Hello Garuda users.
I can't open the hardwareconfiguration menu, it showes up in the search bar, but when I open it, it just takes me to the start page of the Settings Program. Also some settings I see on Youtube Videos/Forum Posts just aren't there for me...
Here is the Video: 2023-02-23 13-26-00.mkv - VEED
Kernel: 6.2.0-AMD arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-amd
root=UUID=d49bf23f-b8f4-4618-aab1-784c23938b39 rw [email protected]
resume=UUID=2fc9941b-8b88-49ce-8e63-d3346a0738ad loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.1 tk: Qt v: 5.15.8 info: latte-dock
Type: Laptop System: Acer product: Aspire A315-42 v: V1.11
Mobo: PK model: Sleepy_PK v: V1.11 serial: <superuser required>
UEFI: Insyde v: 1.11 date: 11/16/2020
ID-1: BAT1 charge: 25.1 Wh (100.0%) condition: 25.1/36.7 Wh (68.3%)
volts: 12.3 min: 11.3 model: LGC AC14B18 type: Li-ion serial: <filter>
status: full
Info: model: AMD Ryzen 7 3700U with Radeon Vega Mobile Gfx bits: 64
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 2743 high: 2947 min/max: 1400/2300 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2138 2: 2295
3: 2945 4: 2939 5: 2947 6: 2945 7: 2917 8: 2820 bogomips: 36738
vendor: Acer Incorporated ALI driver: amdgpu v: kernel arch: GCN-5
lanes: 16 ports: active: HDMI-A-1,eDP-1 empty: none bus-ID: 05:00.0
chip-ID: 1002:15d8 class-ID: 0300 temp: 70.0 C
Device-2: Quanta VGA WebCam type: USB driver: uvcvideo bus-ID: 2-1:2
chip-ID: 0408:a031 class-ID: 0e02 serial: <filter>
Screen-1: 0 s-res: 3600x1080 s-dpi: 96 s-size: 952x285mm (37.48x11.22")
s-diag: 994mm (39.12")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: right model: Dell P2213
serial: <filter> built: 2014 res: 1680x1050 hz: 60 dpi: 90 gamma: 1.2
size: 473x296mm (18.62x11.65") diag: 558mm (22") ratio: 16:10 modes:
max: 1680x1050 min: 720x400
Monitor-2: eDP-1 mapped: eDP pos: primary,left model: AU Optronics 0x61ed
built: 2018 res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2
max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 22.3.5 renderer: AMD Radeon Vega 10 Graphics
(raven LLVM 15.0.7 DRM 3.49 6.2.0-AMD) direct-render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel bus-ID: 1-1.4:4
v: kernel pcie: chip-ID: 1395:0025 gen: 3 class-ID: 0300 speed: 8 GT/s
lanes: 16 bus-ID: 05:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor
vendor: Acer Incorporated ALI driver: snd_pci_acp3x v: kernel
alternate: snd_rn_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_rpl_pci_acp6x,snd_pci_ps,snd_sof_amd_renoir,snd_sof_amd_rembrandt
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI
Device-4: DSEA A/S Headset [PC 8] type: USB
Sound API: ALSA v: k6.2.0-AMD running: yes
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168
vendor: Lite-On driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 04:00.0 chip-ID: 168c:0042 class-ID: 0280
Device-1: Lite-On Qualcomm Atheros QCA9377 Bluetooth type: USB driver: btusb
v: 0.8 bus-ID: 2-4:4 chip-ID: 04ca:3015 class-ID: e001
Local Storage: total: 476.94 GiB used: 20.98 GiB (4.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PCP3512F-AA
lanes: 4 type: SSD serial: <filter> rev: ECFK52.3 temp: 31.9 C scheme: GPT
ID-1: / raw-size: 245.59 GiB size: 245.59 GiB (100.00%)
used: 15.7 GiB (6.4%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
used: 608 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 214.84 GiB size: 214.84 GiB (100.00%)
used: 5.28 GiB (2.5%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-4: /var/log raw-size: 245.59 GiB size: 245.59 GiB (100.00%)
ID-5: /var/tmp raw-size: 245.59 GiB size: 245.59 GiB (100.00%)
ID-1: swap-1 type: zram size: 13.61 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
System Temperatures: cpu: 69.6 C mobo: N/A gpu: amdgpu temp: 69.0 C
Processes: 297 Uptime: 12m wakeups: 1 Memory: 13.61 GiB
used: 3.34 GiB (24.6%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 2010
libs: 537 tools: octopi,paru,yaourt Shell: fish v: 3.6.0 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2023-02-19
Last full system update: 2023-02-23 ↻
