Hello,
I have a problem. I tried to open Minigalaxy on my long-standing Garuda installation earlier to play a GOG game. Unfortunately, it failed without any error message.
Only in the terminal did I get the following feedback:
╭─sfox@desktop in ~
╰─λ minigalaxy
File "/usr/bin/minigalaxy", line 19, in <module>
from minigalaxy.version import VERSION
ModuleNotFoundError: No module named 'minigalaxy'
Together with ChatGPT, I went through all possible steps, from a simple import minigalaxy
to full system consistency checks using sudo pacman -Qkk
We reinstalled Minigalaxy, graphics drivers, Vulkan packages, and who knows what else.
None of it worked, and at some point, I got fed up and simply downloaded a new Garuda image and wiped the system. I reinstalled Garuda, and…
It still doesn’t work?! Same error as before!
So instead of ChatGPT, I’m trying here now.
Here´s the Error:
╭─sfox@desktop in ~
╰─λ minigalaxy
In the graphical interface, absolutely nothing happens. No error, no feedback. So, the terminal output is all I can provide.
Here’s my Inxi:
╭─sfox@desktop in ~ took 0s
[🔴] × garuda-inxi
Kernel: 6.12.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=f0ce5d7f-1069-4632-85ba-4da20600b6af rw rootflags=subvol=@
Type: Desktop System: Gigabyte product: Z170X-UD3 v: N/A
Mobo: Gigabyte model: Z170X-UD3-CF v: x.x serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: F23g
date: 03/09/2018
Info: model: Intel Core i7-6700 bits: 64 type: MT MCP arch: Skylake-S
Speed (MHz): avg: 800 min/max: 800/4000 scaling: driver: intel_pstate
8: 800 bogomips: 54398
Device-1: NVIDIA TU104 [GeForce RTX 2060] driver: nvidia v: 565.77
alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of
2024-09; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none
off: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 10de:1e89
display-ID: 0
API: OpenGL v: 4.6.0 vendor: nvidia v: 565.77 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2
memory: 5.86 GiB display-ID: :1.0
API: Vulkan v: 1.4.303 layers: 15 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 2060 driver: N/A device-ID: 10de:1e89
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Gigabyte
Device-2: NVIDIA TU104 HD Audio driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f8
Device-3: C-Media CMI8788 [Oxygen HD Audio] vendor: ASUSTeK Virtuoso 100
driver: snd_virtuoso v: kernel bus-ID: 0f:04.0 chip-ID: 13f6:8788
class-ID: 0401
API: ALSA v: k6.12.6-zen1-1-zen status: kernel-api with: aoss
Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
Local Storage: total: 2.27 TiB used: 34.72 GiB (1.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Micron model: MTFDDAV256TBN-1AR1ZABHA
size: 238.47 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0014 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 500GB
ID-3: /dev/sdc maj-min: 8:32 vendor: SanDisk model: SD8SN8U256G1122
tech: SSD serial: <filter> fw-rev: 0000 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A02 scheme: GPT
ID-5: /dev/sde maj-min: 8:64 vendor: Crucial model: CT480BX200SSD1
size: 447.13 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: .6 scheme: MBR
used: 34.71 GiB (14.6%) fs: btrfs dev: /dev/sdc2 maj-min: 8:34
used: 584 KiB (0.2%) fs: vfat dev: /dev/sdc1 maj-min: 8:33
ID-1: swap-1 type: zram size: 23.42 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 40.0 C mobo: N/A
Memory: total: 24 GiB available: 23.42 GiB used: 2.25 GiB (9.6%)
Processes: 277 Power: uptime: 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 9.32 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2388 libs: 611 tools: octopi,paru Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date: 2024-12-22
Last full system update: 2024-12-23
I hope someone knows what to do, since GOG is my main Game-Source.
Thanks in advance.
