Mirror.hackingand.coffee?
is it a legit mirror or is there something funny going on? >.>
i doubt you need the itchy-fuzz for this but here it is regardless lmao
❯ garuda-inxi
  Kernel: 6.4.10-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=63f3c83e-5747-44de-974f-c89d4101bd95 rw rootflags=subvol=@
    resume=UUID=c0d4fb48-27bb-458a-9d32-db4bea9d7420 loglevel=3 ibt=off
  Type: Desktop Mobo: MSI model: Z77A-GD55 (MS-7751) v: 1.0
    serial: <superuser required> UEFI: American Megatrends v: 1.11
    date: 11/20/2013
  Info: model: Intel Core i7-3770K bits: 64 type: MT MCP arch: Ivy Bridge
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 3378 high: 3900 min/max: 1600/3900 scaling:
    driver: intel_cpufreq governor: performance cores: 1: 3900 2: 3580 3: 3900
    4: 3900 5: 1600 6: 3900 7: 3900 8: 2344 bogomips: 55998
    vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-1 code: Navi-1x
    process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 03:00.0
    chip-ID: 1002:731f class-ID: 0300
  Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Asus VX238 serial: <filter>
    built: 2015 res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2
    size: 510x290mm (20.08x11.42") diag: 587mm (23.1") ratio: 16:9 modes:
  API: OpenGL v: 4.6 Mesa 23.1.5 renderer: AMD Radeon RX 5600 XT (navi10
    LLVM 15.0.7 DRM 3.52 6.4.10-zen2-1-zen) direct-render: Yes
    vendor: Micro-Star MSI 7 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
  Device-2: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel pcie:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab38
  API: ALSA v: k6.4.10-zen2-1-zen status: kernel-api with: aoss
  Device-1: Intel 82579V Gigabit Network vendor: Micro-Star MSI driver: e1000e
    v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1503 class-ID: 0200
  IF-ID-1: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A
    mac: <filter>
  IF-ID-2: proton0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
  IF-ID-3: pvpnksintrf0 state: unknown speed: N/A duplex: N/A mac: <filter>
  Local Storage: total: 2.91 TiB used: 349.38 GiB (11.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SH103S3120G
    tech: SSD serial: <filter> fw-rev: BBF0 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SH103S3120G
  ID-3: /dev/sdc maj-min: 8:32 vendor: Kingston model: SA400S37480G
    size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 0107 scheme: GPT
  ID-4: /dev/sdd maj-min: 8:48 vendor: Kingston model: SA400S37480G
  ID-5: /dev/sde maj-min: 8:64 vendor: Western Digital
    model: WD20EZRX-00D8PB0 size: 1.82 TiB block-size: physical: 4096 B
    logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: 0A80
    scheme: MBR
  ID-1: / raw-size: 39.75 GiB size: 39.75 GiB (100.00%)
    used: 12.54 GiB (31.5%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
  ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%)
    used: 576 KiB (0.1%) fs: vfat dev: /dev/sda4 maj-min: 8:4
  ID-3: /home raw-size: 71.04 GiB size: 71.04 GiB (100.00%)
    used: 16.13 GiB (22.7%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
  ID-4: /var/log raw-size: 39.75 GiB size: 39.75 GiB (100.00%)
  ID-5: /var/tmp raw-size: 39.75 GiB size: 39.75 GiB (100.00%)
  Kernel: swappiness: 15 (default 60) cache-pressure: 100 (default) zswap: no
  ID-1: swap-1 type: zram size: 23.42 GiB used: 19.5 MiB (0.1%)
  ID-2: swap-2 type: partition size: 512 MiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/sda3 maj-min: 8:3
  System Temperatures: cpu: 42.0 C mobo: N/A gpu: amdgpu temp: 42.0 C
    mem: 40.0 C
  Processes: 319 Uptime: 3h 33m wakeups: 0 Memory: total: 24 GiB
  available: 23.42 GiB used: 3.39 GiB (14.5%) Init: systemd v: 254
  pm: pacman pkgs: 2002 libs: 557 tools: octopi,paru Shell: fish v: 3.6.1
  running-in: konsole inxi: 3.3.29
  System install date:     2023-04-12
  Last full system update: 2023-08-16 ↻
Legit Arch mirror:
https://archlinux.org/mirrors/hackingand.coffee/
Seems to be having issues:
rsync error: timeout waiting for daemon connection (code 35) at socket.c(278) [Receiver=3.2.7]
okay, thanks boss! the name looked fishy to me.
and thanks for that link so i can reference it in the future.
