Miscolored Pixels in Top Left of Panel Widget Menus
Greetings,
I have found an issue that now that I have seen it I cannot unsee it. It would seem that in the top left corner of the various panel widgets (i.e. app menu, digital clock, etc) there is a small line of miscolored pixels. I have confirmed this issue persists across various theme options. Is anyone else seeing a similar issue?
garuda-inxi:
  Kernel: 6.9.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    root=UUID=acc91bbd-51b8-4669-9368-f85ecd75b0a1 rw rootflags=subvol=@
    resume=UUID=5bb1f004-d544-4ddf-bfac-8a1cf21296d8 loglevel=3
    nvidia-drm.modeset=1 ibt=off
  Desktop: KDE Plasma v: 6.1.0 tk: Qt v: N/A info: frameworks v: 6.3.0
  Type: Laptop System: LENOVO product: ThinkPad W541 v: 1.0
  Mobo: LENOVO model: ThinkPad W541 v: 1.0 serial: <superuser required>
    BIOS: coreboot v: 4.20-410-g3e523b495c date: 06/17/2023
  Info: model: Intel Core i7-4710MQ bits: 64 type: MT MCP arch: Haswell
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 3428 high: 3500 min/max: 800/3500 scaling:
    driver: intel_cpufreq governor: performance cores: 1: 3444 2: 3365 3: 3441
    4: 3398 5: 3458 6: 3416 7: 3500 8: 3407 bogomips: 39905
  Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Lenovo
    driver: i915 v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports:
    active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2, VGA-1 bus-ID: 00:02.0
    chip-ID: 8086:0416 class-ID: 0300
  Device-2: NVIDIA GK107GLM [Quadro K1100M] vendor: Lenovo driver: nvidia
    v: 470.256.02 alternate: nouveau,nvidia_drm non-free: series: 470.xx+
    status: legacy-active (EOL~2024-09-xx) arch: Kepler code: GKxxx
    process: TSMC 28nm built: 2012-2018 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 3 speed: 8 GT/s ports: active: none empty: DP-3
    bus-ID: 01:00.0 chip-ID: 10de:0ff6 class-ID: 0300
  Device-3: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-12:4 chip-ID: 5986:026a
    class-ID: 0e02
    compositor: kwin_wayland driver: X: loaded: modesetting,nvidia dri: crocus
  API: EGL v: 1.5 hw: drv: intel crocus drv: nvidia platforms: device: 0
    drv: nvidia device: 1 drv: crocus device: 3 drv: swrast gbm: drv: crocus
    surfaceless: drv: crocus wayland: drv: crocus x11: drv: crocus
    inactive: device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.1.2-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4600 (HSW
    GT2) device-ID: 8086:0416 memory: 1.46 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.3.279 layers: 4 device: 0 type: integrated-gpu name: Intel
    HD Graphics 4600 (HSW GT2) driver: mesa intel v: 24.1.2-arch1.1
    device-ID: 8086:0416 surfaces: xcb,xlib,wayland device: 1
    type: discrete-gpu name: Quadro K1100M driver: nvidia v: 470.256.02
    device-ID: 10de:0ff6 surfaces: xcb,xlib,wayland device: 2 type: cpu
    v: 24.1.2-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
    vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:03.0
  Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
  Device-3: NVIDIA GK107 HDMI Audio vendor: Lenovo driver: snd_hda_intel
    chip-ID: 10de:0e1b class-ID: 0403
  API: ALSA v: k6.9.6-zen1-1-zen status: kernel-api tools: N/A
  Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet I217-LM driver: N/A modules: e1000e port: 1040
    bus-ID: 00:19.0 chip-ID: 8086:153a class-ID: 0200
  Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:08b2 class-ID: 0280
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-11:3 chip-ID: 8087:07dc
    lmp-v: 6 status: discoverable: no pairing: no class-ID: 6c010c
  Local Storage: total: 931.51 GiB used: 31.63 GiB (3.4%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
    tech: SSD serial: <filter> fw-rev: 3B6Q scheme: MBR
  ID-1: / raw-size: 914.37 GiB size: 914.37 GiB (100.00%)
    used: 31.63 GiB (3.5%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
  ID-2: /home raw-size: 914.37 GiB size: 914.37 GiB (100.00%)
  ID-3: /var/log raw-size: 914.37 GiB size: 914.37 GiB (100.00%)
  ID-4: /var/tmp raw-size: 914.37 GiB size: 914.37 GiB (100.00%)
  ID-1: swap-1 type: zram size: 15.58 GiB used: 0 KiB (0.0%) priority: 100
  ID-2: swap-2 type: partition size: 17.14 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sda2 maj-min: 8:2
  System Temperatures: cpu: 59.0 C mobo: N/A
  Memory: total: 16 GiB available: 15.58 GiB used: 4.14 GiB (26.6%)
  Processes: 266 Power: uptime: 22m states: freeze,standby,mem,disk
    suspend: deep avail: s2idle,shallow wakeups: 0 hibernate: platform
    avail: shutdown, reboot, suspend, test_resume image: 6.18 GiB
    services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd
    v: 256 default: graphical tool: systemctl
  Packages: pm: pacman pkgs: 1979 libs: 446 tools: octopi,paru pm: flatpak
    pkgs: 0 Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi
    default: Bash v: 5.2.26 running-in: ghostty inxi: 3.3.35
  System install date:     2023-12-07
  Last full system update: 2024-06-23
If i’m not mistaken that does probably happened in wayland session, try switching to X11 to see if it still there
I can confirm that, regardless of whether the panel is at the top or bottom. The “problem” only occurs when the panels are in non-floating mode, the issue does not occur in floating mode.
I can reproduce it with plasma on arch, artix, kaos and garuda, regardless of whether it is x11 or wayland. Seems to be a kde bug.
Happens here too. However, only with the browser window and only in rare cases, which is why it doesn’t bother me.
If the rare case occurs, I maximize the window in some way and wait patiently for a solution :smiley:
The most recent update that KDE pushed seems to have fixed the issue, so I’ll mark this issue as solved.
