: 3864 5: 3807 6: 3858 7: 3845 8: 3843 9: 3825 10: 3784 11: 3769
    12: 3842 bogomips: 81436
    STIBP: disabled, RSB filling
    vendor: XFX Pine driver: amdgpu v: kernel bus-ID: 08:00.0
  Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0")
    s-diag: 777mm (30.6")
  Monitor-1: DisplayPort-0 res: 2560x1440 dpi: 93
    size: 697x392mm (27.4x15.4") diag: 800mm (31.5")
  OpenGL: renderer: AMD Radeon RX 580 Series (POLARIS10 DRM 3.40.0
    5.10.78.55.realtime1-1-rt-lts LLVM 13.0.0)
    v: 4.6 Mesa 21.3.1 direct render: Yes
    vendor: XFX Pine driver: snd_hda_intel v: kernel bus-ID: 08:00.1
    chip-ID: 1002:aaf0 class-ID: 0403
    v: kernel bus-ID: 0a:00.3 chip-ID: 1022:1457 class-ID: 0403
  Sound Server-1: ALSA v: k5.10.78.55.realtime1-1-rt-lts running: yes
    vendor: Gigabyte driver: r8169 v: kernel port: f000 bus-ID: 04:00.0
  Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: N/A
    modules: iwlwifi bus-ID: 07:00.0 chip-ID: 8086:24fb class-ID: 0280
  Device-3: Realtek RTL8814AU 802.11a/b/g/n/ac Wireless Adapter type: USB
    driver: rtl8814au bus-ID: 3-1:2 chip-ID: 0bda:8813 class-ID: 0000
  IF: wlp9s0f3u1 state: up mac: <filter>
  Local Storage: total: 2.04 TiB used: 165.88 GiB (7.9%)
    model: WDS240G2G0A-00JH30 size: 223.58 GiB block-size: physical: 512 B
    logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0000
    scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM006-2DM164
    type: HDD rpm: 7200 serial: <filter> rev: CC26 scheme: MBR
  ID-1: / raw-size: 223.58 GiB size: 223.58 GiB (100.00%)
    used: 165.88 GiB (74.2%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
  ID-2: /home raw-size: 223.58 GiB size: 223.58 GiB (100.00%)
  ID-3: /var/log raw-size: 223.58 GiB size: 223.58 GiB (100.00%)
  ID-4: /var/tmp raw-size: 223.58 GiB size: 223.58 GiB (100.00%)
  ID-1: swap-1 type: zram size: 7.78 GiB used: 3.13 GiB (40.3%)
  System Temperatures: cpu: 40.4 C mobo: N/A gpu: amdgpu temp: 59.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 769
  Processes: 370 Uptime: 10h 45m wakeups: 0 Memory: 7.78 GiB
  used: 2.83 GiB (36.3%) Init: systemd v: 249 tool: systemctl Compilers:
  gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1455 lib: 443 Shell: fish
  v: 3.3.1 running-in: kitty inxi: 3.3.11
As an AUR package this depends on several SDL2 library packages.
How did you install this package, and have you rebuilt it since the Python 3.10 update?
No. How can I do that?
Try this: https://wiki.archlinux.org/title/Arch_User_Repository#Installing_and_upgrading_packages
I followed the steps and it still ends up saying.
╭─[email protected] in ~
 ╰─λ tauon
    from sdl2 import *
Even tried reinstalling sdl2 and it didn't work.
I've just tried installing it myself and it works fine.
I'd try removing the package completely, and then building and installing again using makepkg to make sure it's built from scratch.
I no this is not recommended and you still haveing trouble with Tauon-music-box you can always install as a snap/flatpack
