Middle Click Not Registered
This is the only issue on my Garuda machines (all of them) that I have yet to solve. It happens both in X11 and Wayland sessions. It's as if nothing is happening when clicking the middle mouse button, click is not registered. In Plasma Mouse settings on Wayland I even tried to bind an additional mouse button and clicking the middle button wasn't detected. Using "Press left and right buttons for middle click" enabled works, so middle click as a feature works. At least I have a workaround.
I've verified this with multiple mice and computers.
garuda-inxi:
Kernel: 6.1.23-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=e0430201-0931-4d49-a5a8-f8a1445e4ab0 rw rootflags=subvol=@
resume=UUID=ae0cdb3c-2994-4db6-8822-7960e6e25fe8 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.9 wm: kwin_wayland vt: 2
Type: Laptop System: Apple product: MacBookAir7,2 v: 1.0
serial: <superuser required> Chassis: type: 9 v: Mac-937CB26E2E02BB01
Mobo: Apple model: Mac-937CB26E2E02BB01 v: MacBookAir7,2
serial: <superuser required> UEFI: Apple v: 428.60.3.0.0 date: 10/27/2021
ID-1: BAT0 charge: 51.4 Wh (100.0%) condition: 51.4/54.3 Wh (94.5%)
volts: 8.5 min: 7.6 model: DP bq20z451 type: Li-ion serial: N/A status: full
cycles: 87
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M510
Info: model: Intel Core i5-5350U bits: 64 type: MT MCP arch: Broadwell
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2750 high: 2853 min/max: 500/2900 scaling:
driver: intel_cpufreq governor: performance cores: 1: 2700 2: 2750 3: 2700
4: 2853 bogomips: 14407
Device-1: Intel HD Graphics 6000 vendor: Apple driver: i915 v: kernel
arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: HDMI-A-1
off: eDP-1 empty: DP-1,DP-2,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1626
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel HD Graphics 6000 (BDW
GT3) direct-render: Yes
Device-1: Intel Broadwell-U Audio vendor: Apple driver: snd_hda_intel
Device-3: Broadcom 720p FaceTime HD Camera driver: facetimehd v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 14e4:1570
class-ID: 0480
API: ALSA v: k6.1.23-1-lts status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.68 status: active with: 1: pipewire-pulse
Device-1: Broadcom BCM4360 802.11ac Wireless Network Adapter vendor: Apple
bus-ID: 03:00.0 chip-ID: 14e4:43a0 class-ID: 0280
Device-2: ASIX AX88179 Gigabit Ethernet type: USB driver: cdc_ncm
bus-ID: 2-1:2 chip-ID: 0b95:1790 class-ID: 0a00 serial: <filter>
IF: enp0s20u1c2 state: up speed: 1000 Mbps duplex: half mac: <filter>
Device-1: Apple Bluetooth USB Host Controller type: USB driver: btusb v: 0.8
bus-ID: 1-3.3:11 chip-ID: 05ac:828f class-ID: fe01
Report: bt-adapter ID: hci0 rfk-id: 1 state: down
address: <filter>
Local Storage: total: 233.76 GiB used: 169.49 GiB (72.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: SSD SM0256G
size: 233.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 3A0Q scheme: GPT
ID-1: / raw-size: 224.66 GiB size: 224.66 GiB (100.00%)
used: 169.49 GiB (75.4%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 224.66 GiB size: 224.66 GiB (100.00%)
ID-4: /var/log raw-size: 224.66 GiB size: 224.66 GiB (100.00%)
ID-5: /var/tmp raw-size: 224.66 GiB size: 224.66 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.67 GiB used: 1.29 GiB (16.8%)
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 103.0 C pch: 98.0 C mobo: N/A
Processes: 258 Uptime: 3m wakeups: 4 Memory: 7.67 GiB used: 3.5 GiB (45.6%)
Init: systemd v: 253 default: graphical tool: systemctl Compilers:
gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman pkgs: 2170 libs: 596
tools: octopi,pamac,paru,pikaur Shell: fish v: 3.6.1 running-in: konsole
inxi: 3.3.26
System install date:     2022-12-02
Last full system update: 2023-04-13
Relevant software:       snapper NetworkManager dracut(custom) mkinitcpio
Are you trying to assign a custom function to it, or are you just trying to copy/paste?
I'm just trying to use it as a input device button. For example, the Applied Energistics mod for Minecraft requires middle click for certain actions.
Can you test if highlighting text and middle-clicking somewhere (text file, whatever) copies and pastes the text? If not, perhaps something wrong with the mouse button.
Tried to use middle click to copy/paste text but nothing happened and there isn't a new entry in my clipboard history. The mouse is not the problem, I've tested with multiple (known working) mice.
OK, turns out it is my mouse, I have to press middle click really hard for it to register. I just took my other test mouse that is brand new and never gets used, and now it works just fine. Not sure what happened when I tested it before. Glad this is working on a software level!
