Hi, Can you make a garuda sway or qtile minimal edition? the current one is bloated alot with unwanted tools.. Thanks
This is an old story...
Unwanted and bloated are personal attirbutes.
What is bloated to you may be important to others (and vice versa, what is critical to some is bloated to others).
Choices have been made, and it is not possible for a small team to proliferate with editions.
You can always remove what you don't need, and if something was dependent on Garuda configuration packages open a dedicated topic, to get advice on how to remove it or maybe reason together about this dependency.
