Missing fonts for Plymouth
Hi,
during garuda-update something doesn’t go well due to missing fonts.
The garuda is able to make boot and it works fine.
But I don’t these errors.
How I can fix them?
Here my garuda-inxi
Kernel: 6.6.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e1b87af6-67e0-4350-97cb-8bdfe430d209 rw rootflags=subvol=@
quiet
cryptdevice=UUID=735c2a29-e901-4fc7-893a-52a88bf43878:luks-735c2a29-e901-4fc7-893a-52a88bf43878
root=/dev/mapper/luks-735c2a29-e901-4fc7-893a-52a88bf43878
resume=/dev/mapper/luks-23c04b79-4698-461f-ade3-f485919f86ca loglevel=3
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_wayland dm: SDDM
Type: Laptop System: FUJITSU product: LIFEBOOK A544 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: FUJITSU model: FJNBB35 serial: <filter> UEFI: FUJITSU // Phoenix
v: Version 1.13 date: 11/18/2013
ID-1: BAT0 charge: 0.6 Wh (100.0%) condition: 0.6/4.5 Wh (14.2%) volts: 12.4
min: 10.8 model: PTL CP651527-01 type: Li-ion serial: <filter> status: full
cycles: 277
Info: model: Intel Core i7-4702MQ socket: rPGA988B (On Board) note: check
bits: 64 type: MT MCP arch: Haswell gen: core 4 level: v3 note: check
built: 2013-15 process: Intel 22nm family: 6 model-id: 0x3C (60)
stepping: 3 microcode: 0x16
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 2195 min/max: 800/3200 base/boost: 2200/2200 scaling:
driver: intel_cpufreq governor: performance volts: 0.7 V ext-clock: 100 MHz
cores: 1: 2195 2: 2195 3: 2195 4: 2195 5: 2195 6: 2195 7: 2195 8: 2195
bogomips: 35119
Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Fujitsu
driver: i915 v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports:
active: HDMI-A-1 off: eDP-1 empty: VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0416 class-ID: 0300
Device-2: Importek FJ Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:5 chip-ID: 10f1:1a58
class-ID: 0e02
Display: server: X.Org v: 23.2.2 with: Xwayland v: 23.2.2
alternate: fbdev,intel,vesa dri: crocus gpu: i915 display-ID: :1
s-diag: 583mm (22.95")
Monitor-1: HDMI-A-1 res: 1920x1080 hz: 60 dpi: 102
size: 480x270mm (18.9x10.63") diag: 551mm (21.68") modes: N/A
device: 1 drv: swrast surfaceless: drv: crocus x11: drv: crocus
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4600 (HSW
GT2) device-ID: 8086:0416 memory: 1.46 GiB unified: yes
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: Intel
HD Graphics 4600 (HSW GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:0416 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
vendor: Fujitsu driver: snd_hda_intel v: kernel bus-ID: 00:03.0
Device-2: Intel 8 Series/C220 Series High Definition Audio
vendor: Fujitsu . 8 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:8c20 class-ID: 0403
API: ALSA v: k6.6.3-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.0 status: n/a (root, process) with:
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:08b1 class-ID: 0280
vendor: Fujitsu driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-2: virbr1 state: down mac: <filter>
IF-ID-3: virbr2 state: down mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:7 chip-ID: 8087:07dc
rfk-block: hardware: no software: yes address: <filter> bt-v: 4.0 lmp-v: 6
Local Storage: total: 931.51 GiB used: 167.8 GiB (18.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 1TB
family: based SSDs size: 931.51 GiB block-size: physical: 512 B
logical: 512 B sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 1B6Q temp: 27 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 212d 4h cycles: 2287
written: 12.13 TiB
ID-1: / raw-size: 922.45 GiB size: 922.45 GiB (100.00%)
used: 167.8 GiB (18.2%) fs: btrfs block-size: 4096 B dev: /dev/dm-0
maj-min: 254:0 mapped: luks-735c2a29-e901-4fc7-893a-52a88bf43878
used: 694 KiB (0.3%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 922.45 GiB size: 922.45 GiB (100.00%)
ID-4: /var/log raw-size: 922.45 GiB size: 922.45 GiB (100.00%)
ID-5: /var/tmp raw-size: 922.45 GiB size: 922.45 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.66 GiB used: 0 KiB (0.0%) priority: 100
dev: /dev/dm-1 maj-min: 254:1
mapped: luks-23c04b79-4698-461f-ade3-f485919f86ca
System Temperatures: cpu: 66.0 C pch: 56.5 C mobo: N/A
Processes: 305 Uptime: 4m wakeups: 0 Memory: total: 8 GiB
available: 7.66 GiB used: 3.54 GiB (46.2%) igpu: 32 MiB Init: systemd v: 254
Packages: pm: pacman pkgs: 1900 libs: 460 tools: pamac,paru
Shell: garuda-inxi (sudo) default: Bash v: 5.2.21 running-in: konsole
inxi: 3.3.31
Garuda (2.6.19-2):
System install date:     2021-03-13
Last full system update: 2023-12-04
Total system updates:    1573
--> Updates per week:    11
Here a part of garuda-update log file.
( 6/18) Arming ConditionNeedsUpdate...
( 7/18) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux-zen.preset: 'default'
==> Using configuration file: '/etc/mkinitcpio.conf'
  -> -k /boot/vmlinuz-linux-zen -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-zen.img
==> Starting build: '6.6.3-zen1-1-zen'
  -> Running build hook: [base]
  -> Running build hook: [udev]
  -> Running build hook: [autodetect]
  -> Running build hook: [modconf]
  -> Running build hook: [block]
==> WARNING: Possibly missing firmware for module: 'xhci_pci'
  -> Running build hook: [keyboard]
  -> Running build hook: [keymap]
  -> Running build hook: [consolefont]
  -> Running build hook: [plymouth]
==> ERROR: invalid symlink: '/usr/share/fonts/noto/NotoSans-Regular.ttf'
find: '/usr/share/fonts/Plymouth.ttf': No such file or directory
==> ERROR: invalid symlink: '/usr/share/fonts/Plymouth.ttf'
==> ERROR: invalid symlink: '/usr/share/fonts/noto/NotoSansMono-Regular.ttf'
find: '/usr/share/fonts/Plymouth-monospace.ttf': No such file or directory
==> ERROR: invalid symlink: '/usr/share/fonts/Plymouth-monospace.ttf'
  -> Running build hook: [encrypt]
  -> Running build hook: [openswap]
  -> Running build hook: [resume]
  -> Running build hook: [filesystems]
==> Generating module dependencies
==> Creating zstd-compressed initcpio image: '/boot/initramfs-linux-zen.img'
==> WARNING: errors were encountered during the build. The image may not be complete.
==> Building image from preset: /etc/mkinitcpio.d/linux-zen.preset: 'fallback'
  -> -k /boot/vmlinuz-linux-zen -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-zen-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: 'aic94xx'
==> WARNING: Possibly missing firmware for module: 'bfa'
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'qla1280'
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
==> WARNING: Possibly missing firmware for module: 'wd719x'
==> Creating zstd-compressed initcpio image: '/boot/initramfs-linux-zen-fallback.img'
